【玩转C2000 Launchpad】驱动TFT真彩屏
ddllxxrr   2013-1-11 21:03 楼主
由于真彩屏管脚比较多,故选用SPI驱动的真彩屏。我手头上有智林的真彩屏。今天晚上回来点了下居然亮了。
保险起见我也用了模似SPI驱动,其管脚定义如下:
#define clr_RST  GpioDataRegs.GPADAT.bit.GPIO4 = 0
#define set_RST  GpioDataRegs.GPADAT.bit.GPIO4 = 1
#define clr_CS  GpioDataRegs.GPADAT.bit.GPIO5 = 0
#define set_CS  GpioDataRegs.GPADAT.bit.GPIO5 = 1
#define clr_SDO  GpioDataRegs.GPADAT.bit.GPIO6 = 0 //PORTB &= ~0x02
#define set_SDO  GpioDataRegs.GPADAT.bit.GPIO6 = 1 // PORTB |= 0x02
#define clr_CLK  GpioDataRegs.GPADAT.bit.GPIO7 = 0
#define set_CLK  GpioDataRegs.GPADAT.bit.GPIO7 = 1
也就是说这款TFT真彩屏我只用了四根线就驱动起来了。当然再加上地和3.3V电源共六根线。
工程也很简单:我把同TFT所有文件都放在TFT子录中。
以下是LCD的主要函数:
//测试系统
//芯片:F28027
//电压:3.3V
#include "DSP28x_Project.h"     // Device Headerfile and Examples Include File
#include"LCD.h"
/* LCD Registers */
volatile unsigned char Font=0;
//颜色数值
//红色,绿色,蓝色,黄色,黑色,白色,天蓝色,紫色
uint color[]={0xF800,0x07E0,0x001F,0xFFE0,0x0000,0xFFFF,0x07FF,0xF81F};
void _delay_ms(unsigned char x)
     unsigned char i;
  for(i=0;i   ;
    I/O口初始化
void LCD_IO_Init()
clr_RST;
_delay_ms(100); // _delay_ms 50ms
set_RST;
void SPI_OutB(unsigned char dat)
clr_SDO;
   if(dat & 0x80)set_SDO;
   clr_CLK ;
   set_CLK ;
    clr_SDO;
   if(dat & 0x40)set_SDO;
   clr_CLK ;
   set_CLK ;
   clr_SDO;
   if(dat & 0x20)set_SDO;
   clr_CLK ;
   set_CLK ;
   clr_SDO;
   if(dat & 0x10)set_SDO;
   clr_CLK ;
   set_CLK ;
clr_SDO;
if(dat & 0x8)set_SDO;
clr_CLK ;
set_CLK ;
clr_SDO;
if(dat & 0x4)set_SDO;
clr_CLK ;
set_CLK ;
clr_SDO;
if(dat & 0x2)set_SDO;
clr_CLK ;
set_CLK ;
clr_SDO;
if(dat & 0x1)set_SDO;
clr_CLK ;
set_CLK ;
//发送命令给液晶
void send_comand(unsigned char cmd)
clr_CS;
SPI_OutB(0x70);
SPI_OutB(0x00);
SPI_OutB(cmd);
set_CS;
//发送字数据给液晶
void send_data(uint16 dat)
clr_CS;
SPI_OutB(0x72);
SPI_OutB(dat>>8);
SPI_OutB(dat);
set_CS;
//发送命令和数据
void send_com(unsigned char cmd,unsigned int dat)
    send_comand(cmd);
    send_data(dat);
void LCD_Init_ZL(void)
    //************* Start Initial Sequence **********//
  send_com(0x00E7, 0x0010); // Set internal timing
  send_com(0x0000, 0x0001); // Start Oscillation
  //send_com(0x0001, 0x0100); // set SS and SM bit
  send_com(0x0001, 0x0000); // set SS and SM bit
  send_com(0x0002, 0x0700); // set 1 line inversion
  send_com(0x0003, (1<<12)|(1<<5)|(1<<4)|(1<<3) ); // 65K
  send_com(0x0004, 0x0000); // Resize register
  send_com(0x0008, 0x0207); // set the back porch and front porch
  send_com(0x0009, 0x0000); // set non-display area refresh cycle ISC[3:0]
  send_com(0x000A, 0x0000); // FMARK function
  send_com(0x000C, 0x0001); // RGB interface setting: 16 bit
  send_com(0x000D, 0x0000); // Frame marker Position
