[LaunchPad] user guide 中文版用户指南向导 006 翻译slau144i
ppiicc   2012-11-24 17:37 楼主
9.2.2
SVS Comparator Operation .比较器 操作 . ................................ 345
9.2.3
Changing the VLDx Bits ............. ...................................... 345
9.2.4
SVS Operating Range .经营范围 ................................... 346
9.3
SVS Registers .向量寄存器 ............ ........ 347
9.3.1
SVSCTL, SVS Control Register ............. ............................. 348
Watchdog Timer+ (WDT+) .看门狗定时器 ............................................. 349
10.1
Watchdog Timer+ (WDT+) Introduction ............. ............................. 350
10.2
Watchdog Timer+ Operation ............. ......................................... 352
10.2.1 Watchdog Timer+ Counter .定时器和计数器 ............................ 352
10.2.2 Watchdog Mode ............. .............................................. 352
10.2.3 Interval Timer Mode ............. ......................................... 352
10.2.4 Watchdog Timer+ Interrupts ............. ................................ 352
10.2.5 Watchdog Timer+ Clock Fail-Safe Operation
看门狗定时器时钟故障安全操作  ............. ............ 353
10.2.6 Operation in Low-Power Modes ............. ........................... 353
10.2.7 Software Examples ....软件的例子. .................................. 353
10.3
Watchdog Timer+ Registers ............. .......................................... 354
10.3.1 WDTCTL, Watchdog Timer+ Register ............. .................... 355
10.3.2 IE1, Interrupt Enable Register 1 ..中断使能寄存器 ................... 356
10.3.3 IFG1, Interrupt Flag Register 1 ...中断标志寄存器 ............. 356
Hardware Multiplier 硬件乘法器 ........ ...... 357
11.1
Hardware Multiplier Introduction ............. ..................................... 358
11.2
Hardware Multiplier Operation ............. ........................................ 358
11.2.1 Operand Registers ..操作数寄存器 ................................... 359
11.2.2 Result Registers .....结果寄存器   返回................................. 359
11.2.3 Software Examples ............. .......................................... 360
11.2.4 Indirect Addressing of RESLO .间接寻址 ......................... 361
11.2.5 Using Interrupts ............. .............................................. 361
11.3
Hardware Multiplier Registers ......寄存器 ........................................ 362
Timer_A ............. ............. ...................... 363
12.1
Timer_A Introduction ............. .............  364
12.2
Timer_A Operation ............. ............. ... 365
12.2.1 16-Bit Timer Counter .....16位定时器计数器 .......................... 365
12.2.2 Starting the Timer ............. ............................................ 366
12.2.3 Timer Mode Control ............. ......................................... 366
12.2.4 Capture/Compare Blocks 捕获/比较块 ............................. 370
12.2.5 Output Unit ..输出单元     ........... ............. .. 371
12.2.6 Timer_A Interrupts ......中断 ....... ........................................... 375
12.3
Timer_A Registers ............. ............. ... 377
12.3.1 TACTL, Timer_A Control Register ............. ......................... 378
12.3.2 TAR, Timer_A Register ............. ..................................... 379
12.3.3 TACCRx, Timer_A Capture/Compare Register x ..... 捕获/比较寄存器 ....... 379
12.3.4 TACCTLx,            Capture/Compare Control Register ...控制.. ... .......... 380
12.3.5 TAIV, Timer_A     Interrupt Vector Register .......中断向量寄存器 .......... 381
Timer_B ............. ............. ...................... 383
13.1
Timer_B Introduction ............. .............  384
13.1.1 Similarities and Differences From Timer_A ............. .............. 384
13.2
Timer_B Operation ............. ............. ... 386
13.2.1 16-Bit Timer Counter ............. ........................................ 386
13.2.2 Starting the Timer ............. ............................................ 386
13.2.3 Timer Mode Control ............. ......................................... 386
13.2.4 Capture/Compare Blocks ............. ................................... 390
13.2.5 Output Unit ............. ............. .. 393
[ 本帖最后由 ppiicc 于 2012-11-24 18:37 编辑 ]
回复评论
暂无评论,赶紧抢沙发吧
    写回复
