各位高手好,我最近想要UART與timer一起使用,但是只要我把兩個寫在一起,就無法作動,可以幫我解決這個疑惑嗎?謝謝
回复 楼主 lavender780510 的帖子
如果可以贴出你的 init code ,才能找到原因。
你也可以单步仿真,看执行到那一步出现了问题。
回复 沙发 Study_Stellaris 的帖子
// timers.c - Timers example.
// Copyright (c) 2012 Texas Instruments Incorporated. All rights reserved.
// Software License Agreement
// Texas Instruments (TI) is supplying this software for use solely and
// exclusively on TI's microcontroller products. The software is owned by
// TI and/or its suppliers, and is protected under applicable copyright
// laws. You may not combine this software with "viral" open-source
// software in order to form a larger program.
// THIS SOFTWARE IS PROVIDED "AS IS" AND WITH ALL FAULTS.
// NO WARRANTIES, WHETHER EXPRESS, IMPLIED OR STATUTORY, INCLUDING, BUT
// NOT LIMITED TO, IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
// A PARTICULAR PURPOSE APPLY TO THIS SOFTWARE. TI SHALL NOT, UNDER ANY
// CIRCUMSTANCES, BE LIABLE FOR SPECIAL, INCIDENTAL, OR CONSEQUENTIAL
// DAMAGES, FOR ANY REASON WHATSOEVER.
// This is part of revision 9453 of the EK-LM4F120XL Firmware Package.
#include "inc/hw_ints.h"
#include "inc/hw_memmap.h"
#include "inc/hw_types.h"
#include "driverlib/debug.h"
#include "driverlib/fpu.h"
#include "driverlib/gpio.h"
#include "driverlib/interrupt.h"
#include "driverlib/pin_map.h"
#include "driverlib/rom.h"
#include "driverlib/sysctl.h"
#include "driverlib/timer.h"
#include "utils/uartstdio.h"
#include "driverlib/uart.h"
//! \addtogroup example_list
//! Timer (timers)
//! This example application demonstrates the use of the timers to generate
//! periodic interrupts. One timer is set up to interrupt once per second and
//! the other to interrupt twice per second; each interrupt handler will toggle
//! its own indicator on the display.
//! UART0, connected to the Stellaris Virtual Serial Port and running at 115,200,
//! 8-N-1, is used to display messages from this application.
// Flags that contain the current value of the interrupt indicator as displayed
// on the UART.
unsigned long g_ulFlags;
// The error routine that is called if the driver library encounters an error.
#ifdef DEBUG
void
__error__(char *pcFilename, unsigned long ulLine)
#endif
// The interrupt handler for the first timer interrupt.
void
UARTIntHandler(void)
unsigned long ulStatus;
// Get the interrrupt status.
ulStatus = ROM_UARTIntStatus(UART0_BASE, true);
// Clear the asserted interrupts.
ROM_UARTIntClear(UART0_BASE, ulStatus);
// Loop while there are characters in the receive FIFO.
while(ROM_UARTCharsAvail(UART0_BASE))
// Read the next character from the UART and write it back to the UART.
ROM_UARTCharPutNonBlocking(UART0_BASE,
ROM_UARTCharGetNonBlocking(UART0_BASE));
// Blink the LED to show a character transfer is occuring.
GPIOPinWrite(GPIO_PORTF_BASE, GPIO_PIN_2, GPIO_PIN_2);
// Delay for 1 millisecond. Each SysCtlDelay is about 3 clocks.
SysCtlDelay(SysCtlClockGet() / (1000 * 3));
// Turn off the LED
GPIOPinWrite(GPIO_PORTF_BASE, GPIO_PIN_2, 0);
void
Timer0IntHandler(void)
// Clear the timer interrupt.
ROM_TimerIntClear(TIMER0_BASE, TIMER_TIMA_TIMEOUT);
// Toggle the flag for the first timer.
HWREGBITW(&g_ulFlags, 0) ^= 1;
// Use the flags to Toggle the LED for this timer
GPIOPinWrite(GPIO_PORTF_BASE, GPIO_PIN_1, g_ulFlags << 1);
// Update the interrupt status on the display.
