[原创] 【TI首届低功耗设计大赛】+串口调试
billjing   2014-11-7 22:50 楼主
这次根据下载里面的技术文档进行串口,采用的C语言的库的编程形式,感觉到C语言库带来的方便,再也不用操作具体寄存器了。只需要知道的函数的作用就可以了。SMCLK =  8M  波特率9600 数据位8位,停止位1位,无检验。
void Init_UART()
        // Configure UART
    if ( STATUS_FAIL == EUSCI_A_UART_initAdvance(EUSCI_A0_BASE,
                                                 EUSCI_A_UART_CLOCKSOURCE_SMCLK,
                                                 52,        //波特率9600
                                                 1,
                                                 0x49,
                                                 EUSCI_A_UART_NO_PARITY,
                                                 EUSCI_A_UART_LSB_FIRST,
                                                 EUSCI_A_UART_ONE_STOP_BIT,
                                                 EUSCI_A_UART_MODE,
                                                 EUSCI_A_UART_OVERSAMPLING_BAUDRATE_GENERATION ))
        return;
    EUSCI_A_UART_enable(EUSCI_A0_BASE);
    EUSCI_A_UART_clearInterruptFlag(EUSCI_A0_BASE,
                                    EUSCI_A_UART_RECEIVE_INTERRUPT);
    // Enable USCI_A0 RX interrupt
    EUSCI_A_UART_enableInterrupt(EUSCI_A0_BASE,
                                 EUSCI_A_UART_RECEIVE_INTERRUPT); // Enable interrupt
    // Enable globale interrupt
    __enable_interrupt();
* USCI_A0 Interrupt Service Routine that receives PC GUI's commands
#pragma vector = USCI_A0_VECTOR
__interrupt void USCI_A0_ISR(void)
        int i;
    switch (__even_in_range(UCA0IV, USCI_UART_UCTXCPTIFG)) {
        case USCI_NONE: break;
        case USCI_UART_UCRXIFG:
            i = EUSCI_A_UART_receiveData(EUSCI_A0_BASE);
            EUSCI_A_UART_transmitData(EUSCI_A0_BASE,i);
                /*if (i == '5')
                pingHost = 1;
            else
                mode = i;
            __bic_SR_register_on_exit(LPM3_bits); // Exit active CPU*/
            break;
        case USCI_UART_UCTXIFG: break;
        case USCI_UART_UCSTTIFG: break;
        case USCI_UART_UCTXCPTIFG: break;
以上为中断函数和串口的初使化的函数。
函数代码
uart.rar (493.7 KB)
(下载次数: 5, 2014-11-7 22:49 上传)
stay hungry,stay foolish.
回复评论
暂无评论,赶紧抢沙发吧
    写回复
