[求助] 求助:今天看了一下intrinsics.h很多不懂啊
成都回锅肉   2014-8-7 10:54 楼主
比如:
void           _never_executed(void );
unsigned short _bcd_add_short(unsigned short, unsigned short);
unsigned long  _bcd_add_long(unsigned long, unsigned long);
unsigned int   _even_in_range(unsigned int, unsigned int);
void           _op_code(unsigned short);
void           _data20_write_char(unsigned long, unsigned char);
void           _data20_write_short(unsigned long, unsigned short);
void           _data20_write_long(unsigned long, unsigned long);
unsigned char  _data20_read_char(unsigned long);
unsigned short _data20_read_short(unsigned long);
unsigned long  _data20_read_long(unsigned long);
unsigned short _get_interrupt_state(void);
void           _set_interrupt_state(unsigned short);
unsigned short _get_SP_register(void);
void           _set_SP_register(unsigned short);
话说有讲解这些东西的资料没?
回复评论 (1)
这个你看函数的名字就应该明白几分了吧。如果有所疑问,可以写个小程序试试结果不就可以了
点赞  2014-8-7 12:26
    写回复
