基本上是按照手册做的,一次操作成功还是蛮高兴的!觉得HELPER2416对于咱这种初学者来说,做的最周到的就是那本详尽的开发手册了,开发步骤很相近,对于操作中可能出现的问题也讲解的很到位,比如我已开始看手册不仔细
,结果在一开始烧写到SD时总是提示无法烧录
,觉得可能是SD卡的原因就换了张SD卡,还是老问题,无法烧录
。唉,没办法,继续看手册,结果注意事项里看到“WIN7下以管理员身份运行软件”,马上操作一遍,果然,秒刷到位。紧接着的按照手册说明一步步继续执行就可以了!整体来说是很快的,三分钟以内吧!
首次执行的时候会让校准触摸屏,如下所示:
接下来贴一下PUTTY打印的信息:
- OK
- U-Boot 1.3.4 (Mar 4 2014 - 16:23:56) for SMDK2416
- CPU: S3C2416@534MHz
- Fclk = 534MHz, Hclk = 133MHz, Pclk = 66MHz
- Board: SMDK2416 DDR2
- DRAM: 64 MB
- Flash: 1 MB
- SD/MMC: 15087MB
- NAND: 256 MB
- SD/MMC: After SD/MMC boot
- *** Warning - bad CRC or moviNAND, using default environment
- In: serial
- Out: serial
- Err: serial
- smc911x: MAC 00:40:5c:26:0a:5b
- Hit any key to stop autoboot: 0
- NAND scrub: device 0 whole chip
- Warning: scrub option will erase all factory set bad blocks!
- There is no reliable way to recover them.
- Use this command only for testing purposes if you
- are sure of what you are doing!
- Erasing at 0x3ae0000 -- 23% complete.
- NAND 256MiB 3,3V 8-bit: MTD Erase failure: -5
- Erasing at 0x47a0000 -- 28% complete.
- Erasing at 0x4a20000 -- 29% complete.
- Erasing at 0xffe0000 -- 100% complete.
- Scanning device for bad blocks
- s3c-nand: ECC uncorrectable error detected
- OK
- NAND erase: device 0 whole chip
- Skipping bad block at 0x03c00000
- Skipping bad block at 0x04920000
- Skipping bad block at 0x04a40000
- OK
- Reading data from sector 3800000 (512 sectors).. completed
- NAND write: device 0 offset 0x0, size 0x40000
- 262144 bytes written: OK
- Reading kernel from sector 30887886 (8192 sectors).. completed
- NAND write: device 0 offset 0x40000, size 0x300000
- Writing data at 0x33f800 -- 100% complete.
- 3145728 bytes written: OK
- Reading data from sector 3600000 (117942 sectors).. completed
- NAND write: device 0 offset 0x600000, size 0x3996c00
- Bad block at 0x3c00000 in erase block from 0x3c00000 will be skipped
- Writing data at 0x3df7800 -- 100% complete.
- 60386304 bytes written: OK
- Helper2416 # ls
- Unknown command 'ls' - try 'help'
- Helper2416 # ▒OK
- U-Boot 1.3.4 (Mar 4 2014 - 16:19:04) for SMDK2416
- DRAM: 64 MB
- Flash: 1 MB
- NAND: 256 MB
- *** Warning - bad CRC or NAND, using default environment
- In: serial
- Out: serial
- Err: serial
- NAND read: device 0 offset 0x40000, size 0x300000
- Reading data from 0x33f800 -- 100% complete.
- 3145728 bytes read: OK
- Boot with zImage
- Starting kernel ...
- Uncompressing Linux... done, booting the kernel.
