F282xx/F283xx自身带有I2C模块,但受限于TI的官方例程中使用了fifo,其深度为4,在写EEPROM时,读写地址16位,占了2个字节,最多只留下2个字节存储数据,使用很不方便、实用性也极差。有不少网友在这一块碰壁,甚至逼的没办法使用IO口模拟I2C,放弃使用I2C模块。最近一直在测试28027的I2C模块有所获,可突破发送/接收长度限制(非fifo模式,当然这个长度也要和I2C器件匹)。本查介绍查询方式下的I2C模块使。
1、宏定义I2C模块操作参数
#define I2C_SLAVE_ADDR 0x50 //器件地址不含读写位。以24Cxx系列为例,器件地址应为:(0xA0>>1),即0x50
#define I2C_NUMBYTES 10 //发送/接收数据长度
#define I2C_EEPROM_HIGH_ADDR 0x00
#define I2C_EEPROM_LOW_ADDR 0x00
2、设置相应GPIO引脚用作I2C引脚。 修改F2802x_I2C.c文件中的void InitI2CGpio()函数。
3、初始化I2C模块。
void I2CA_Init(void)
// Initialize I2C
I2caRegs.I2CSAR = 0x0050; // Slave address - EEPROM control code
// I2CCLK = SYSCLK/(I2CPSC+1)
#if (CPU_FRQ_40MHZ||CPU_FRQ_50MHZ)
I2caRegs.I2CPSC.all = 4; // Prescaler - need 7-12 Mhz on module clk
#endif
#if (CPU_FRQ_60MHZ)
I2caRegs.I2CPSC.all = 6; // Prescaler - need 7-12 Mhz on module clk
#endif
I2caRegs.I2CCLKL = 10; // NOTE: must be non zero
I2caRegs.I2CCLKH = 5; // NOTE: must be non zero
I2caRegs.I2CIER.all = 0x00; // Enable SCD & ARDY interrupts
I2caRegs.I2CMDR.all = 0x0020; // Take I2C out of reset
// Stop I2C when suspended
I2caRegs.I2CFFTX.all = 0x0000; // Enable FIFO mode and TXFIFO
I2caRegs.I2CFFRX.all = 0x0000; // Enable RXFIFO, clear RXFFINT,
return;
4、执行I2C模块接收或者发送。
//I2C模块发送数据到I2C器件。
void I2CA_SendData(void)
Uint16 i;
I2caRegs.I2CSAR = I2C_SLAVE_ADDR; //Set slave address
I2caRegs.I2CCNT = I2C_NUMBYTES + 2; //Set count to 5 characters plus 2 address bytes
I2caRegs.I2CDXR = I2C_EEPROM_HIGH_ADDR; //Send eeprom high address
I2caRegs.I2CMDR.bit.TRX = 1; //Set to Transmit mode
I2caRegs.I2CMDR.bit.MST = 1; //Set to Master mode
I2caRegs.I2CMDR.bit.FREE = 1; //Run in FREE mode
I2caRegs.I2CMDR.bit.STP = 1; //Stop when internal counter becomes 0
I2caRegs.I2CMDR.bit.STT = 1; //Send the start bit, transmission will follow
while(I2caRegs.I2CSTR.bit.XRDY == 0){}; //Do nothing till data is shifted out
I2caRegs.I2CDXR = I2C_EEPROM_LOW_ADDR; //Send eeprom low address
for(i = 0; i < I2C_NUMBYTES; i++){
I2caRegs.I2CDXR = TxdData; //Send out the message
//I2C模块从I2C器件接收数据。
void I2CA_ReceiveData(void)
Uint16 i;
I2caRegs.I2CCNT = 2; //Set count to 2 address bytes
I2caRegs.I2CMDR.bit.STP = 0; //Dont release the bus after Tx
I2caRegs.I2CCNT = I2C_NUMBYTES; //read 5 bytes from eeprom
I2caRegs.I2CMDR.bit.TRX = 0; //Set to Recieve mode
I2caRegs.I2CMDR.bit.STT = 1; //Repeated start, Reception will follow
while(I2caRegs.I2CSTR.bit.RRDY == 0){}; //I2CDRR not ready to read?
RxdData = I2caRegs.I2CDRR;
测试程序见26楼。
【富士通FRAM心得提交——MB85RC64】一文使用的就是C2000 LaunchPad(F28027)I2C模块对FRAM进行测试。可供大家参考。
https://bbs.eeworld.com.cn/thread-427610-1-1.html
TI官方的I2C程序就像玩具,不中用,大家只能探讨补全了。
给什么样的例子。楼主讲的还不够详细吗,具体的要自己去做。
给你个源码对你没有任何帮助。我已经讲的太详细了,你把我提到的整合一起就能成功,动动手对你的帮助才是最大的。
I2C模块是不是只有I2CCNT 减到0才会发出停止信号??
I2C模块是硬件的,当检测到发送完了就会发结束自动发信号,不需要人为干预
24c02的话,传送完器件地址以后不是只要传送一个字节的地址吗??为什么有high adress 和low adress
24c02地址只有一个字节。24c64地址有个2个字节。自己想想或者查资料
谢谢,楼主,看了上面的程序,还有几个问题请教,发送或接收数据之前还用查询一下总线的状态吗比如
if (I2caRegs.I2CMDR.bit.STP == 1) 和 if (I2caRegs.I2CSTR.bit.BB == 1)
还有为什么要先把地址写进DXR寄存器再写MDR寄存器
发送/接收的时候无需人为判断总线状态。因为28027中的I2C模块是纯硬件的,硬件自己会去检测,在总线空闲的时候发送/接收。
“还有为什么要先把地址写进DXR寄存器再写MDR寄存器”没搞懂你的意思想说什么
楼主你好 我按照你的跑了一下 但是不成功啊,能帮帮我吗?或者给一个源程序,我想参考下;