ROM_IntMasterDisable();
UARTprintf("\rT1: %d T2: %d", HWREGBITW(&g_ulFlags, 0) ? 1 : 0,
HWREGBITW(&g_ulFlags, 1) ? 1 : 0);
ROM_IntMasterEnable();
// The interrupt handler for the second timer interrupt.
void
UARTSend(const unsigned char *pucBuffer, unsigned long ulCount)
// Loop while there are more characters to send.
while(ulCount--)
// Write the next character to the UART.
ROM_UARTCharPutNonBlocking(UART0_BASE, *pucBuffer++);
void
Timer1IntHandler(void)
ROM_TimerIntClear(TIMER1_BASE, TIMER_TIMA_TIMEOUT);
// Toggle the flag for the second timer.
HWREGBITW(&g_ulFlags, 1) ^= 1;
GPIOPinWrite(GPIO_PORTF_BASE, GPIO_PIN_2, g_ulFlags << 1);
// This example application demonstrates the use of the timers to generate
// periodic interrupts.
int
main(void)
// Enable lazy stacking for interrupt handlers. This allows floating-point
// instructions to be used within interrupt handlers, but at the expense of
// extra stack usage.
ROM_FPULazyStackingEnable();
ROM_FPUEnable();
// Set the clocking to run directly from the crystal.
ROM_SysCtlClockSet(SYSCTL_SYSDIV_1 | SYSCTL_USE_OSC | SYSCTL_OSC_MAIN |
SYSCTL_XTAL_16MHZ);
ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOF);
ROM_GPIOPinTypeGPIOOutput(GPIO_PORTF_BASE, GPIO_PIN_2);
ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_UART0);
ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOA);
// Initialize the UART and write status.
//ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOA);
GPIOPinConfigure(GPIO_PA0_U0RX);
GPIOPinConfigure(GPIO_PA1_U0TX);
ROM_GPIOPinTypeUART(GPIO_PORTA_BASE, GPIO_PIN_0 | GPIO_PIN_1);
// UARTStdioInit(0);
//UARTprintf("\033[2JTimers example\n");
// UARTprintf("T1: 0 T2: 0");
ROM_UARTConfigSetExpClk(UART0_BASE, ROM_SysCtlClockGet(), 115200,
(UART_CONFIG_WLEN_8 | UART_CONFIG_STOP_ONE |
UART_CONFIG_PAR_NONE));
// Enable the GPIO port that is used for the on-board LED.
// Enable the GPIO pins for the LED (PF1 & PF2).
ROM_GPIOPinTypeGPIOOutput(GPIO_PORTF_BASE, GPIO_PIN_2 | GPIO_PIN_1);
// Enable the peripherals used by this example.
ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_TIMER0);
ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_TIMER1);
// Enable processor interrupts.
// Configure the two 32-bit periodic timers.
ROM_TimerConfigure(TIMER0_BASE, TIMER_CFG_PERIODIC);
ROM_TimerConfigure(TIMER1_BASE, TIMER_CFG_PERIODIC);
ROM_TimerLoadSet(TIMER0_BASE, TIMER_A, ROM_SysCtlClockGet());
ROM_TimerLoadSet(TIMER1_BASE, TIMER_A, ROM_SysCtlClockGet() / 2);
// Setup the interrupts for the timer timeouts.
ROM_IntEnable(INT_TIMER0A);
ROM_IntEnable(INT_TIMER1A);
ROM_TimerIntEnable(TIMER0_BASE, TIMER_TIMA_TIMEOUT);
ROM_TimerIntEnable(TIMER1_BASE, TIMER_TIMA_TIMEOUT);
// Enable the timers.
ROM_TimerEnable(TIMER0_BASE, TIMER_A);
ROM_TimerEnable(TIMER1_BASE, TIMER_A);
ROM_IntEnable(INT_UART0);
ROM_UARTIntEnable(UART0_BASE, UART_INT_RX | UART_INT_RT);
// Prompt for text to be entered.
UARTSend((unsigned char *)"\033[2JEnter text: ", 16);
// Loop forever while the timers run.
while(1)
您好~這是我的程式碼,可以請您看看嗎?
