CC110L vs CC1101 无线收发器之间的区别
winterwu   2013-2-5 10:50 楼主
参考资料:http://e2e.ti.com/support/low_power_rf/f/155/t/153153.aspx
CC110L作为“Value Line (超值系列)”的产品对于CC1101被精简了部分功能:
The following features are removed from the Value Line chips versus CC1101:
CC110L"超值系列"对比CC1101被删除的功能如下:
• Forward error correction (FEC) and interleaving
• 前向纠错(FEC)和交错纠错
• Wake-on-Radio (WOR) and RCOSC (no RX timeout possible)
• 无线唤醒(WOR)和RCOSC(无RX超时可能)
• Data Whitening
• 数据白化
• Preamble quality threshold (PQT) indication (used to gate sync word detection)
• 前导质量阀值(PQT)指示(用于同步字门限检测)
• Link quality (LQI) indication (received signal strength (RSSI) is supported in Value Line parts)
• 链路质量(LQI)指示(在"超值系列"中支持接收信号强度(RSSI))
• Temp sensor
• 温度传感器
• PA ramping and shaping
• 功率斜坡和整形
• MSK and ASK modulation (OOK modulation is supported in Value Line parts)
• MSK和ASK调制(在"超值系列"产品中支持OOK调制)
• No pin control for strobe commands (SPI strobe commands need to be used)
• 不能通过引脚控制选通命令(需要使用SPI进行选通命令)
• ATEST removed
• 删除ATEST
回复评论
暂无评论,赶紧抢沙发吧
    写回复
