各位大神,帮忙看看这个时钟程序哪里有错误吧
41wanglh41   2013-5-11 00:57 楼主
悬赏 2 分 芯积分未解决
程序在keil里编译没有错也没有警告,但是烧录到51单片机里显示不出来。是我程序不对吗?还是单片机的显示有问题?望各位大神指导啊,急用啊。要是能给个新的程序也行
    SW1     BIT P0.0
    SW2     BIT P0.1
    SW3     BIT P0.2
    SW4     BIT P0.3
    SW5     BIT P0.4
    SW6     BIT P0.5
    DIG1    BIT P0.0
    DIG2    BIT P0.1
    DIG3    BIT P0.2
    DIG4    BIT P0.3
    DIG5    BIT P0.4
    DIG6    BIT P0.5
    DAT164  BIT P0.6
    CLK164  BIT P0.7
    BEEP    BIT P2.0
    SPK     BIT P2.1
    DI0832  BIT P2.2
    DO0832  BIT P2.3
    CK0832  BIT P2.4
    CS0832  BIT P2.5
    DAT24   BIT P2.6
    CLK24   BIT P2.7
    LED1    BIT P1.0
    LED2    BIT P1.1
    LED3    BIT P1.2
    LED4    BIT P1.3
    LED5    BIT P1.4
    LED6    BIT P1.5
    LED7    BIT P1.6
    LED8    BIT P1.7
    RX      BIT P3.0
    TX      BIT P3.1
    KEY     BIT P3.2
    JDQ     BIT P3.3
    STPA    BIT P3.4
    STPB    BIT P3.5
    STPC    BIT P3.6
    STPD    BIT P3.7
    BUFF_LED1   EQU  22H
    BUFF_LED2   EQU  23H
    BUFF_LED3   EQU  24H
    BUFF_LED4   EQU  25H
    BUFF_LED5   EQU  26H
    BUFF_LED6   EQU  27H
    BUFF_LED_LP EQU  28H     ;T0键盘显示扫描缓存
    BUFF_KEY    EQU  29H
    BUFF_164    EQU  2AH
    BUFF_DEL    EQU  2BH
    BUFF_DEL0   EQU  2CH
    BUFF_DEL1   EQU  2DH
    DIG_PORT    EQU  P0
         HOR    EQU   30H           ;小时值缓存
         MIN    EQU   31H           ;分钟值缓存
         SEC    EQU   32H           ;秒值缓存
        org   000h
        JMP   main
        org   003h
        jmp   ex_int0
        ORG   00BH
        JMP   T0_INT
        ORG   100H
MAIN:   MOV    SP ,#40H
        MOV    PSW,#00H
        MOV    R0,#7FH      ;初始化RAM区,
CLR_RAM:MOV    A,#00H
        MOV    @R0,A
        DJNZ   R0,CLR_RAM
        MOV    P1,#0FFH      ;INIT
        MOV    P2,#0FFH
        MOV    P0,#0FFH
        MOV    P3,#0FFH
        clr    beep
        clr    jdq
        clr    spk
        lcall  del
        setb    BEEP
        lcall   del
        clr    beep
        CLR    JDQ
        CLR    SPK
        SETB   KEY
        MOV    TMOD,#21h
        MOV    TH0,#HIGH(65536-4000)     ;T0=4MS
        MOV    TL0,#LOW(65535-4000)
        SETB   TR0
        mov   ie,#10000011b
        mov   ip,#00000010b
        ajmp   $
ex_int0:push  psw
         push  acc
         JNB   SW1,SW1_OK
         JNB   SW2,SW2_OK
         JNB   SW3,SW3_OK
         JNB   SW4,SW4_OK
         JNB   SW5,SW5_OKA
         JNB   SW6,SW6_OKA
         JMP   return
SW5_OKA: JMP   SW5_OK
SW6_OKA: JMP   SW6_OK
SW1_OK:  MOV    A,HOR
         CJNE   A,#24,SW1_OVER
         MOV    HOR,#00H
         SETB   BEEP
         LCALL  DEL
         CLR    BEEP
         JMP    return
SW1_OVER:INC    HOR        ;时加1
         SETB    BEEP
         LCALL  DEL
         CLR    BEEP
         JMP    return
SW2_OK:  MOV    A,HOR
         CJNE   A,#00,SW2_OVER
         MOV    HOR,#23
         SETB   BEEP
         LCALL  DEL
         CLR    BEEP
         JMP    return
SW2_OVER:DEC    HOR        ;时减1
         SETB   BEEP
         LCALL  DEL
         CLR    BEEP
         JMP    return
SW3_OK:  MOV    A,MIN
         CJNE   A,#59,SW3_OVER
         MOV    MIN,#00H
         SETB   BEEP
         LCALL  DEL
         CLR    BEEP
         JMP    return
SW3_OVER:INC    MIN        ;分加1
         SETB   BEEP
         LCALL  DEL
         CLR    BEEP
         JMP    return
SW4_OK:  MOV    A,MIN
         CJNE   A,#00,SW4_OVER
         MOV    MIN,#59
