[求助] MSP430G2553比较器A+模块有现成的程序没?看了一天了,这一模块还是不太懂!
tao910221   2013-7-30 16:53 楼主
至今还没能清除的理解比较器A+模块的具体功能,以及通过什么方法实现他的功能!希望有个清晰的例程做个引导!谢谢啦……
回复评论 (2)
你好,请下载 MSP430Ware:
http://www.ti.com/tool/msp430ware
里面有各种430的各种例程。
G2553比较器A+例程1如下:
//  MSP430G2x13/G2x53 Demo - Comp_A, Output Reference Voltages on P1.1
//  Description: Output Comparator_A reference levels on P1.1. Program will
//  cycle through the on-chip comparator_A reference voltages with output on
//  P1.1. Normal mode is LPM0, TA0_ISR will interrupt LPM0.
//  ACLK = n/a, MCLK = SMCLK = default DCO
//         /|\|              XIN|-
//          --|RST          XOUT|-
//            |         P1.1/CA1|--> Vref
//  D. Dang
//  Texas Instruments Inc.
//  December 2010
//   Built with CCS Version 4.2.0 and IAR Embedded Workbench Version: 5.10
#include
void delay(void);                           // Software delay
int main (void)
  WDTCTL = WDTPW + WDTHOLD;                 // Stop WDT
  CACTL2 = P2CA4;                           // CA1/P1.1 = +comp
  CCTL0 = CCIE;                             // CCR0 interrupt enabled
  TACTL = TASSEL_2 + ID_3 + MC_2;           // SMCLK/8, cont-mode
  _EINT();                                  // enable interrupts
  while (1)                                 // Loop
    CACTL1 = 0x00;                          // No reference voltage
    _BIS_SR(LPM0_bits);                     // Enter LPM0
    CACTL1 = CAREF0 + CAON;                 // 0.25*Vcc, Comp. on
    CACTL1 = CAREF1 + CAON;                 // 0.5*Vcc, Comp. on
    CACTL1 = CAREF1 + CAREF0 + CAON;        // 0.55V, Comp. on
// Timer A0 interrupt service routine
#pragma vector=TIMER0_A0_VECTOR
__interrupt void Timer_A (void)
    _BIC_SR_IRQ(LPM0_bits);                 // Clear LPM0 bits from 0(SR)
[ 本帖最后由 Ling_Zhu 于 2013-7-30 21:28 编辑 ]
点赞  2013-7-30 21:26
在CCS里有相应模块的例程,可以结合用户手册,就能比较快的弄明白了
点赞  2013-7-30 21:46
    写回复
