[讨论] ccs3.3安装出错
ttxs_2013   2013-10-3 14:02 楼主
安装CCS3.3,打开软件报错
Can't Initialize Target CPU:
Error 0x80002240/-122
Fatal Error during: Initialization, OCS, Control,
This error was generated by TI's USCIF driver.
SC_ERR_CMD_PARM <-122>
A bad parameter value was detected within a function.
It is likely a problem with `SC_ARGS' in SMG_call().
I/O Port = 240
Board Name: C5402 SEEDXDS510USB  Emulator
Cpu Name: TMS320C5400_0
Abort:                Close Code Composer Studio.
Retry:                Try to initialize the target again.
Ignore:                Ignore the initialization error and start
                without target debugging access.
Diagnostic:        Run diagnostic utility.
这个问题该怎么解决啊?
回复评论
暂无评论,赶紧抢沙发吧
    写回复
