[讨论] 求助!ccs与目标板连接连接不上
木槿豆豆   2013-1-7 16:56 楼主
我自己做了一块dsp28016的最小系统,测得电压、时钟信号都是正常的,用的仿真器是spectrum digital 510LC usb
每次连接报错是:
Error connecting to the target:
Error 0x80000200/-1135
Fatal Error during: OCS,
Unrecoverable emulation error
I/O Port = 510
Board Name: F2808 XDS510USB Emulator
Cpu Name: cpu_0
Abort:  Close Code Composer Studio.
Retry:  Try to connect to the target again.
Cancel:  Remain disconnected from the target
Diagnostic: Run diagnostic utility.
接上仿真器后,测JTAG的TRST一直为低,TCK没有脉冲 TMS为3.28V。
请高手们指点是什么原因?
回复评论 (2)
不要沉贴啊!!!
求助求助!!!
点赞  2013-1-8 08:38
有新进展,测硬件后发现EMU0和EMU1被我接反了,现在以调整过来,但也出现新问题,报错如下:
Error 0x00000024/-1137
Error during: Register, Execution,
It appears that the target is being held in reset.  This may be
due to Wait-In-Reset (WIR) configuration set by the EMU0=0
and EMU1=1 pin settings.  If this is the case, DISCONNECT
all CONNECTED devices including icepick and then select
RETRY to clear the WIR configuration.
If this is a multi-core system, the master CPU may not be
releasing the DSP/MCU from reset.  Please check your
configuration in CC_setup and/or your GEL file to ensure that
nothing is blocking the DSP/MCU from being released from reset
I/O Port = 510
Cpu Name: cpu_0
点赞  2013-1-8 15:36
    写回复
