[求助] 请教MPLAB IDE编译出错问题.感谢不尽!
pcqboys   2013-5-15 17:00 楼主
程序是:
#include
__CONFIG(HS&WDTDIS);
void main(void)
Clean: Deleting intermediary and output files.
Clean: Deleted file "E:\ww\ww.cce".
Clean: Done.
Executing: "C:\Program Files\HI-TECH Software\PICC\std\9.60\bin\picc.exe" -C -E"ww.cce" "ww.c" -O"ww.obj" -Zg9 -O -ASMLIST -Q -MPLAB -16F877A
Error[1187]   : An error, warning or message was generated, but no description is available
Halting build on first failure as requested.
BUILD FAILED: Wed May 15 16:54:16 2013
回复评论 (1)
回复 楼主 pcqboys 的帖子
应该是MAPLAB或者PICC的安装问题,建议换个版本试试!
点赞  2013-5-15 17:36
    写回复
