LM7808的最大允许电流不同厂家的产品是不一样的,CONTEX的是1A,NS和FS的是1.5A,超过此值就会自动进入限流保护状态,但是实际耗散功率并不单取决于输出电流,它是输出电流和输入输出电压差的乘积。如果输入输出之间的电压差只有3V,那么即使电流较大也不需要加散热片,如果输入输出电压是20V,即使输入电流只有0.5A,实际耗散功率也将达到10W,会严重发热。LM7805实际允许的耗散功率取决于很多因素,以NS的产品为例,其计算公式如下——
【图片展示】
Electrical Characteristics 电气特性 (MC7808)(LM7808)
(参照测试电路 ,0℃ < TJ < 125℃ , IO =500mA, VI =14V, CI=0.33ìF, CO=0.1ìF, 除非另有说明)
Parameter 参数 | Symbol 符号 | Conditions 条件 | LM7808 | 单位 | |||
最小 | 典型 | 最大 | |||||
Output Voltage 输出电压 | VO | TJ =+25℃ | 7.7 | 8.0 | 8.3 | V | |
5.0mA ≤ IO ≤ 1.0A, PO ≤ 15W VI =10.5V to 23V | 7.6 | 8.0 | 8.4 | ||||
Line Regulation 线性调整率 (Note1) | Regline | TJ =+25℃ | VI =10.5V to 25V | - | 5.0 | 160 | mV |
VI =11.5V to 17V | - |
2.0 | 80 | ||||
Load Regulation 负载调整率 (Note1) | Regload | TJ =+25℃ |
IO =5.0mA to 1.5A |
- | 10 | 160 | mV |
IO=250mA to 750mA | - | 5.0 | 80 | ||||
Quiescent Current 静态电流 | IQ | TJ =+25℃ | - | 5.0 | 8.0 | mA | |
Quiescent Current Change 静态电流变化 | ΔIQ | IO =5mA to 1.0A | - | 0.05 | 0.5 | mA | |
VI =10.5A to 25V | - | 0.5 | 1.0 | ||||
Output Voltage Drift 输出电压漂移 | ΔVO/ΔT | IO=5mA | - | -0.8 | - | mV/℃ | |
Output Noise Voltage 输出噪声电压 | VN | f =10Hz to 100KHz, TA =+25℃ | - | 52 | - | μV/Vo | |
Ripple Rejection 纹波抑制 | RR | f =120Hz, VI=11.5V to 21.5V | 56 | 73 | - | dB | |
Dropout Voltage 电压差 | VDrop | IO =1A, TJ=+25℃ | - | 2 | - | V | |
Output Resistance 输出电阻 | rO | f=1KHz | - | 17 | - | mΩ | |
Short Circuit Current 短路电流 | ISC | VI=35V, TA =+25℃ | - | 230 | - | mA | |
Peak Current 峰值电流 | IPK | TJ =+25℃ | - | 2.2 | - | A |
三端稳压集成电路极限参数:
Parameter 参数 | Symbol 符号 | Value | 单位 | |
Input Voltage输入电压 | (for VO =5V to 18V) | VI | 35 | V |
(for VO =24V) | VI | 40 | V | |
Thermal Resistance Junction-Cases热阻(结到壳) (TO-220) | RθJC | 5 | ℃/W | |
Thermal Resistance Junction-Air热阻(结到空气) (TO-220) | RθJC | 65 | ℃/W | |
Operating Temperature Range工作温度范围 | TOPR | 0~+125 | ℃ | |
Storage Temperature Range储存温度范围 | TSTG | -65~+150 | ℃ |
图1 LM7808内部电路图
图2 LM7808参照测试电路 图3 外形引脚排列图管脚图
图4 文波抑制电路
图5 负载调节控制电路
图6 典型应用电路
图7 TO-220封装图