         SETB   BEEP
         LCALL  DEL
         CLR    BEEP
         JMP    return
SW4_OVER:DEC    MIN        ;分减1
         SETB   BEEP
         LCALL  DEL
         CLR    BEEP
         JMP    return
SW5_OK:  MOV    A,SEC
         CJNE   A,#59,SW5_OVER
         MOV    SEC,#00H
         SETB   BEEP
         LCALL  DEL
         CLR    BEEP
         JMP    return
SW5_OVER:INC    SEC        ;秒加1
         SETB   BEEP
         LCALL  DEL
         CLR    BEEP
         JMP    return
SW6_OK:  MOV    A,SEC
         CJNE   A,#00,SW6_OVER
         MOV    HOR,#59
         SETB   BEEP
         LCALL  DEL
         CLR    BEEP
         JMP    return
SW6_OVER:DEC    SEC        ;时减1
         SETB   BEEP
         LCALL  DEL
         CLR    BEEP
         JMP    return
  return:pop acc
         pop psw
         reti
DEL:     MOV   buff_del,#03      ;为演示方便,人为插入的延时
DEL01:   MOV   buff_del0,#200
DEL02:   MOV   buff_del1,#200
         DJNZ  buff_del1,$
         DJNZ  buff_del0,DEL02
         DJNZ  buff_del,DEL01
         RET
BIN_BCD:  MOV  B,#10
          DIV  AB
          RET
;-------------  T0 INTRRUPT 数码管扫描定时中断---------------------------
T0_INT:  PUSH   ACC
         PUSH   PSW
         MOV    TL0,#LOW(65536-4000)
         INC    BUFF_LED_LP
         MOV    A,BUFF_LED_LP
         CJNE   A,#250,CONT_SCAN     ;250*4MS=1S
         MOV    BUFF_LED_LP,#00H
         INC    SEC
         MOV    A,SEC
         CJNE   A,#60,CONT_SCAN
         MOV    SEC,#00H
         INC    MIN
         MOV    A,MIN
         MOV    MIN,#00H
         INC    HOR
         MOV    A,HOR
         CJNE   A,#24,CONT_SCAN    ;24:00:00时BEEP报时,
         MOV    HOR,#00H
         SETB   beep
         clr    LED1
         lcall  del
         CLR    beep
         setb   LED1
CONT_SCAN:MOV   A,SEC
          LCALL  BIN_BCD
          MOV   BUFF_LED6,B
          MOV   BUFF_LED5,A
          MOV   A,MIN
          LCALL  BIN_BCD
          MOV   BUFF_LED4,B
          MOV   BUFF_LED3,A
          MOV   A,HOR
          LCALL  BIN_BCD
          MOV   BUFF_LED2,B
          MOV   BUFF_LED1,A
          MOV   A,BUFF_LED_LP
          MOV   B,#06
          DIV   AB
          MOV   A,B
          RL    A
          MOV   DPTR,#TAB_SCAN
          JMP   @A+DPTR
TAB_SCAN: AJMP  SCAN_L1
          AJMP  SCAN_L2
          AJMP  SCAN_L3
          AJMP  SCAN_L4
          AJMP  SCAN_L5
          AJMP  SCAN_L6
SCAN_L1:  MOV   DIG_PORT,#11111110B
          MOV   A,BUFF_LED1
          JMP   END_SCAN
SCAN_L2:  MOV   DIG_PORT,#11111101B
          MOV   A,BUFF_LED2
          JMP   END_SCAN
SCAN_L3:  MOV   DIG_PORT,#11111011B
          MOV   A,BUFF_LED3
          JMP   END_SCAN
SCAN_L4:  MOV   DIG_PORT,#11110111B
          MOV   A,BUFF_LED4
          JMP   END_SCAN
SCAN_L5:  MOV   DIG_PORT,#11101111B
          MOV   A,BUFF_LED5
          JMP   END_SCAN
SCAN_L6:  MOV   DIG_PORT,#11011111B
          MOV   A,BUFF_LED6
END_SCAN: MOV   DPTR,#TAB_LED
          MOVC  A,@A+DPTR
          LCALL  SEND164
EXIT_T0:  POP   PSW
          POP   ACC
          RETI
TAB_LED: DB 0C0H,0F9H,0A4H,0B0H,99H,92H   ;数码管显示字型表
         DB 82H,0F8H,80H,90H,88H,83H,0A7H
         DB 0A1H,86H,8EH
SEND164:  MOV   BUFF_164,#08         ;发送数据到74164
          PUSH  ACC
SND164_LP:CLR   CLK164
          RLC   A
          MOV   DAT164,C
          SETB  CLK164
          DJNZ  BUFF_164,SND164_LP
          POP   ACC
          RET
      END
回复评论
暂无评论,赶紧抢沙发吧
    写回复
