[求助] 跪求大神给个G2553连接DHT11的完整程序
asd25845601   2013-5-22 23:52 楼主
我想用串口调试助手检测DHT11测到的数据,无奈水平太菜,所以跪求大神们帮助。
回复评论 (6)
#include "msp430G2553.h"
#include"stdio.h"
#define DHT11_OUTPUT   P2DIR|=BIT0
#define DHT11_INPUT   P2DIR&=~BIT0
#define DHT11_H   P2OUT|=BIT0
#define DHT11_L   P2OUT&=~BIT0
#define DHT11_IN   (P2IN&BIT0)
#define uchar unsigned char
#define uint unsigned int
#define ulong unsigned long
#define CPU          (1000000)
#define delay_us(x)   (__delay_cycles((double)x*CPU/1000000.0))
#define delay_ms(x)   (__delay_cycles((double)x*CPU/1000.0))
uchar start_DHT11(void);
uchar DHT11_ReadChar(void);
void dht11(void);
uchar DHT11T_Data_H, DHT11T_Data_L, DHT11RH_Data_H, DHT11RH_Data_L,CheckData_temp;
void put(uchar *x)
  while(*x)
    while (!(IFG2&UCA0TXIFG));                // USCI_A0 TX buffer ready?
    UCA0TXBUF=*x;
    x++;
void putc(char *x)
  while(*x)
    UCA0TXBUF=*x;
    x++;
void wellcome()
put("*************************************\n");
put("********   hello,eeworld!   ********\n");
put("********   this is mengzhilv!    ********\n");
put("********  Copyright @ 2011   ********\n");
put("*************************************\n\n");
delay_ms(10);
void main(void)
  WDTCTL = WDTPW + WDTHOLD;                 // Stop WDT
  UCA0CTL1 |= UCSWRST;
   BCSCTL1 = CALBC1_1MHZ;
   DCOCTL = CALDCO_1MHZ;
   P1SEL = BIT1 + BIT2 ;
   P1SEL2 = BIT1 + BIT2 ;
   UCA0CTL1 |= UCSSEL_2;
   UCA0BR0 = 104;
   UCA0BR1 = 0;
   UCA0MCTL = UCBRS0;
   UCA0CTL1 &= ~UCSWRST;                  // **Initialize USCI state machine**
  delay_us(1000);
  wellcome();
  put("**********DHT11 TEST**********\n");
  delay_ms(1000);
while(1)
  dht11();
uchar TData_H_temp,TData_L_temp,RHData_H_temp,RHData_L_temp,checktemp;
uchar  presence,flag;
uint count;
DHT11_OUTPUT;
DHT11_L;    //拉低18ms以上
delay_ms(20);
DHT11_H;
DHT11_INPUT;
delay_us(40);
presence=DHT11_IN;
if(!presence)
   count=2;
   while((!DHT11_IN)&&count++);//等待低电平
   count=2;
   while((DHT11_IN)&&count++);//等待高电平
      RHData_H_temp = DHT11_ReadChar();
      RHData_L_temp = DHT11_ReadChar();
      TData_H_temp = DHT11_ReadChar();
      TData_L_temp = DHT11_ReadChar();
      CheckData_temp = DHT11_ReadChar();
      DHT11_OUTPUT;
      DHT11_H;
      checktemp = (RHData_H_temp + RHData_L_temp + TData_H_temp + TData_L_temp);
      if (checktemp == CheckData_temp) {
         DHT11RH_Data_H = RHData_H_temp;
         DHT11RH_Data_L = RHData_L_temp;
         DHT11T_Data_H = TData_H_temp;
         DHT11T_Data_L = TData_L_temp;
         flag=1;
   P1OUT |=BIT0;
   return flag;
  unsigned char dat;
   unsigned int count;     //计数防止死等
   unsigned char i;
   for(i=0;i<8;i++)
      count=2;
      while((!DHT11_IN)&&count++);     //等待50us低电平结束
     delay_us(40); //40us
      dat <<= 1;        //50us低电平+28us高电平表示'0'
      if(DHT11_IN)    //50us低电平+70us高电平表示'1'
         dat |= 1;
      count=2;
      if(count==1)      //超时则跳出for循环
         break;
   return dat;
void dht11()
char c[40];
uchar o;
o=start_DHT11();
P1OUT |=BIT1;
delay_ms(300);
P1OUT &=~BIT1;
delay_ms(300);
if (o)
        put("DHT11 EXIST AND ACQUIRE SUCCESSFUL!\n");
        delay_ms(10);
  sprintf(c, "%d.%d %d.%d %d\r\n",DHT11RH_Data_H,DHT11RH_Data_L,DHT11T_Data_H,DHT11T_Data_L,CheckData_temp);
  putc(c);
点赞  2013-5-26 19:28
#include"stdio.h"
测试了 可以用 谢谢大神了!!
点赞  2014-5-2 21:47
为什么我的不可以呢
自我主导
点赞  2014-6-20 21:01
引用: ljc2010 发表于 2014-5-2 21:47
测试了 可以用 谢谢大神了!!
lz,我还是调不出来,可不可以留下个联系方式
点赞  2014-8-4 22:15
#include"stdio.h"
用的是Iar还是ccs
点赞  2014-8-4 22:17
请问这个程序dht是插在哪个引脚上的?我用的是energia开发环境。本人菜鸟,大神求指教,谢谢
点赞  2017-1-9 19:57
    写回复