- Linux version 3.2.50+ (d02cj@LinuxServer0) (gcc version 4.4.6 (crosstool-NG 1.13.3) ) #407 Mon Feb 24 22:49:49 CST 2014
- CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177
- CPU: VIVT data cache, VIVT instruction cache
- Machine: SMDK2416
- Memory policy: ECC disabled, Data cache writeback
- CPU S3C2416/S3C2450 (id 0x32450003)
- S3C24XX Clocks, Copyright 2004 Simtec Electronics
- CPU: MPLL on 534.000 MHz, cpu 534.000 MHz, mem 133.500 MHz, pclk 66.750 MHz
- CPU: EPLL on 96.000 MHz, usb-bus 48.000 MHz
- Built 1 zonelists in Zone order, mobility grouping on. Total pages: 16256
- Kernel command line: root=/dev/mtdblock2 console=ttySAC0,115200 rootfstype=yaffs2 mem=64m
- PID hash table entries: 256 (order: -2, 1024 bytes)
- Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
- Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
- Memory: 64MB = 64MB total
- Memory: 59612k/59612k available, 5924k reserved, 0K highmem
- Virtual kernel memory layout:
- vector : 0xffff0000 - 0xffff1000 ( 4 kB)
- fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
- vmalloc : 0xc4800000 - 0xf6000000 ( 792 MB)
- lowmem : 0xc0000000 - 0xc4000000 ( 64 MB)
- modules : 0xbf000000 - 0xc0000000 ( 16 MB)
- .text : 0xc0008000 - 0xc048f598 (4638 kB)
- .init : 0xc0490000 - 0xc04d4000 ( 272 kB)
- .data : 0xc04d4000 - 0xc04ff500 ( 174 kB)
- .bss : 0xc04ff524 - 0xc052c81c ( 181 kB)
- SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
- NR_IRQS:109
- irq: clearing subpending status 00000002
- Console: colour dummy device 80x30
- Calibrating delay loop... 266.03 BogoMIPS (lpj=665088)
- pid_max: default: 32768 minimum: 301
- Mount-cache hash table entries: 512
- CPU: Testing write buffer coherency: ok
- NET: Registered protocol family 16
- S3C Power Management, Copyright 2004 Simtec Electronics
- S3C2416: Initializing architecture
- S3C2416: IRQ Support
- S3C24XX DMA Driver, Copyright 2003-2006 Simtec Electronics
- DMA channel 0 at c4804000, irq 88
- DMA channel 1 at c4804100, irq 89
- DMA channel 2 at c4804200, irq 90
- DMA channel 3 at c4804300, irq 91
- DMA channel 4 at c4804400, irq 92
- DMA channel 5 at c4804500, irq 93
- DMA channel 6 at c4804600, irq 99
- DMA channel 7 at c4804700, irq 100
- bio: create slab at 0
- SCSI subsystem initialized
- usbcore: registered new interface driver usbfs
- usbcore: registered new interface driver hub
- usbcore: registered new device driver usb
- input: helper2416_keypad as /devices/platform/helper2416_keypad/input/input0
- s3c-i2c s3c2410-i2c: slave address 0x10
- s3c-i2c s3c2410-i2c: bus frequency set to 65 KHz
- s3c-i2c s3c2410-i2c: i2c-0: S3C I2C adapter
- Advanced Linux Sound Architecture Driver Version 1.0.24.
- NET: Registered protocol family 2
- IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
- TCP established hash table entries: 2048 (order: 2, 16384 bytes)
- TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
- TCP: Hash tables configured (established 2048 bind 2048)
- TCP reno registered
- UDP hash table entries: 256 (order: 0, 4096 bytes)
- UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
- RPC: Registered named UNIX socket transport module.
- RPC: Registered udp transport module.
- RPC: Registered tcp transport module.
- RPC: Registered tcp NFSv4.1 backchannel transport module.
- NetWinder Floating Point Emulator V0.97 (double precision)
- s3c-adc s3c24xx-adc: attached adc driver
- helper2416 pwm device Driver
- s3c24xx-pwm s3c24xx-pwm.0: tin at 33375000, tdiv at 33375000, tin=divclk, base 0
- s3c24xx-pwm s3c24xx-pwm.1: tin at 33375000, tdiv at 33375000, tin=divclk, base 8
- s3c24xx-pwm s3c24xx-pwm.2: tin at 11125000, tdiv at 11125000, tin=divclk, base 12
- s3c24xx-pwm s3c24xx-pwm.3: tin at 11125000, tdiv at 11125000, tin=divclk, base 16
- nfs4filelayout_init: NFSv4 File Layout Driver Registering...
- NTFS driver 2.1.30 [Flags: R/O].
- JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
- ROMFS MTD (C) 2007 Red Hat, Inc.
- msgmni has been set to 116
- Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
- io scheduler noop registered
- io scheduler deadline registered
- io scheduler cfq registered (default)
- S3C NAND Driver, (c) 2007 Samsung Electronics
- S3C NAND Driver is using hardware ECC.
