STM32F429i Discovery还有一个陀螺仪,如果不能把它也搞起来,那有点太浪费STM的感情了。
好,那么本辑内容我们就来玩玩陀螺仪。
准备工程,就使用示例中的MEMS_Example
通过学习代码,了解到其中这个函数:
- static void Demo_MEMS(void)
- /* Read Gyro Angular data */
- Demo_GyroReadAngRate(Buffer);
- Buffer[0] = (int8_t)Buffer[0] - (int8_t)Gyro[0];
- Buffer[1] = (int8_t)Buffer[1] - (int8_t)Gyro[1];
- /* Update autoreload and capture compare registers value*/
- Xval = ABS((int8_t)(Buffer[0]));
- Yval = ABS((int8_t)(Buffer[1]));
- if ( Xval>Yval)
- if ((int16_t)Buffer[0] > 40)
- /* Clear the LCD */
- LCD_Clear(LCD_COLOR_WHITE);
- LCD_SetTextColor(LCD_COLOR_MAGENTA);
- LCD_DrawFullRect(100, 40, 40, 120);
- LCD_FillTriangle(50, 190, 120, 160, 160, 310);
- Delay(50);
- if ((int16_t)Buffer[0] < -40)
- LCD_SetTextColor(LCD_COLOR_RED);
- LCD_DrawFullRect(100, 160, 40, 120);
- LCD_FillTriangle(50, 190, 120, 160, 160, 10);
- Delay(50);
- else
- if ((int16_t)Buffer[1] < -40)
- LCD_SetTextColor(LCD_COLOR_GREEN);
- LCD_DrawFullRect(120, 140, 100, 40);
- LCD_FillTriangle(120, 120, 5, 60, 260, 160);
- Delay(50);
- if ((int16_t)Buffer[1] > 40)
- LCD_SetTextColor(LCD_COLOR_BLUE);
- LCD_DrawFullRect(20, 140, 100, 40);
- LCD_FillTriangle(120, 120, 235, 60, 260, 160);
- Delay(50);
以上这些就是使用陀螺仪的关键代码啦,关于陀螺仪初始化等等的内容,我们完全可以利用示例工程的资源。
那么接下来我们就来玩转上面这个函数吧。
当然,首先根据示例,我们把三个方向的角度都取出来:
- Buffer[0] = Buffer[0] - Gyro[0];
- Buffer[1] = Buffer[1] - Gyro[1];
- Buffer[2] = Buffer[2] - Gyro[2];
……为了玩转嘛,楼主又准备了一个可以转的函数,这里免费提供给大家。
- #include "math.h"
- * 3D Cube
- #define CUBE_HALF_A 70
- typedef unsigned char u8_t;
- typedef float pos_t; /* position */
- typedef float rad_t; /* radian */
- typedef struct{
- pos_t x;
- pos_t y;
- }d2pos_t; /* 2D point type */
- typedef struct{
- pos_t x;
- pos_t y;
- pos_t z;
- }d3pos_t; /* 3D point type */
- typedef struct{
- rad_t x;
- rad_t y;
- rad_t z;
- }d3rad_t; /* 3D radian type */
- typedef const u8_t * surface_t;
- typedef struct{
- u8_t vert_count;
- u8_t face_count;
- d3pos_t *vertexes;
- surface_t *surfaces;
- d3pos_t pos;
- d3rad_t rad;
- }poly_t;
- d3pos_t cube_pos[8]={
- { CUBE_HALF_A, CUBE_HALF_A, CUBE_HALF_A},
- {-CUBE_HALF_A, CUBE_HALF_A, CUBE_HALF_A},
- {-CUBE_HALF_A, -CUBE_HALF_A, CUBE_HALF_A},
- { CUBE_HALF_A, -CUBE_HALF_A, CUBE_HALF_A},
- { CUBE_HALF_A, CUBE_HALF_A, -CUBE_HALF_A},
- {-CUBE_HALF_A, CUBE_HALF_A, -CUBE_HALF_A},
- {-CUBE_HALF_A, -CUBE_HALF_A, -CUBE_HALF_A},
- { CUBE_HALF_A, -CUBE_HALF_A, -CUBE_HALF_A}
- const u8_t cube_face1[]={0, 1, 2, 3, 0};
- const u8_t cube_face2[]={0, 3, 7, 4, 0};
- const u8_t cube_face3[]={0, 4, 5, 1, 0};
- const u8_t cube_face4[]={6, 5, 4, 7, 6};
- const u8_t cube_face5[]={6, 2, 1, 5, 6};
- const u8_t cube_face6[]={6, 7, 3, 2, 6};
- surface_t cube_faces[6]={
