其中,按键按一次数码管变化一次
#include "msp430g2553.h"
#define uint unsigned int
#define uchar unsigned char
void delay(uint z);
int num,wei;
unsigned long i;
uchar table[11]={
0x3f,0x06,0x5b,0x4f,0x66,
0x6d,0x7d,0x07,0x7f,0x6f,
0x00
uchar table1[8]={
0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};
void keyscan();
void main()
// Stop watchdog timer to prevent time out reset
WDTCTL = WDTPW + WDTHOLD;
//主系统时钟切换为外部高速晶振
if (CALBC1_8MHZ == 0xFF || CALDCO_8MHZ == 0xFF)
while(1); // If calibration constants erased, trap CPU!!
// Configure Basic Clock
BCSCTL1 = CALBC1_8MHZ; // Set range
DCOCTL = CALDCO_8MHZ; // Set DCO step + modulation
BCSCTL3 |= LFXT1S_2; // Set LFXT1
P1DIR=0XFF;//p4作为输出
P1DIR&=~BIT3;//P1.3按键输入
P2DIR=0XFF;//数码管段输出
P1IE |=BIT3; //使能按键P1.3引脚中断
P1IES&=~BIT3; //中断触发方式为上升降沿
P1IFG= 0x00; //清除中断标志位
_EINT();//开总中断
while(1)
P2OUT=table[10];
P1OUT|=BIT5;//设置p5.5为高电平
P2OUT=table1[wei];
P1OUT^=BIT5;//设置p5.5为低电平
P1OUT|=BIT6;
P2OUT=table[num];
P1OUT^=BIT6;
for(i=0;i<100000;i++);
P2OUT=table[10];
#pragma vector=PORT1_VECTOR
__interrupt void PORT1_ISR(void)
for(i=0;i<1000;i++);//消抖
if(P1IFG&BIT3)
num++;
wei++;
if(num==10)
num=0;
if(wei==8)
wei=0;
P1IFG=0; //清除中断标志位