  send_com(0x000F, 0x0000); // RGB interface polarity
  //*************Power On sequence ****************//
  send_com(0x0010, 0x0000); // SAP, BT[3:0], AP, DSTB, SLP, STB
  send_com(0x0011, 0x0007); // DC1[2:0], DC0[2:0], VC[2:0]
  send_com(0x0012, 0x0000); // VREG1OUT voltage
    _delay_ms(50);                         // _delay_ms 50ms
  send_com(0x0013, 0x0000); // VDV[4:0] for VCOM amplitude
    _delay_ms(200);                         // _delay_ms 50ms
  send_com(0x0010, 0x1590); // SAP, BT[3:0], AP, DSTB, SLP, STB
  send_com(0x0011, 0x0227); // R11h=0x0221 at VCI=3.3V, DC1[2:0], DC0[2:0], VC[2:0]
  send_com(0x0012, 0x009C); // External reference voltage= Vci;
  send_com(0x0013, 0x1900); // VDV[4:0] for VCOM amplitude
  send_com(0x0029, 0x0023); // VCM[5:0] for VCOMH
  send_com(0x002B, 0x000E); // Frame Rate = 40Hz
  send_com(0x0020, 0x0000); // GRAM horizontal Address
  send_com(0x0021, 0x0000); // GRAM Vertical Address
  // ----------- Adjust the Gamma Curve ----------//
  send_com(0x0030, 0x0007);
  send_com(0x0031, 0x0707);
  send_com(0x0032, 0x0006);
  send_com(0x0035, 0x0704);
  send_com(0x0036, 0x1F04);
  send_com(0x0037, 0x0004);
  send_com(0x0038, 0x0000);
  send_com(0x0039, 0x0706);
  send_com(0x003C, 0x0701);
  send_com(0x003D, 0x000F);
  //------------------ Set GRAM area ---------------//
  send_com(0x0050, 0x0000); // Horizontal GRAM Start Address
  send_com(0x0051, 0x00EF); // Horizontal GRAM End Address
  send_com(0x0052, 0x0000); // Vertical GRAM Start Address
  send_com(0x0053, 0x013F); // Vertical GRAM Start Address
  send_com(0x0060, 0xA700); // Gate Scan Line
  //send_com(0x0060, 0x2700); // Gate Scan Line
  send_com(0x0061, 0x0001); // NDL,VLE, REV
  send_com(0x006A, 0x0000); // set scrolling line
  //-------------- Partial Display Control ---------//
  send_com(0x0080, 0x0000);
  send_com(0x0081, 0x0000);
  send_com(0x0082, 0x0000);
  send_com(0x0083, 0x0000);
  send_com(0x0084, 0x0000);
  send_com(0x0085, 0x0000);
  //-------------- Panel Control -------------------//
  send_com(0x0090, 0x0010);
  send_com(0x0092, 0x0000);
  send_com(0x0093, 0x0003);
  send_com(0x0095, 0x0110);
  send_com(0x0097, 0x0000);
  send_com(0x0098, 0x0000);
  //----------------- display ON -------------------//
  send_com(0x0007, 0x0133); // 262K color and display ON
    LCD初始化函数
void LCD_Init()
    LCD_IO_Init();
    send_com(0x00E3, 0x3008); // Set internal timing
    send_com(0x00E7, 0x0012); // Set internal timing
    send_com(0x00EF, 0x1231); // Set internal timing
    //send_com(0x0003, 0x1030); // set GRAM write direction and BGR=1.
    send_com(0x0003, 0x1038); // set GRAM write direction and BGR=1.
