首先,在
http://downloads.angstrom-distribution.org/demo/beaglebone/下载更新包
7zip解压
使用win32diskimager烧写工具,将解压缩后的镜像文件烧录至microSD卡中
插进Beaglebone-Black SD卡卡槽,按住uSD BOOT按钮
将usb转TTL设备接在BBB板子上,串口打印信息如下
U-Boot SPL 2013.04-dirty (Jun 19 2013 - 09:57:14)
musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, HB-ISO Rx, HB-ISO Tx, SoftConn)
musb-hdrc: MHDRC RTL version 2.0
musb-hdrc: setup fifo_mode 4
musb-hdrc: 28/31 max ep, 16384/16384 memory
USB Peripheral mode controller at 47401000 using PIO, IRQ 0
USB Host mode controller at 47401800 using PIO, IRQ 0
OMAP SD/MMC: 0
reading u-boot.img
reading u-boot.img
U-Boot 2013.04-dirty (Jun 19 2013 - 09:57:14)
I2C: ready
DRAM: 512 MiB
WARNING: Caches not enabled
NAND: No NAND device found!!!
0 MiB
MMC: OMAP SD/MMC: 0, OMAP SD/MMC: 1
*** Warning - readenv() failed, using default environment
Net:
not set. Validating first E-fuse MAC
cpsw, usb_ether
Hit any key to stop autoboot: 0
gpio: pin 53 (gpio 53) value is 1
mmc0 is current device
micro SD card found
gpio: pin 54 (gpio 54) value is 1
SD/MMC found on device 0
reading uEnv.txt
14 bytes read in 3 ms (3.9 KiB/s)
Loaded environment from uEnv.txt
Importing environment from mmc ...
gpio: pin 55 (gpio 55) value is 1
4270840 bytes read in 751 ms (5.4 MiB/s)
gpio: pin 56 (gpio 56) value is 1
24125 bytes read in 46 ms (511.7 KiB/s)
Booting from mmc ...
## Booting kernel from Legacy Image at 80007fc0 ...
Image Name: Angstrom/3.8.13/beaglebone
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 4270776 Bytes = 4.1 MiB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum ... OK
## Flattened Device Tree blob at 80f80000
Booting using the fdt blob at 0x80f80000
XIP Kernel Image ... OK
OK
Using Device Tree in place at 80f80000, end 80f88e3c
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
[ 0.194340] omap2_mbox_probe: platform not supported
[ 0.204997] tps65217-bl tps65217-bl: no platform data provided
[ 0.281461] bone-capemgr bone_capemgr.9: slot #0: No cape found
[ 0.318567] bone-capemgr bone_capemgr.9: slot #1: No cape found
[ 0.355678] bone-capemgr bone_capemgr.9: slot #2: No cape found
[ 0.392786] bone-capemgr bone_capemgr.9: slot #3: No cape found
[ 0.412352] bone-capemgr bone_capemgr.9: slot #6: BB-BONELT-HDMIN conflict P8.45 (#5:BB-BONELT-HDMI)
[ 0.421948] bone-capemgr bone_capemgr.9: slot #6: Failed verification
[ 0.428720] bone-capemgr bone_capemgr.9: loader: failed to load slot-6 BB-BONELT-HDMIN:00A0 (prio 2)
[ 0.451267] omap_hsmmc mmc.4: of_parse_phandle_with_args of 'reset' failed
[ 0.516348] pinctrl-single 44e10800.pinmux: pin 44e10854 already requested by 44e10800.pinmux; cannot claim for gpio-leds.8
[ 0.528064] pinctrl-single 44e10800.pinmux: pin-21 (gpio-leds.8) status -22
[ 0.535380] pinctrl-single 44e10800.pinmux: could not request pin 21 on device pinctrl-single
[ 120.197457] INFO: task swapper/0:1 blocked for more than 60 seconds.
[ 120.204112] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[ 120.212325] Kernel panic - not syncing: hung_task: blocked tasks
[ 120.218620] [] (unwind_backtrace+0x1/0x8c) from [] (panic+0x55/0x14c)
[ 120.227163] [] (panic+0x55/0x14c) from [] (watchdog+0x153/0x1a0)
[ 120.235245] [] (watchdog+0x153/0x1a0) from [] (kthread+0x61/0x72)
[ 120.243426] [] (kthread+0x61/0x72) from [] (ret_from_fork+0x11/0x34)
[ 120.251869] drm_kms_helper: panic occurred, switching back to text console
请教各位,能帮我定位一下问题点在哪里吗
