[uCOS/uCGUI] ucos-ii的移植代码分析
wantedlife   2014-1-13 21:35 楼主
移植的代码中,在时钟SysTick_Handler中OSIntExit()进行任务切换;
其中OSIntExit()的代码为:
void  OSIntExit (void)
#if OS_CRITICAL_METHOD == 3                                /* Allocate storage for CPU status register */
    OS_CPU_SR  cpu_sr;
#endif
    if (OSRunning == TRUE) {
        OS_ENTER_CRITICAL();
        if (OSIntNesting > 0) {                            /* Prevent OSIntNesting from wrapping       */
            OSIntNesting--;
        if ((OSIntNesting == 0) && (OSLockNesting == 0)) { /* Reschedule only if all ISRs complete ... */
            OSIntExitY    = OSUnMapTbl[OSRdyGrp];          /* ... and not locked.                      */
            OSPrioHighRdy = (INT8U)((OSIntExitY << 3) + OSUnMapTbl[OSRdyTbl[OSIntExitY]]);
            if (OSPrioHighRdy != OSPrioCur) {              /* No Ctx Sw if current task is highest rdy */
                OSTCBHighRdy  = OSTCBPrioTbl[OSPrioHighRdy];
                OSCtxSwCtr++;                              /* Keep track of the number of ctx switches */
                OSIntCtxSw();                              /* Perform interrupt level ctx switch       */
        OS_EXIT_CRITICAL();
在void  OSIntExit (void)中调用OSIntCtxSw(),触发PendSV_Handler实现任务切换。问题在于调用OSIntCtxSw()前
已经使用OS_ENTER_CRITICAL()禁止异常,为什么还可以触发PendSV_Handler?困扰多时,请大家指教。
回复评论
暂无评论,赶紧抢沙发吧
    写回复
