[求助] launchpad 有关ADC10的问题
zlcchina   2012-11-28 21:19 楼主
#include  "msp430g2553.h"
void main(void)
  WDTCTL = WDTPW + WDTHOLD;                 // Stop WDT
  ADC10CTL1 = CONSEQ_2+INCH_1;              // Repeat single channel
  ADC10CTL0 = SREF_1 + ADC10SHT_2 + MSC + REFON + ADC10ON + ADC10IE;
  __enable_interrupt();                     // Enable interrupts.
  TACCR0 = 30;                              // Delay to allow Ref to settle
  TACCTL0 |= CCIE;                          // Compare-mode interrupt.
  TACTL = TASSEL_2 + MC_1;                  // TACLK = SMCLK, Up mode.
  LPM0;                                     // Wait for delay.
  TACCTL0 &= ~CCIE;                         // Disable timer Interrupt
  __disable_interrupt();
  ADC10DTC1 = 0x20;                         // 32 conversions
  ADC10AE0 |= 0x02;                         // P1.1 ADC option select
  P1DIR |= 0x01;                            // Set P1.0 output
  for (;;)
    ADC10CTL0 &= ~ENC;
    while (ADC10CTL1 & BUSY);               // Wait if ADC10 core is active
    ADC10SA = 0x200;                        // Data buffer start
    P1OUT |= 0x01;                          // Set P1.0 LED on
    ADC10CTL0 |= ENC + ADC10SC;             // Sampling and conversion start
    __bis_SR_register(CPUOFF + GIE);        // LPM0, ADC10_ISR will force exit
    P1OUT &= ~0x01;                         // Clear P1.0 LED off
// ADC10 interrupt service routine
#pragma vector=ADC10_VECTOR
__interrupt void ADC10_ISR(void)
  __bic_SR_register_on_exit(CPUOFF);        // Clear CPUOFF bit from 0(SR)
#pragma vector=TIMER0_A0_VECTOR
__interrupt void ta0_isr(void)
  TACTL = 0;
  LPM0_EXIT;                                // Exit LPM0 on return
有如下问题:
(1)以上程序中
在整个程序中的作用是什么?
(2)为什么有TACCTL0 &= ~CCIE;                         // Disable timer Interrupt
                      __disable_interrupt();这两句?
回复评论
暂无评论,赶紧抢沙发吧
    写回复
