[讨论] 【转载】apk 打包方法
Wince.Android   2014-5-8 17:00 楼主
对于Android系统集成有源码的第三方库和程序,只需要提供Android.mk文件,把源码集成到 Android编译系统中就可以了,并且有很多例子可以参考。但是对于没有源码的pre-build第三方库和程序,网上介绍的比较少,可以参考的例子也不多。本文简单介绍一下集成pre-build库和程序时候,怎样编写Android.mk。
1、集成静态库 [xhtml] view plaincopyprint?
  • 1: LOCAL_PATH := $(call my-dir)
  • 2: include $(CLEAR_VARS)
  • 3:
  • 4: LOCAL_PREBUILT_LIBS := libA.a    /
  • 5:                        libB.a
  • 6:
  • 7: LOCAL_STATIC_LIBRARIES := libA    /
  • 8:                         libB
  • 9:
  • 0: include $(BUILD_MULTI_PREBUILT)
   1: LOCAL_PATH := $(call my-dir)   2: include $(CLEAR_VARS)   3:     4: LOCAL_PREBUILT_LIBS := libA.a    /   5:                        libB.a   6:                            7: LOCAL_STATIC_LIBRARIES := libA    /   8:                         libB   9:    10: include $(BUILD_MULTI_PREBUILT)
2、集成动态库 [c-sharp] view plaincopyprint?
  • 3:
  • 4: LOCAL_PREBUILT_LIBS := libA.so
  • 5:                         libB.so
  • 6: include $(BUILD_MULTI_PREBUILT)
   1: LOCAL_PATH := $(call my-dir)   2: include $(CLEAR_VARS)   3:     4: LOCAL_PREBUILT_LIBS := libA.so   5:                         libB.so   6: include $(BUILD_MULTI_PREBUILT)
3、集成可执行程序
  • 3:
  • 4: LOCAL_SRC_FILES := hellovprc.elf
  • 5: LOCAL_MODULE := hellovprc.elf
  • 6: LOCAL_MODULE_CLASS := EXECUTABLES
  • 7: LOCAL_MODULE_TAGS := debug
  • 8: include $(BUILD_PREBUILT)
   1: LOCAL_PATH := $(call my-dir)   2: include $(CLEAR_VARS)   3:     4: LOCAL_SRC_FILES := hellovprc.elf    5: LOCAL_MODULE := hellovprc.elf   6: LOCAL_MODULE_CLASS := EXECUTABLES   7: LOCAL_MODULE_TAGS := debug   8: include $(BUILD_PREBUILT)
4、集成pre-build Android应用程序(APK) 如何集成没有源码的apk文件,纯粹的apk呢?
方法一、目录结构vendor/BM/APPs/MobileQQ2011/MobileQQ2011.apk
            vendor/BM/APPs/MobileQQ2011/Android.mk
以下是Android.mk:
  •   LOCAL_PATH := $(call my-dir)
  •   include $(CLEAR_VARS)
  •   # Module name should match apk name to be installed.
  •   LOCAL_MODULE := MobileQQ2011
  •   LOCAL_SRC_FILES := $(LOCAL_MODULE).apk
  •   LOCAL_MODULE_CLASS := APPS
  •   LOCAL_MODULE_SUFFIX := $(COMMON_ANDROID_PACKAGE_SUFFIX)
  • #  LOCAL_MODULE_TAGS := user
  • #add by yue @20110516
  •   #you can choose apk's diff location
  • # LOCAL_MODULE_PATH := $(TARGET_OUT_APPS)
  •    LOCAL_MODULE_PATH := $(TARGET_OUT_DATA_APPS)
  •   LOCAL_CERTIFICATE := platform
  • #end
  • include $(BUILD_PREBUILT)
  LOCAL_PATH := $(call my-dir)  include $(CLEAR_VARS)     # Module name should match apk name to be installed.  LOCAL_MODULE := MobileQQ2011  LOCAL_SRC_FILES := $(LOCAL_MODULE).apk  LOCAL_MODULE_CLASS := APPS  LOCAL_MODULE_SUFFIX := $(COMMON_ANDROID_PACKAGE_SUFFIX)  #  LOCAL_MODULE_TAGS := user#add by yue @20110516  #you can choose apk's diff location  # LOCAL_MODULE_PATH := $(TARGET_OUT_APPS)   LOCAL_MODULE_PATH := $(TARGET_OUT_DATA_APPS)  LOCAL_CERTIFICATE := platform#end include $(BUILD_PREBUILT)
加进去后,在根目录下执行:make即可,
可以在installed-files.txt中查看是否加入到了对应的img文件中。
弊端是如果加入很多apk,要逐个建立这样的目录结构,也因为有android.mk,会产生相应的临时文件
方法二、纯粹拷贝apk文件
目录结构vendor/BM/APPs/MobileQQ2011.apk
            vendor/BM/APPs/Renren_Android_3.0.2.apk
通过android提供的PRODUCT_COPY_FILES这个变量来自动拷贝,只需要给此变量赋值。在任何一个确定加入编译的mk文件
中加入(我的是加在msm7627_qrd.mk)
PRODUCT_COPY_FILES += /
    vendor/bm/APPS/MobileQQ2011.apk:system/app/MobileQQ2011.apk/
    vendor/bm/APPS/Renren_Android_3.0.2.apk:system/app/Renren_Android_3.0.2.apk
这种相对不会很繁琐,不需要一级级的建立目录,在内置很多apk是比较方便。
附加说明: 关于android.mk中的LOCAL_OVERRIDES_PACKAGES需要说明一下,
此变量可以使其他的模块不加入编译,如源码中DeskClock的android.mk有
LOCAL_OVERRIDES_PACKAGES := AlarmClock
使 AlarmClock不会加入到编译系统中,不会生成 AlarmClock.apk。
原先我是死活不明白会什么有两个闹钟 AlarmClock和 DeskClock ,源码几乎相同,原先只在 AlarmClock中的文件中修改,就是没有效果,测试说没有修改,原来发布的版本中只有DeckClock.apk,我却在本地make AlarmClock编译出了AlarmClock.apk,>_
试了一下在 DeskClock的android.mk中加入LOCAL_OVERRIDES_PACKAGES := Calendar,删掉 Calendar.apk, 然后全部make一下,在system/app下calendar.apk竟然没再生成了????!!!
p.s
# Some packages may override others using LOCAL_OVERRIDES_PACKAGES.
# Filter out (do not install) any overridden packages.
overridden_packages := $(call get-package-overrides,$(modules_to_install))
ifdef overridden_packages
#  old_modules_to_install := $(modules_to_install)
  modules_to_install := /
      $(filter-out $(foreach p,$(overridden_packages),$(p) %/$(p).apk), /
endif
其他参考: 1.对Android.mk文件中变量做了详细说明
    http://www.cnblogs.com/leaven/archive/2011/03/30/1999350.html
2. Android.mk文件语法规范
   http://apps.hi.baidu.com/share/detail/15447104
如果对linux,Android,wince 等嵌入式底层有兴趣的,请加这个QQ群吧,群号:27100460
回复评论
暂无评论,赶紧抢沙发吧
    写回复
