[求助] STM32F103ZET6的TIM5-TIM8不能工作(新手求助)
舒影寒携   2013-11-28 09:31 楼主
STM32F103ZET6的TIM5-TIM8不能工作,TIM1-TIM4工作正常。TIM2-TIM5是通用定时器,但是TIM5与TIM2\3\4配置完全一样,却不能工作。TIM1换成TIM8也是同样问题,查看寄存器,TIM5\6\7\8->CNT根本没有计数。下面是TIM2和TIM8的配置。
static void TIM2_GPIO_Config(void)
        GPIO_InitTypeDef GPIO_InitStructure;
        /* TIM2 clock enable */
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);
  /* GPIOA clock enable */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
  /*GPIOA Configuration: TIM3 channel 1 and 2 as alternate function push-pull */
  GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_3;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;                    // 复用推挽输出
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_Init(GPIOA, &GPIO_InitStructure);
static void TIM2_Mode_Config(void)
  TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
        TIM_OCInitTypeDef  TIM_OCInitStructure;
        u16 CCR4_Val =         1000;
  /* Time base configuration */
  TIM_TimeBaseStructure.TIM_Period = 9999;       //当定时器从0计数到9999,即为10000次 10MS,为一个定时周期
  TIM_TimeBaseStructure.TIM_Prescaler = 71;            //设置预分频:72   1Mhz           1us
  TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1 ;        //设置时钟分频系数:不分频
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;  //向上计数模式
  TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);
  /* PWM1 Mode configuration: Channel1 */
  TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;            //配置为PWM模式1
  TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
  TIM_OCInitStructure.TIM_Pulse = CCR4_Val;           //设置跳变值,当计数器计数到这个值时,电平发生跳变
  TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low;  //当定时器计数值小于CCR4_Val时为低电平
  TIM_OC4Init(TIM2, &TIM_OCInitStructure);         //使能通道1
  TIM_OC4PreloadConfig(TIM2, TIM_OCPreload_Enable);
  TIM_ARRPreloadConfig(TIM2, ENABLE);                         // 使能TIM2重载寄存器ARR
  /* TIM3 enable counter */
  TIM_Cmd(TIM2, ENABLE);                   //使能定时器2
static void TIM8_GPIO_Config(void)
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM8, ENABLE);
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);
  GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_6;
  GPIO_Init(GPIOC, &GPIO_InitStructure);
static void TIM8_Mode_Config(void)
  TIM_TimeBaseInit(TIM8, &TIM_TimeBaseStructure);
  TIM_OCInitStructure.TIM_Pulse = 5000;           //设置跳变值,当计数器计数到这个值时,电平发生跳变
  TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low;  //当定时器计数值小于CCR1_Val时为低电平
  TIM_OC1Init(TIM8, &TIM_OCInitStructure);         //使能通道1
  TIM_OC1PreloadConfig(TIM8, TIM_OCPreload_Enable);
  TIM_ARRPreloadConfig(TIM8, ENABLE);                         // 使能TIM8重载寄存器ARR
  TIM_Cmd(TIM8, ENABLE);                   //使能定时器8
  TIM_CtrlPWMOutputs(TIM8,ENABLE);
回复评论 (1)
没看出来,帮你顶一下吧
点赞  2013-11-28 11:21
    写回复
