[求助] 430 I/O中断疑问
zhanghuaihe01   2013-5-13 10:55 楼主
#include
int main(void)
  WDTCTL = WDTPW | WDTHOLD;                 // Stop watchdog timer
  P1DIR |= BIT0;                            // Set P1.0 to output direction
  P1OUT &= ~BIT0;
  P1REN |= BIT4;                            // Enable P1.4 internal resistance
  P1OUT |= BIT4;                            // Set P1.4 as pull-Up resistance
  P1IES &= ~BIT4;                           // P1.4 Lo/Hi edge
  P1IFG &= ~BIT4;                           // P1.4 IFG cleared
  P1IE |= BIT4;                             // P1.4 interrupt enabled
  while(1)
    __bis_SR_register(LPM4_bits |GIE);     // Enter LPM4 w/interrupt
    __no_operation();                       // For debugger
    P1OUT ^= BIT0;                        // P1.0 = toggle
    P1IES ^= BIT4;                          // Toggle between H-L and L-H transition triggers
    P1IE |= BIT4;                           // Enable port interrupt
// Port 1 interrupt service routine
#pragma vector=PORT1_VECTOR
__interrupt void Port_1(void)
  P1IFG &= ~BIT4;                           // Clear P1.4 IFG
  P1IE &= ~ BIT4;                           // Clear P1.4 IE
  _BIC_SR_IRQ(LPM4_bits);                   // Exit LPM4
此是430 5系列的MCU的库,如果P1.4是个按键,在单步执行时能否顺利到达P1.4的中端入口?
我试了 很多次都是不行,请教原因?
回复评论
暂无评论,赶紧抢沙发吧
    写回复