- cube_face1,cube_face2,cube_face3,cube_face4,cube_face5,cube_face6
- poly_t cube_A = {
- 8,
- 6,
- cube_pos,
- cube_faces,
- {0,0,0},
- {0,0,0}
- static void draw_line(int ax, int ay, int bx, int by);
- void d3_draw(poly_t * poly_p, float eye_z, float screen_z)
- d2pos_t d2p[8];
- int i, j;
- float Yn;
- float x[8],y[8],z[8],xt,yt,zt,sinax,cosax,sinay,cosay,sinaz,cosaz;
- int sx,sy,mx,my,ex,ey;
- sinax = sin(poly_p->rad.x); // precalculate the sin and cos values
- cosax = cos(poly_p->rad.x);
- sinay = sin(poly_p->rad.y);
- cosay = cos(poly_p->rad.y);
- sinaz = sin(poly_p->rad.z);
- cosaz = cos(poly_p->rad.z);
- for (i = 0; i < poly_p->vert_count; i++) // translate 3d vertex position to 2d screen position
- x[i]=poly_p->vertexes[i].x; // get current position x
- y[i]=poly_p->vertexes[i].y; // get current position y
- z[i]=poly_p->vertexes[i].z; // get current position z
- yt = y[i] * cosax - z[i] * sinax; // rotate around X axis
- zt = y[i] * sinax + z[i] * cosax;
- y[i] = yt;
- z[i] = zt;
- xt = x[i] * cosay - z[i] * sinay; // rotate around Y axis
- zt = x[i] * sinay + z[i] * cosay;
- x[i] = xt;
- z[i] = zt;
- xt = x[i] * cosaz - y[i] * sinaz; // rotate around Z axis
- yt = x[i] * sinaz + y[i] * cosaz;
- x[i] = xt;
- y[i] = yt;
- x[i] += poly_p->pos.x; // calc the new position x
- y[i] += poly_p->pos.y; // calc the new position y
- z[i] += poly_p->pos.z; // calc the new position Z
- z[i] = (eye_z - screen_z) / (eye_z - z[i]);
- d2p[i].x = x[i] * z[i]; // translate 3d to 2d
- d2p[i].y = y[i] * z[i]; // translate 3d to 2d
- for (i = 0; i < poly_p->face_count; i++) // draw each surface of the object
- sx = x[poly_p->surfaces[i][0]];
- sy = y[poly_p->surfaces[i][0]];
- mx = x[poly_p->surfaces[i][1]];
- my = y[poly_p->surfaces[i][1]];
- ex = x[poly_p->surfaces[i][2]];
- ey = y[poly_p->surfaces[i][2]];
- Yn = (ex-mx)*(sy-my)-(sx-mx)*(ey-my); // check direction of the surface
- if(Yn > 0) // draw it if face to us
- j = 0;
- do{
- j++;
- sx=d2p[poly_p->surfaces[i][j-1]].x; // set line start x
- sy=d2p[poly_p->surfaces[i][j-1]].y; // set line start y
- ex=d2p[poly_p->surfaces[i][j]].x; // set line end x
- ey=d2p[poly_p->surfaces[i][j]].y; // set line end y
- draw_line(sx,sy,ex,ey);
- }while(poly_p->surfaces[i][0] != poly_p->surfaces[i][j]);
- void draw_line(int ax, int ay, int bx, int by)
- ax+=110;
- ay+=110;
- bx+=110;
- by+=110;
- LCD_DrawUniLine(ax,ay,bx,by);
draw_line里面对坐标的修正是因为硬件的坐标原点在角落里,要移动到屏幕中间来,我比较懒,没有移到正中间,而是偏向一侧了。
使用的时候呢,只需要
- cube_A.rad.x = rotatex;
- cube_A.rad.y = rotatey;
- cube_A.rad.z = rotatez;
- d3_draw(&cube_A, 10000, 1000);
注意就是那三个参数,第一个表示描画对象;第二个是指视点的坐标,越大透视效果越差但是消隐越正确;第三个是投影面的坐标,应当小于视点坐标,并且越小画面越大。
最后就是玩转了,随个人喜好来玩吧
我就简单转了一小下吧,抛砖引玉啦
本辑没有工程分享啦,因为关键代码全部展示在上面了,自己贴一贴吧。
完。