- NAND device: Manufacturer ID: 0xec, Chip ID: 0xda (Samsung NAND 256MiB 3,3V 8-bit)
- Creating 3 MTD partitions on "NAND 256MiB 3,3V 8-bit":
- 0x000000000000-0x000000040000 : "Bootloader"
- 0x000000040000-0x000000400000 : "Kernel"
- 0x000000400000-0x000010000000 : "File System"
- LCD TYPE :: S3C_4.3inch LCD will be initialized
- S3C_LCD clock got enabled :: 133.500 Mhz
- Window[0]- FB1 : map_video_memory: clear ffd80000:0003fc00
- FB1 : map_video_memory: dma=33980000 cpu=ffd80000 size=0003fc00
- Console: switching to colour frame buffer device 60x34
- fb-1068365652: frame buffer device
- Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
- s3c2440-uart.0: ttySAC0 at MMIO 0x50000000 (irq = 70) is a S3C2440
- console [ttySAC0] enabled
- s3c2440-uart.1: ttySAC1 at MMIO 0x50004000 (irq = 73) is a S3C2440
- s3c2440-uart.2: ttySAC2 at MMIO 0x50008000 (irq = 76) is a S3C2440
- s3c2440-uart.3: ttySAC3 at MMIO 0x5000c000 (irq = 94) is a S3C2440
- lp: driver loaded but no devices found
- ppdev: user-space parallel port driver
- helper2416 adc device Driver
- brd: module loaded
- loop: module loaded
- SCSI Media Changer driver v0.25
- CAN device driver interface
- mcp251x spi0.0: probed
- eth0: LAN9220 (rev 0) at 0x8000000 IRQ 59
- eth0: Ethernet addr: 00:40:5c:26:0a:5b
- PPP generic driver version 2.4.2
- PPP BSD Compression module registered
- PPP Deflate Compression module registered
- PPP MPPE Compression module registered
- nwhw_config: generating random addr...
- nwhw_config: (eth0) setting mac address: 3e:ab:b2:b9:5a:e0
- ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
- s3c2410-ohci s3c2410-ohci: S3C24XX OHCI
- s3c2410-ohci s3c2410-ohci: new USB bus registered, assigned bus number 1
- s3c2410-ohci s3c2410-ohci: irq 42, io mem 0x49000000
- hub 1-0:1.0: USB hub found
- hub 1-0:1.0: 2 ports detected
- usbcore: registered new interface driver cdc_acm
- cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
- Initializing USB Mass Storage driver...
- usbcore: registered new interface driver usb-storage
- USB Mass Storage support registered.
- usbcore: registered new interface driver usbserial
- USB Serial support registered for generic
- usbcore: registered new interface driver usbserial_generic
- usbserial: USB Serial Driver core
- USB Serial support registered for GSM modem (1-port)
- usbcore: registered new interface driver option
- option: v0.7.2:USB Driver for GSM modems
- mousedev: PS/2 mouse device common for all mice
- samsung-ts s3c2410-ts: driver attached, registering input device
- input: S3C24XX TouchScreen as /devices/virtual/input/input1
- S3C24XX RTC, (c) 2004,2006 Simtec Electronics
- s3c-rtc s3c2410-rtc: rtc disabled, re-enabling
- s3c-rtc s3c2410-rtc: rtc core: registered s3c as rtc0
- s3c-rtc s3c2410-rtc: warning: invalid RTC value so initializing it
- i2c /dev entries driver
- S3C2410 Watchdog Timer, (c) 2004 Simtec Electronics
- sdhci: Secure Digital Host Controller Interface driver
- sdhci: Copyright(c) Pierre Ossman
- s3c-sdhci s3c-sdhci.0: clock source 0: hsmmc (133500000 Hz)
- s3c-sdhci s3c-sdhci.0: clock source 1: hsmmc (133500000 Hz)
- s3c-sdhci s3c-sdhci.0: clock source 2: hsmmc-if (96000000 Hz)
- mmc0: SDHCI controller on samsung-hsmmc [s3c-sdhci.0] using ADMA
- s3c-sdhci s3c-sdhci.1: clock source 0: hsmmc (133500000 Hz)
- s3c-sdhci s3c-sdhci.1: clock source 1: hsmmc (133500000 Hz)
- s3c-sdhci s3c-sdhci.1: clock source 2: hsmmc-if (96000000 Hz)
- mmc1: SDHCI controller on samsung-hsmmc [s3c-sdhci.1] using ADMA
- usbcore: registered new interface driver usbhid
- usbhid: USB HID core driver
- asoc: wm8731-hifi <-> s3c24xx-iis mapping ok
- ALSA device list:
- #0: wm8731
- TCP cubic registered
- NET: Registered protocol family 17
- can: controller area network core (rev 20090105 abi 8)
- NET: Registered protocol family 29
- can: raw protocol (rev 20090105)
- can: broadcast manager protocol (rev 20090105 t)
- Registering the dns_resolver key type
- s3c-rtc s3c2410-rtc: setting system clock to 2000-01-01 00:00:01 UTC (946684801)
- yaffs: dev is 32505858 name is "mtdblock2" rw
- yaffs: passed flags ""
- mmc1: new high speed SDHC card at address 59b4
- mmcblk0: mmc1:59b4 NCard 14.7 GiB
- mmcblk0: p1
- VFS: Mounted root (yaffs2 filesystem) on device 31:2.