    send_com(0x0008, 0x0202); // set the back porch and front porch
    send_com(0x000C, 0x0000); // RGB interface setting
    _delay_ms(100); // Dis-charge capacitor power voltage
    send_com(0x0010, 0x1690); // SAP, BT[3:0], AP, DSTB, SLP, STB
    _delay_ms(10); // _delay_ms 50ms
    send_com(0x0012, 0x001C); // External reference voltage= Vci;
    send_com(0x0013, 0x1800); // R13=1200 when R12=009D;VDV[4:0] for VCOM amplitude
    send_com(0x0029, 0x001C); // R29=000C when R12=009D;VCM[5:0] for VCOMH
    send_com(0x002B, 0x000D); // Frame Rate = 91Hz
//    send_com(0x0020, 0x0000); // GRAM horizontal Address
//    send_com(0x0021, 0x0000); // GRAM Vertical Address
    send_com(0x0030, 0x0204);
    send_com(0x0031, 0x0507);
    send_com(0x0032, 0x0204);
    send_com(0x0035, 0x0107);
    send_com(0x0036, 0x0207);
    send_com(0x0037, 0x0305);
    send_com(0x0038, 0x0002);
    send_com(0x0039, 0x0305);
    send_com(0x003D, 0x060A);
//    set_CS;
//设置液晶显示位置
void ram_addr(unsigned int x,unsigned int y)
    send_com(0x0020,x);        //行地址
    send_com(0x0021,y);        //列地址
    send_comand(0x22);
//全屏幕显示一种颜色
void Full_display(unsigned int color)
uint j;
uint8 i;
// clr_CS;
ram_addr(0,0);
//send_comand(0x22);
for(j=0;j<320;j++)
   for(i=0;i<240;i++)
     send_data(color);
  // _delay_ms(10);
// set_CS;
//测试程序
//彩色测试
void LCD_test()
| LCD_SetCursor  : Sets the cursor position.                                  |
| Input          : - Xpos: specifies the X position.                          |
|                  - Ypos: specifies the Y position.                          |
void LCD_SetCursor(unsigned short Xpos, unsigned short Ypos)
  send_com(R33, Xpos);
send_com(R32, Ypos);
| LCD_SetArea  : Sets a display window                                        |
void LCD_SetArea( unsigned short x0, unsigned short y0, unsigned short x1, unsigned short y1 ) {
  LCD_SetCursor(x0, y0);
  /* Horizontal GRAM Start Address */
send_com(R80, y0);
  /* Horizontal GRAM End Address */
send_com(R81, y1);
  /* Vertical GRAM Start Address */
send_com(R82, x0);
  /* Vertical GRAM End Address */
send_com(R83, x1);
| LCD_RectangleFill  : Displays a rectangle filled                            |
void LCD_RectangleFill( unsigned short x0, unsigned short y0, unsigned short x1, unsigned short y1, unsigned short Color ) {
  int x,y;
  LCD_SetArea(x0,y0,x1,y1);
  send_comand( R34 ); /* Prepare to write GRAM */
  for(x=0;x<=x1-x0;x++)
    for(y=0;y<=y1-y0;y++)
   send_data( Color );
| LCD_Clear    : Clears the hole LCD.                                         |
void LCD_Clear_Screen( unsigned short Color ) {
  LCD_RectangleFill( 0,0, 319,239, Color );
| LCD_SetPixel  : Displays a pixel.                                           |
void LCD_SetPixel( unsigned short x, unsigned short y, unsigned short Color ) {
  LCD_SetArea(x,y,x,y);
  send_data( Color );
| LCD_PutChar8x16  : Displays a 8x16 pixel charactor                          |
#include "8X16.h"
void LCD_PutChar8x16(unsigned short x, unsigned short y, char c, unsigned int f, unsigned int b) {
  register unsigned int i,j;
