[求助] 调试stm32时运行一条语句后进入硬中断HardFault_Handler
cheng_bingyuan   2013-7-6 17:00 楼主
typedef struct _PARA_SET
#if STRING_STORE_USE_ARRAY
    char                name[NAME_STRING_MAX];
    char                alias[ALIAS_STRING_MAX];
    char                unit[UNIT_STRING_MAX];
    char                strValue[LINE_STRING_MAX];
#else
    char                *name;
    char                *alias;
    char                *unit;
    char                *strValue;
#endif
    tParaType           type;
    FLOAT32             value;
    FLOAT32             MaxValue;
    FLOAT32             MinValue;
    FLOAT32             DefValue;
}tParaSet;
tParaSet DevCommSets[3];
static void DEV_ReadCommSets(void)
  UINT32 i, value;
    tParaSet *pSets = DevCommSets;
    DF_ReadMainMemoryPage(SAVE_DEV_COMM_SETS_PAGE,
                          DEV_ReadData, COMM_MAX_SETS * 4 + 4);
    for (i = 0; i < COMM_MAX_SETS; i++)
        value = BytesToDword(&DEV_ReadData[i * 4]);
         pSets->value = value;
        if ((pSets->value > pSets->MaxValue) || (pSets->value < pSets->MinValue))
            pSets->value = pSets->DefValue;
        pSets++;
    DEV_CommSetsCrc = BytesToDword(&DEV_ReadData[i * 4]);
调试过程如下:
(gdb) n
Reset_Handler () at startup_stm32f10x_hd.c:262
262          SystemInit();
(gdb) n
268           __Init_Data();
(gdb) n
271          main();
(gdb) n
Breakpoint 1, DEV_ReadCommSets () at device.c:980
980            for (i = 0; i < COMM_MAX_SETS; i++)
(gdb) n
982                value = BytesToDword(&DEV_ReadData[i * 4]);
(gdb) n
984                 pSets->value = value;                   //运行这条语句后进入硬中断void HardFault_Handler(void){ while(1){} }中,不知道为什么?
(gdb) n
HardFault_Handler () at stm32f10x_it.c:61
61        {
(gdb) n
64            {}
回复评论
暂无评论,赶紧抢沙发吧
    写回复