- Freeing init memory: 272K
- FAT-fs (mmcblk0p1): utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive!
- [31/Dec/1999:16:00:08 +0000] boa: server version Boa/0.94.13
- [31/Dec/1999:16:00:08 +0000] boa: server built Mar 26 2009 at 15:28:42.
- [31/Dec/1999:16:00:08 +0000] boa: starting server pid=74, port 80
- smc911x smc911x: eth0: link down
- Please press Enter to activate this console.
- [root@jyxtec /]# ls
- bin linuxrc root usr
- dev lost+found sbin var
- etc mnt sdcard www
- g_file_storage.ko opt sys
- home proc tmp
- lib qtenv usbdisk
- [root@jyxtec /]# cd /etc
- [root@jyxtec /etc]# ls
- boa inetd.conf mtab scsi_id.config
- eth0-setting init.d passwd sd_card_inserting
- ftpchroot issue.net pointercal sd_card_removing
- ftpusers localtime profile services
- group login.defs protocols usb_inserting
- host.conf mdev.conf rc.d usb_removing
- hosts mime.types resolv.conf
- [root@jyxtec /etc]# cd ..
- home proc tmp
- lib qtenv usbdisk
- [root@jyxtec /]# cd /bin
- [root@jyxtec /bin]# ls
- addgroup dmesg ipaddr mpstat scriptreplay
- adduser dnsdomainname ipcalc mt sed
- ash dumpkmap iplink mv setarch
- base64 echo iproute netstat setserial
- bbconfig ed iprule nice sh
- busybox egrep iptunnel pidof sleep
- cat false kill ping stat
- catv fdflush linux32 ping6 stty
- chattr fgrep linux64 pipe_progress su
- chgrp fsync ln powertop sync
- chmod gdbserver login printenv tar
- chown getopt ls ps touch
- conspy grep lsattr pwd true
- cp gunzip lzop qtopia umount
- cpio gzip makemime raw_bmp uname
- cttyhack hostname mkdir reformime uncompress
- date hotplug mknod rev usleep
- dd hush mktemp rm vi
- delgroup ionice more rmdir watch
- deluser iostat mount rpm zcat
- df ip mountpoint run-parts
- [root@jyxtec /bin]# ps
- PID USER TIME COMMAND
- 1 root 0:03 init
- 2 root 0:00 [kthreadd]
- 3 root 0:00 [ksoftirqd/0]
- 4 root 0:00 [kworker/0:0]
- 5 root 0:00 [kworker/u:0]
- 6 root 0:00 [khelper]
- 7 root 0:00 [netns]
- 8 root 0:00 [sync_supers]
- 9 root 0:00 [bdi-default]
- 10 root 0:00 [kblockd]
- 11 root 0:00 [s3c64xx-spi.0]
- 12 root 0:00 [khubd]
- 13 root 0:00 [helper2416_keyp]
- 14 root 0:00 [rpciod]
- 15 root 0:00 [kswapd0]
- 16 root 0:00 [kworker/0:1]
- 17 root 0:00 [nfsiod]
- 18 root 0:00 [crypto]
- 22 root 0:01 [kworker/u:1]
- 25 root 0:00 [mtdblock0]
- 26 root 0:00 [mtdblock1]
- 27 root 0:00 [mtdblock2]
- 38 root 0:00 [kpsmoused]
- 39 root 0:00 [kworker/u:2]
- 42 root 0:00 [mmcqd/1]
- 43 root 0:00 [yaffs-bg-1]
- 68 root 0:00 syslogd
- 71 root 0:00 /usr/sbin/inetd
- 74 root 0:00 /usr/sbin/boa
- 80 root 0:06 /opt/Qtopia/bin/qpe
- 81 root 0:00 -/bin/sh
- 82 root 0:00 init
- 84 root 0:00 init
- 85 root 0:00 init
- 100 root 0:00 /opt/Qtopia/bin/qss
- 101 root 0:01 /opt/Qtopia/bin/quicklauncher
- 105 root 0:00 [flush-31:2]
- 109 root 0:00 ps
- [root@jyxtec /bin]# dfsdfs
- -/bin/sh: dfsdfs: not found
- [root@jyxtec /bin]# echo $SHELL
- /bin/sh
- [root@jyxtec /bin]# more /etc/shells
- more: /etc/shells: No such file or directory
看到系统默认用的是burne shell (sh) ,果断温习了下shell指令!今天到这吧,明天到UBUNTU上体验下!