  LCD_SetArea(x,y,x+8-1,y+16-1);
  send_comand( R34 );
  for(i=0; i<16;i++) {
    unsigned char m=Font8x16[c*16+i];
    for(j=0;j<8;j++) {
      if((m&0x80))
        send_data( f );
      else
        send_data( b );
      m<<=1;
| LCD_PutChar8x8  : Displays a 8x8 pixel charactor                            |
#include "8X8h.h"
void LCD_PutChar8x8(unsigned short x, unsigned short y, char c, unsigned int f, unsigned int b) {
  LCD_SetArea(x,y,x+8-1,y+8-1);
  for(i=0; i<8;i++) {
    unsigned char m=Font8x8[c];
    for(j=0;j<8;j++) {
      if((m&0x80))
        send_data( f );
      else
        send_data( b );
      m<<=1;
| LCD_PutGB1616  : Displays a Chinese charactor use small libary              |
#include "GB1616.h" //16*16汉字字模
void LCD_PutGB1616(unsigned short x, unsigned short  y, unsigned char c[2], unsigned int f,unsigned int b){
  unsigned int i,j,k;
  LCD_SetArea(x, y, x+16-1, y+16-1);
  send_comand( R34 );
  for (k=0;k<70;k++) {
    if ((codeGB_16[k].Index[0]==c[0])&&(codeGB_16[k].Index[1]==c[1])){
      for(i=0;i<32;i++) {
        unsigned short m=codeGB_16[k].Msk;
        for(j=0;j<8;j++) {
        if((m&0x80)==0x80)
          send_data( f );
        else
          send_data( b );
          m<<=1;
| LCD_PutChar  : Displays a charactor on Font                                 |
void LCD_PutChar(unsigned short x, unsigned short y, char c, unsigned int f, unsigned int b) {
if( Font )
  LCD_PutChar8x8( x, y, c, f, b );
//else
  //LCD_PutChar8x16( x, y, c, f, b );
| LCD_PutString  : Displays a string                                          |
void LCD_PutString(unsigned short x, unsigned short y, char *s, unsigned int f, unsigned int b) {
register unsigned char l=0;
while(*s) {
  if( *s < 0x80 ) {
   LCD_PutChar(x+l*8,y,*s,f,b);
   s++;l++;
  //else {
   //LCD_PutGB1616(x+l*8,y,(unsigned char *)s,f,b);
   //s+=2;l+=2;
| END OF FILE                                              |
我这次显示8*8的小字,下次想显示汉字。
以下是视频及照片:
上工程,这个工程可以在FLASH中执行
newlcdproj.rar (496.04 KB)
(下载次数: 61, 2013-1-11 21:07 上传)
[ 本帖最后由 ddllxxrr 于 2013-1-11 21:07 编辑 ]
http://shop34182318.taobao.com/ https://shop436095304.taobao.com/?spm=a230r.7195193.1997079397.37.69fe60dfT705yr
回复评论 (10)
楼主幸运啊,有个现成的板子。
我焊板子焊得心慌。就这,来回焊了四次,0.8间距的,还要引出那么多线,累啊。不过,现在搞得基本可以了。
俺那是并口的,没有SPI,要是有,就简单了。
点赞  2013-1-11 21:11
恩,有货就是好
[ 本帖最后由 ddllxxrr 于 2013-1-11 21:19 编辑 ]
点赞  2013-1-11 21:17
这个液晶的驱动芯片是什么?
点赞  2013-1-11 22:44
回复 4楼 IC爬虫 的帖子
ILI9325
点赞  2013-1-12 09:58
感觉还是我们家的做的比较好,嘿嘿。
http://item.taobao.com/item.htm?id=20861955853
你们瞄下。
点赞  2013-6-10 16:04
回复 6楼 ken_kc1986 的帖子
不要单纯地在这里做广告,贬低别人更不好。
你那是搞商业开发的,我们这是学习的。
再说了,只要知道原理,具体怎么搞还不是小菜?
你搞的51机驱动TFT,你自己觉得合适吗?????????,CPU的主要时间在做什么?显示图片的刷新率有多高??????
[ 本帖最后由 dontium 于 2013-6-12 00:38 编辑 ]
点赞  2013-6-12 00:36
引用: 原帖由 ken_kc1986 于 2013-6-10 16:04 发表
感觉还是我们家的做的比较好,嘿嘿。
你们瞄下。
希望ken_kc1986 引以为戒。
加油!在电子行业默默贡献自己的力量!:)
点赞  2013-6-13 10:04
赞一个,看着很心动,打算入手一块,也玩玩TFT
点赞  2013-6-13 14:33
回复 板凳 ddllxxrr 的帖子
你好,我想请问一下你的液晶模块是带有字库的TFT是吗?
如果不是,那你的字库怎样解决,F28027的内存很小,对于大字库支持不了呀。
点赞  2013-6-18 18:25
回复 10楼 liuming759 的帖子
不带字库,自己做字库,以数组放CODE中的
点赞  2013-6-19 11:43
    写回复
