TI的UART源代码例子感觉用不了
纹身灬猎人   2013-1-22 09:47 楼主
//   MSP430F5438 Demo - USCI_A0, 9600 UART, SMCLK, LPM0, Echo with over-sampling
//   Description: Echo a received character, RX ISR used. Normal mode is LPM0.
//   USCI_A0 RX interrupt triggers TX Echo.
//   If UCOS16=1, UCBRx=Fbrclk/(16*Baudrate)
//   Baud rate divider with UCBRx = 1MHz/(16*9600) = ~6.8
//   ACLK = REFO = ~32768Hz, MCLK = SMCLK = default DCO = 32 x ACLK = 1048576Hz
//   See User Guide for baud rate divider table
//                MSP430F5438
//          --|RST              |
//            |     P3.4/UCA0TXD|------------>
//            |                 | 9600 - 8N1
//            |     P3.5/UCA0RXD|<------------
//   M Smertneck / W. Goh
//   Texas Instruments Inc.
//   September 2008
//   Built with CCE Version: 3.2.2 and IAR Embedded Workbench Version: 4.11B
#include "msp430x54x.h"
unsigned char x;
void main(void)
  WDTCTL = WDTPW + WDTHOLD;                 // Stop WDT
  P3SEL = 0x30;                             // P3.4,5 = USCI_A0 TXD/RXD
  UCA0CTL1 |= UCSWRST;                      // **Put state machine in reset**
  UCA0CTL1 |= UCSSEL_2;                     // SMCLK
  UCA0BR0 = 6;                              // 1MHz 9600 (see User's Guide)
  UCA0BR1 = 0;                              // 1MHz 9600
  UCA0MCTL = UCBRS_0 + UCBRF_13 + UCOS16;   // Modln UCBRSx=0, UCBRFx=0,
                                            // over sampling
  UCA0CTL1 &= ~UCSWRST;                     // **Initialize USCI state machine**
  UCA0IE |= UCRXIE;                         // Enable USCI_A0 RX interrupt
  __bis_SR_register(LPM0_bits + GIE);       // Enter LPM0, interrupts enabled
  __no_operation();                         // For debugger
// Echo back RXed character, confirm TX buffer is ready first
#pragma vector=USCI_A0_VECTOR
__interrupt void USCI_A0_ISR(void)
  switch(__even_in_range(UCA0IV,4))
  case 0:break;                             // Vector 0 - no interrupt
  case 2:                                   // Vector 2 - RXIFG
    while (!(UCA0IFG&UCTXIFG));             // USCI_A0 TX buffer ready?
    UCA0TXBUF = UCA0RXBUF;                  // TX -> RXed character
    break;
  case 4:                            // Vector 4 - TXIFG
  break;
  default: break;
按照里面所说,应该是PC机发送什么就是应该返回什么,但是程序烧完,也是出不来,出来也是乱码,          作为新手头痛啊!
回复评论 (8)
#include
#define uint  unsigned int
#define uchar unsigned char
int k,i;
uchar temp,sendchar,receivechar;
unsigned char UCA3Read()
    while (!(UCA3IFG&UCRXIFG));
    return UCA3RXBUF;
void UCA3Write(  unsigned char sendchar)
  while (!(UCA3IFG&UCTXIFG));
    UCA3TXBUF = sendchar;
void main()
    WDTCTL = WDTPW + WDTHOLD; // 关闭看门狗
    P5DIR |= BIT4;
    P5SEL|= (BIT2+BIT3); // 端口功能选择外部晶振XT2=24MHz
    UCSCTL6 &= ~XT2OFF ; // XT2振荡器使能
    UCSCTL6 |= XT2DRIVE0 + XT2DRIVE1  ; // XT2 最大驱动模式 24~32MHz
    UCSCTL3 |= SELREF_2; //FLLREFCLK =REFOCLK  .且FLLREFCLK不分频
    UCSCTL4 |= (SELA__REFOCLK+SELM__XT2CLK+SELS__XT2CLK); // ACLK=REFO,SMCLK=XT2,MCLK=XT2
    do
      UCSCTL7 &= ~(XT2OFFG + XT1LFOFFG + XT1HFOFFG + DCOFFG); // 清除 XT2,XT1,DCO 错误标志
      SFRIFG1 &= ~OFIFG ; //清除晶振失效中断标志
    }while(SFRIFG1&OFIFG);// 检测振荡器错误标志
    UCA3CTL1|=UCSWRST; // 使能关闭状态机。USCI在复位后逻辑电平保持不变
    P10SEL|= 0X30; // 选择引脚功能0x30
    P10DIR|= 0X10 ; // 选择引脚功能
    UCA3CTL1|= UCSSEL__SMCLK ; // UART_CLK = SMCLK
    UCA3BR0= 0x0d ;  //粗调波特率控制寄存器0(UCA3BRx的低八位)9600
    UCA3BR1=0x00 ;  //粗调波特率控制寄存器0(UCA3BRx的高八位)
    UCA3MCTL|=(UCBRS_0 + UCBRF_3+UCOS16); // UCBRSx=0, UCBRFx=3  UCOS16=1过采样模式使能
    UCA3CTL1&= ~UCSWRST  ; // 启动状态机
     while(1)
         receivechar = UCA3RXBUF;
         UCA3TXBUF = 0x55;
         for( i = 8000; i > 0; i--);
    UCA3TXBUF = receivechar;
    break;
  case 4:
    break;
  default: break;
修改了一下,懵懵懂懂的,参照TI及一些厂家的程序,这个又可以用,   而且关于那TXD与RXD的定义,定义在P10却是接在P5.4,5可以正常运行
点赞  2013-1-22 10:23
有修改了一个,但是无法进行收发,在12864液晶上显示,从PC机接收到的也是不准确的...
