[求助] STM32+ucos2程序编译过了,也下载到板子上,为什么灯不亮
小小小小菜鸟   2013-4-8 10:50 楼主
用一个多任务的流水灯程序做验证,很简单。为什么灯不亮。
UCOS的内核是在官网下载对应的
求解释
int main(void)
#if (OS_TASK_NAME_EN > 0)
    CPU_INT08U  err;
#endif
    BSP_IntDisAll();                                            /* Disable all interrupts.                              */
    OSInit();                                                   /* Initialize "uC/OS-II, The Real-Time Kernel"          */
    OSTaskCreateExt((void (*)(void *)) AppTaskStart,           /* Create the start task                                */
                    (void           *) 0,
                    (OS_STK         *)&AppTaskStartStk[APP_CFG_TASK_START_STK_SIZE - 1],
                    (INT8U           ) APP_CFG_TASK_START_PRIO,
                    (INT16U          ) APP_CFG_TASK_START_PRIO,
                    (OS_STK         *)&AppTaskStartStk[0],
                    (INT32U          ) APP_CFG_TASK_START_STK_SIZE,
                    (void           *) 0,
                    (INT16U          )(OS_TASK_OPT_STK_CHK | OS_TASK_OPT_STK_CLR));
    OSTaskNameSet(APP_CFG_TASK_START_PRIO, "Start", &err);
#endif
    OSStart();                                                  /* Start multitasking (i.e. give control to uC/OS-II)   */
    return (1);
static  void  AppTaskStart (void *p_arg)
    CPU_INT32U  cpu_clk_freq;
    CPU_INT32U  cnts;
   (void)p_arg;
    BSP_Init();                                                 /* Initialize BSP functions                             */
    CPU_Init();                                                 /* Initialize the uC/CPU services                       */
    cpu_clk_freq = BSP_CPU_ClkFreq();                           /* Determine SysTick reference freq.                    */
    cnts         = cpu_clk_freq                                 /* Determine nbr SysTick increments                     */
                 / (CPU_INT32U)OS_TICKS_PER_SEC;
    OS_CPU_SysTickInit(cnts);                                   /* Init uC/OS periodic time src (SysTick).              */
    Mem_Init();                                                 /* Initialize memory managment module                   */
    Math_Init();                                                /* Initialize mathematical module                       */
#if (OS_TASK_STAT_EN > 0)
    OSStatInit();                                               /* Determine CPU capacity                               */
#endif
    APP_TRACE_DBG(("\n\n\r"));
    APP_TRACE_INFO(("Creating Application Events...\n\r"));
    AppEventCreate();                                          /* Create Application Events                            */
    APP_TRACE_INFO(("Creating Application Tasks...\n\r"));
    AppTaskCreate();                                           /* Create application tasks                             */
        OSTaskCreate( Task0,        //任务1
                          (void          * ) 0,                                                        //不带参数
                          (OS_STK        * )&Task0Stk[128 - 1],                        //堆栈指针
                          (INT8U           ) 5                                                        //优先级
        OSTaskCreate( Task1,        //任务2
                          (void          * ) 0,                                                        //不带参数
                          (OS_STK        * )&Task1Stk[128 - 1],
                           (INT8U           ) 6                                                        //优先级
        for(;;)
                BSP_LED_On(2);
        OSTimeDlyHMSM(0, 0, 0, 500);                            /* Delay for 100 milliseconds                           */
                BSP_LED_Off(2);
void Task0(void *p_arg)
        for(;;)
                BSP_LED_On(3);
        OSTimeDlyHMSM(0, 0, 0, 100);                            /* Delay for 100 milliseconds                           */
                BSP_LED_Off(3);
void Task1(void *p_arg)
        for(;;)
                BSP_LED_On(4);
        OSTimeDlyHMSM(0, 0, 0, 200);                            /* Delay for 100 milliseconds                           */
                BSP_LED_Off(4);
[ 本帖最后由 小小小小菜鸟 于 2013-4-8 10:51 编辑 ]
回复评论 (13)
回复 楼主 小小小小菜鸟 的帖子
给你问问网友哈,看谁能帮你解答一下
点赞  2013-4-8 12:11
回复 沙发 苏莎莎 的帖子
谢谢管理员大大
点赞  2013-4-8 13:09
回复 楼主 小小小小菜鸟 的帖子
检查一下 BSP_LED_On() 里边对 GPIO 的配置是否与板子实际相符。
点赞  2013-4-8 13:38
不知道,帮着顶顶
点赞  2013-4-8 13:38
延时时间弄长些看看。最好1s左右
淘宝:https://viiot.taobao.com/Q群243090717 多年专业物联网行业经验,个人承接各类物联网外包项目
点赞  2013-4-8 13:39
回复 4楼 Study_Stellaris 的帖子
检查了很多次  应该是没有问题的  这让人纠结的
点赞  2013-4-8 14:12
回复 6楼 wateras1 的帖子
试试看
点赞  2013-4-8 14:12
回复 5楼 gaon 的帖子
好吧 谢谢
点赞  2013-4-8 14:12
回复 沙发 苏莎莎 的帖子
debug了一下。应该是系统的板子之间的设置有问题,晕死。
           官网对应的内核编译下载以后竟然有问题 这让人如何是好
点赞  2013-4-8 15:22
问题解决了没?这样的东西,首先第一步就是排除硬件有没问题,如果是买的学习板子一般没问题,其实就是看看软件寄存器是否配置好了。还有像灯闪烁,最好延时1s左右,太短了看不到效果,人眼无法感觉。希望对你有帮助。
点赞  2013-4-8 21:31
回复 11楼 wateras1 的帖子
谢谢哈  有了初步进展  正在一步一步debug  因为刚开始做这个  所以有点儿麻烦 嘿嘿
点赞  2013-4-9 08:29
关注
点赞  2013-4-9 12:26
回复 11楼 wateras1 的帖子
搞定了 就是硬件配置的问题 刚开始初始化的时候出现了问题 控制LED的管脚并没有被正确的初始化 更改以后就OK了 谢谢哈
点赞  2013-4-9 15:28
    写回复
