[求助] 单片机语音温度计怎么加整点报温
lwr1988   2012-11-27 10:22 楼主
////////语音播报子程序
#define __ISD1420_H__
#include "main.h"
#include "clock.h"
#include"lcd1602.h"
#define ISD1420IO P1   //播音地址端口
sbit playe = P3^0;    //开始播音口
extern const unsigned char speak_world[];
void speak_isd1420(unsigned char addr);
#include "ISD1420.h"
const unsigned char speak_world[]={0x00,0x00,0x08,0x10,0x18,0x20,0x28,0x30,0x38,0x40,0x48,0x50,0x58};
//const unsigned char speak_world1[]={0x00,0x00,0x08,0x10,0x18,0x20,0x28,0x30,0x38,0x40,0x48,0x50,0x58};
/*********延时K*1ms,12.000mhz**********/
void delay_ISD1420(unsigned int ms)
{   int j;
while(ms--)
  for(j=0; j<125; j++);
/*********语音播报子程序 addr播音地址**********/
ISD1420IO = addr;       //写地址
            {  playe = 1;
             playe=0;      //开始播音
delay_ISD1420(600);
////语音播报温度子程序
#include "speakTEMP.h"
void delay(unsigned int ms)
{   int j;
while(ms--)
/*********语音播报温度子程序**********/
void speak_temp(unsigned int temp_t){
int digit1,digit0;
    digit1 = temp_t / 10;  //十位
digit0 = temp_t % 10;  //个位
  speak_isd1420(speak_world[12]);//当前温度是
   delay(600);
if(digit1==0){
  speak_isd1420(speak_world[digit0]);
  speak_isd1420(speak_world[11]);
else{
   speak_isd1420(speak_world[digit1]);
  speak_isd1420(speak_world[10]);   //播十
  if(digit0!=0)
  speak_isd1420(speak_world[11]);   //播度
/////时钟程序
#include "clock.h"
unsigned char seconde=0;                 //定义并初始化时钟变量
unsigned char minite=0;
unsigned char hour=12;
unsigned char mstcnt=0;
unsigned char code str0[]={"time:  :  :        "};
/***************定时器t0初始化*******************/
void initClock(void)
seconde=0;
minite=0;
hour=12;
mstcnt=0;
initLCM( );
  TMOD=0x01;              //time0为定时器,方式1
  TCON = 0x01 ;   //触发方式为脉冲负边沿触发
     TH0=0x3c;               //预置计数初值
     TL0=0xb0;
     EA=1;
     ET0=1;
     TR0=1;
     EX0=1;
/***************液晶显示子函数1正常显示*****************/
void displayClock(void)
WriteCommandLCM(0x0c,1);         //显示屏打开,光标不显示,不闪烁,检测忙信号
DisplayListChar(0,0,str0);
DisplayOneChar(5,0,hour/10+0x30);
DisplayOneChar(6,0,hour%10+0x30);
DisplayOneChar(8,0,minite/10+0x30);
DisplayOneChar(9,0,minite%10+0x30);
DisplayOneChar(11,0, seconde/10+0x30);
DisplayOneChar(12,0,seconde%10+0x30);
/***********定时器t0中断子函数**************/
void timer0(void) interrupt 1 using 0         //定时器0方式1,50ms中断一次
   TH0=0x3c;
     TL0=0xb0;
     mstcnt++;
     if(mstcnt>=20 )  {seconde++; mstcnt=0;  }
  if(seconde>=60)  {minite++;  seconde=0;}
  if(minite>=60 )  {hour++;    minite=0; }
  if(hour>=24   )  {hour=0;}
这是手动报温,我想设置整点报温,当到每一个整点时,他就会自动报温
回复评论 (5)
都不介绍你用什么单片机和什么型号的语音芯片
QQ:2213825928 语音芯片、模块。串口MP3芯片、模块 http://mk020.taobao.com
点赞  2012-11-27 11:58
用的是ISD1420语音芯片吧
点赞  2012-11-27 13:45
回复 沙发 iushiyuan 的帖子
是51单片机,语音芯片是ISD1420
点赞  2012-11-28 19:26
语音芯片里面存储需要用到的各种语音。
等时钟走到整点的时候。读出温度值,并根据温度值指向语音芯片相应语音提示的位置
点赞  2012-11-28 22:24
点赞  2012-11-29 13:43
    写回复