//                 MSP430F5438
//          --|RST              |
//            |                 | 9600 - 8N1
#include
#include "LCD12864.h"
#include "XT2.h"
#include "key_4_4.h"
#define CPU_F ((double)8000000)
#define delay_us(x) __delay_cycles((long)(CPU_F*(double)x/1000000.0))
#define delay_ms(x) __delay_cycles((long)(CPU_F*(double)x/1000.0))
#define ulong unsigned long
unsigned char Key_Val;  //存放键值
uchar dat;
void max232()           //max232串口设置
  P3SEL = 0x30;                   //P3.4/P3.5 = USCI_A0 TXD/RXD
  UCA0CTL1 |= UCSWRST;            //要在UCSWRST=1的情况下设置串口
  UCA0CTL1 |= UCSSEL__SMCLK;      //选择SMCLK=1.5MHz
  UCA0BR0 = 0x9c;                    // 1.5MHz/9600=156.25=0x009c
  UCA0BR1 = 0x00;
  UCA0MCTL |= UCBRS_2 + UCBRF_0;    //0.25*8≈2,波特率调整
  UCA0CTL1 &= ~UCSWRST;             //初始化UART状态机
//  UCA0IE |= UCRXIE+UCTXIE;        //使能USART0 TXD/RXD
void key_P1()              //P1.0,P1.1独立键盘
  if((P1IN&0x0f)==0x02)
    delay_ms(5);
      P1OUT=BIT4;
      UCA0IE |= UCTXIE;         //(UCTxIE 置1 和UCRxIE 置 0)开发送中断,关闭收中断
    while((P1IN&0x0f)==0x02);
  if((P1IN&0x0f)==0x01)
    delay_ms(5);
      P1OUT=BIT5;
      UCA0IE|= UCRXIE;         //(UCTxIE 置0 和UCRxIE 置 1)关闭发送中断,开接收中断
    while((P1IN&0x0f)==0x01);
void main(void)
  // Stop watchdog timer to prevent time out reset
  initsys();//TX2时钟初始化
  max232(); //max232串口设置
  P9DIR|=0xff;
  P9OUT =0xff;
  P8DIR|=0xff;
  P8OUT =0xff;
  P2DIR=0xf0;//按键接口设置P2.0-P2.3 为输入方向
  P2OUT|=0xf0;
  P1DIR=0xfC;//P1.0,P1.1为独立键盘
  LCD_Init();    //LCD12864初始化
  diaply();      //数据显示
   _EINT();//打开全局中断
  while(1)
    key_P1();     //P1.0,P1.1独立键盘
    key_display();//按键值显示
  // Vector 2 - RXIFG
  case 2:
          dat = UCA0RXBUF;    //接收数据
          LCD_WriteComm(0x8D);//写命令
          LCD_WriteByte(0x30+dat/100);
          LCD_WriteByte(0x30+dat/10%10);
          LCD_WriteByte(0x30+dat%10);
          UCA0IE=0x02;        //开发送中断,关闭收中断
          break;
  // Vector 4 - TXIFG
  case 4: delay_us(500);
          UCA0TXBUF = Key_Val;
          UCA0IE=0x01;        //关闭发送中断,开接收中断
          break;
  default: break;
点赞  2013-1-24 16:34
点赞  2013-1-24 16:35
将 UCA0IE |= UCRXIE+UCTXIE;        //使能 USART0 TXD/RXD 打开,屏蔽key_P1() 就能输入键盘值,也可以接受PC机给的数据,但是发布出去,接收的数值也不对,求指点
点赞  2013-1-24 16:43
现在已经能够,发送接收10以下的数字,但是要以十六进制在串口小助手上面,发送与接收,有没有人懂为什么啊
点赞  2013-1-24 17:02
引用: 原帖由 纹身灬猎人 于 2013-1-24 17:02 发表
数据格式的问题
点赞  2013-1-24 17:49
那就要写转换数据的代码吗?还是在定义变量哪里改格式?
点赞  2013-1-24 21:10
回复 7楼 lr2131 的帖子
了解明白,这个得自己动脑
点赞  2013-1-24 21:19
    写回复
