48脚的,没有外接晶体。3.3V供电,有朋友说把XT关掉,我调试看到XT脚是做GPIO用的。外围器件都是断开的,复位信号上有一个43K上拉,Vcore 有一个1uF电容,LPM3 我测试电流132uA(把仿真器去掉),去掉复位上拉,电流约100uA,和别的朋友5、6uA差距比较大。我的QQ是44277587,欢迎交流,测试程序如下,感谢!
#include
#define SYS14_WORKAROUND // Comment this line if silicon revision has SYS14 bug fixed
#ifdef SYS14_WORKAROUND
#define INIT_MEMORY_ADDR 0x0900
unsigned int *Address = ((unsigned int*)INIT_MEMORY_ADDR);
#endif
void main(void)
WDTCTL = WDTPW + WDTHOLD; // Stop watchdog timer
*Address = 0x9628;
*(Address+4) = 0x0800;
//*(Address+4) = 0x0000;
*Address = 0x9600;
#endif
// Clock Configuration
//UCSCTL4 = SELA_1+SELS__VLOCLK+SELM__VLOCLK; // ACLK = VLO
UCSCTL4 = SELA_1;
// Port Configuration
P1OUT = 0x00;P2OUT = 0x00;P3OUT = 0x00;P4OUT = 0x00;P5OUT = 0x00;P6OUT = 0x00;
PJOUT = 0x00;
P1DIR = 0xFF;P2DIR = 0xFF;P3DIR = 0xFF;P4DIR = 0xFF;P5DIR = 0xFF;P6DIR = 0xFF;
PJDIR = 0xFF;
__bis_SR_register(LPM3_bits); // Enter LPM3
__no_operation();
加上这几句试试:
// Disable VUSB LDO and SLDO
USBKEYPID = 0x9628; // set USB KEYandPID to 0x9628
// access to USB config registers enabled
USBPWRCTL &= ~(SLDOEN+VUSBEN); // Disable the VUSB LDO and the SLDO
USBKEYPID = 0x9600; // access to USB config registers disabled
// Disable SVS
PMMCTL0_H = PMMPW_H; // PMM Password
SVSMHCTL &= ~(SVMHE+SVSHE); // Disable High side SVS
SVSMLCTL &= ~(SVMLE+SVSLE); // Disable Low side SVS
