Compare Parts | |||
Status | ACTIVE | ACTIVE | ACTIVE |
Applications | Video Security Thin Client Video Conferencing Video Phones | Video Security Thin Client Video Conferncing Video Phones | Video Surveillance |
Operating Systems | Linux Android DSP/BIOS | Linux DSP/BIOS | Linux DSP/BIOS |
DSP | 1 C674x | 1 C674x | 1 C674x |
DSP Instruction Type | Fixed and Floating Point | Fixed and Floating Point | Fixed and Floating Point |
DSP MHz (Max.) | 1000 | 750 | 750 |
DSP Peak MMACS | 12000 | 6000 | 6000 |
ARM CPU | 1 ARM Cortex-A8 | 1 ARM Cortex-A8 | 1 ARM Cortex-A8 |
ARM MHz (Max.) | 1200 | 1000 | 1000 |
ARM MIPS (Max.) | 2400 | 2000 | 2000 |
Graphics Acceleration | 1 3D | 1 3D | |
Video Acceleration | 3 HDVICPs | 1 HDVICP | 1 HDVICP |
Video Capability | Decode Encode Multi-Channel Transcode Multi-format Analytics Image Enhance Deinterlacing Scaling | Decode Encode Multi-Channel Transcode Multi-format Analytics Image Enhance Deinterlacing Scaling | Decode Encode Multi-Channel Transcode Multi-format Analytics Image Enhance Deinterlacing Scaling |
TI Video Codecs | H.264 BP/MP/HP MPEG-4 MPEG-2 JPEG/MJPEG | H.264 BP/MP/HP MPEG-4 MPEG-2 JPEG/MJPEG | H.264 BP/MP/HP MPEG-4 MPEG-2 JPEG/MJPEG |
Video Resolution/Frame Rate | 1080p 60 FPS or less | 1080p 60 FPS or less | 1080p 60 FPS or less |
TI Audio Codecs | AAC-LC/HE G.711 MP3 | AAC-LC/HE G.711 MP3 | AAC-LC/HE G.711 MP3 |
On-Chip L1 Cache | 64 KB (ARM Cortex-A8) 64 KB (DSP) | 64 KB (ARM Cortex-A8) 64 KB (DSP) | 64 KB (ARM Cortex-A8) 64 KB (DSP) |
On-Chip L2 Cache | 256 KB (ARM Cortex-A8) 256 KB (DSP) | 512 KB (ARM) 256 KB (DSP) | 256 KB (ARM) 256 KB (DSP) |
Other On-Chip Memory | 512 KB | 128 KB | 128 KB |
General Purpose Memory | 1 16-bit GPMC NAND flash NOR Flash Pseudo-SRAM SRAM | 1 16-bit GPMC LPDDR NAND flash NOR Flash Pseudo-SRAM SRAM | 1 16-bit GPMC LPDDR NAND flash NOR Flash Pseudo-SRAM SRAM |
DRAM | 2 32-bit (DDR2-800 DDR3-1600) | 2 32-bit (DDR2-800 DDR3-800 LPDDR-400) | 2 32-bit (DDR2-800 DDR3-800 LPDDR-400) |
USB | 2 | 2 | 2 |
EMAC | 2x 10/100/1000 | 10/100/1000 | 10/100/1000 |
PCI/PCIe | 1 2-lane | PCIe | PCIe |
SATA | 2 | 1 | |
MMC/SD | 1 SD/SDIO | 3 | 1 |
UART (SCI) | 3 | 6 | 6 |
I2C | 2 | 4 | 4 |
McBSP | 1 | 1 | |
McASP | 3 | 6 | 6 |
SPI | 1 | 4 | 4 |
引用: boman 发表于 2015-8-22 22:17
打算用8168做ISP算法,是用什么开发平台合适呢? EZSDK还是DVRRDK?
