依旧是launchpad的扩展板,资源比较丰富
ompatibility | MSP430 LaunchPad |
Power | 3.3V via expansion header |
Display type | 2x16 character LCD |
Display interface | Serial |
Indicators | Tri-color (RGB) LED and white LED |
Sensor type | Accelerometer |
Sensor input interface | Analog |
Audio input type | Electret condenser microphone |
Audio input interface | Analog |
Audio output type | Magnetic buzzer |
Audio output interface | GPIO |
Potentiometer interface | Analog
境外的网站,不知道能不能申请成功,暂且介绍下这个扩展板吧!
- A0 (connected to XOUT of accelerometer)
- A3 (connected to YOUT of accelerometer OR output of potentiometer)
- A4 (connected to ZOUT of accelerometer OR output of microphone)
- UCB0CLK (Connected to the character LCD display)
- UCB0SOMI (Connected to the character LCD display)
- P2.1 (Connected to the red channel of the RGB LED)
- P2.2 (Connected to the green channel of the RGB LED)
- P2.3 (Connected to the character LCD display "RS")
- P2.4 (Connected to the blue channel of the RGB LED)
- P2.5 (connected to the white LED)
- P2.6 (connected to the buzzer)
- P2.7 (connected to alligator clip connector "MK1")
wstt, could you help to forward the link for this application. thanks!
地址什么的总要写一下吧,估计没戏,因为是国外的地方论坛搞得!
回复 9楼 wgsxsm 的帖子
美帝的论坛做的 ,不一定靠谱
回复 6楼 幸运武士2 的帖子
要用google account吧
这个,还是自己做个扩展板吧!上课的时候给学生做了一个。
