一开始运行都是正常的,只是在跑一个USB的例程时不知道什么原因CCS无响应,强制关闭也没用,就直接拔掉了仿真器,CCS立刻就关了,重启后2812就和CCS没法连接了,然后卸载了CCS又重新装一遍,还有SEED-XDSUSB2.0的驱动也重新装了,都是用的和以前一样的安装文件,可是还是没法连接,显示错误是
error connecting to the target:
Error 0x80000240/-171
Fatal Error during: Initialization, OCS,
This error was generated by TI's USCIF driver.
SC_ERR_REG_DETECT_CTLR <-171>
The wrong controller port value has been used.
A controller cannot be detected even though the
selected port does match the hardware configuration.
The standard 560 ports are 0x0, 0x1, 0x2 and 0x3.
The standard EVM ports are 0x0, 0x1, 0x2 and 0x3.
The standard DSK ports are 0x378, 0x278 and 0x3BC.
The standard 510 ports are 0x240, 0x280, 0x320 and 0x340.
Sequence ID: 0
Error Code: -171
Error Class: 0x80000240
I/O Port = 240
Board Name: F2812 XDS510 Emulator
Cpu Name: CPU_1
Abort: Close Code Composer Studio.
Retry: Try to connect to the target again.
Cancel: Remain disconnected from the target
Diagnostic: Run diagnostic utility.
可是同一块开发板和仿真器在另一台机子上可以顺利运行,是安装出错了吗还是哪里需要设置一下?
重启过,不行,不过刚刚解决了,卸载了仿真器驱动重新装了一次,就好了,还是谢谢你啦
我用CCS3.3也经常出这个问题。不过不是每次都这样,总得来说也不太多,就没追究过,应该是驱动和仿真器通讯异常了,CCS上就一直在等待某个条件就绪,从而卡死
