[求助] LM3S SSI AD采样?
喜鹊王子   2013-8-30 14:33 楼主
程序如下,设置断点发下程序执行到红色部分就不再往下执行了,不知道为什么。
int
main(void)
    unsigned long ulDataTx[NUM_SSI_DATA];
    unsigned long ulDataRx[NUM_SSI_DATA];
    unsigned long ulindex;
    //系统时钟
    SysCtlClockSet(SYSCTL_SYSDIV_1 | SYSCTL_USE_OSC | SYSCTL_OSC_MAIN |
                   SYSCTL_XTAL_16MHZ);
    // Set up the serial console to use for displaying messages.  This is
    // just for this example program and is not needed for SSI operation.
    InitConsole();
    SysCtlPeripheralEnable(SYSCTL_PERIPH_SSI0);
    SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOA);
    GPIOPinTypeGPIOOutput(GPIO_PORTA_BASE, GPIO_PIN_3);
    GPIOPinConfigure(GPIO_PA2_SSI0CLK);
    GPIOPinConfigure(GPIO_PA3_SSI0FSS);
    GPIOPinConfigure(GPIO_PA4_SSI0RX);
    GPIOPinConfigure(GPIO_PA5_SSI0TX);
    // The pins are assigned as follows:
    //      PA5 - SSI0Tx
    //      PA4 - SSI0Rx
    //      PA3 - SSI0Fss
    //      PA2 - SSI0CLK
    // TODO: change this to select the port/pin you are using.
    GPIOPinTypeSSI(GPIO_PORTA_BASE, GPIO_PIN_5 | GPIO_PIN_4 | GPIO_PIN_3 | GPIO_PIN_2);
    //SSI配置
    SSIConfigSetExpClk(SSI0_BASE, SysCtlClockGet(), SSI_FRF_MOTO_MODE_0, SSI_MODE_MASTER, 1000000, 8);
    SSIEnable(SSI0_BASE);// 使能SSI0模块
    for(int i=0;i<1;i++)
      GPIOPinWrite(GPIO_PORTA_BASE, GPIO_PIN_3,0x01);//使能端置高电平
      GPIOPinWrite(GPIO_PORTA_BASE, GPIO_PIN_3,0x00);//使能端置低电平
      for(ulindex=0;ulindex<3;ulindex++)
        //while(SSIBusy(SSI0_BASE));
       SSIDataGet(SSI0_BASE, &ulDataRx[ulindex]);
        ulDataRx[ulindex] &= 0x00FF;
      cv=4.1*(float)(ulDataRx[0]&0x03<<14+ulDataRx[1]<<6+ulDataRx[2]>>2)/65535;
      for(int j=0;j<10;j++);
回复评论 (1)
回复 楼主喜鹊王子 的帖子
应该是停在
    // Wait until there is data to be read.
    while(!(HWREG(ui32Base + SSI_O_SR) & SSI_SR_RNE))
换用 SSIDataGetNonBlocking 试试.
点赞  2013-9-3 16:14
    写回复
