[讨论] IAR的系统变量
dontium   2014-2-17 22:55 楼主
Variable
$CONFIG_NAME$
The name of the current build  configuration, for example Debug or Release.
$CUR_DIR$
Current directory
$CUR_LINE$
Current line
$DATE$
Today’s date
$EW_DIR$
Top directory of IAR Embedded  Workbench, for example c:\program  files\iar systems\embedded workbench 6.n
$EXE_DIR$
Directory for executable output
$FILE_BNAME$
Filename without extension
$FILE_BPATH$
Full path without extension
$FILE_DIR$
Directory of active file, no  filename
$FILE_FNAME$
Filename of active file without  path
$FILE_PATH$
Full path of active file (in  Editor, Project, or Message window)
$LIST_DIR$
Directory for list output
$OBJ_DIR$
Directory for object output
$PROJ_DIR$
Project directory
$PROJ_FNAME$
Project filename without path
$PROJ_PATH$
Full path of project file
$TARGET_DIR$
Directory of primary output  file
$TARGET_BNAME$
Filename without path of  primary output file and without extension
$TARGET_BPATH$
Full path of primary output  file without extension
$TARGET_FNAME$
$TARGET_PATH$
$TOOLKIT_DIR$
Directory of the active  product, for example c:\program  files\iar systems\embedded workbench 6.n\arm
$USER_NAME$
Your host login name
$_ENVVAR_$
The environment variable ENVVAR. Any name within $_ and _$ will be expanded to  that system environment variable.
回复评论
暂无评论,赶紧抢沙发吧
    写回复
