[讨论] 求大神帮忙看看这个FLASH保存数据实验程序哪错了
疯狂编程   2014-11-9 23:31 楼主
*                         FLASH保存数据实验
* 实验目的:  熟悉FLASH及其操作
* 连接方法: 参考 “连接方法” 图片演示
* 实验现象: 用K1设定一个数据, 先用K2擦除指定FLASH扇区 再按K3保存数据
*            再按K4把数据调到数码管显示,与先前设定的数据对比下。
*            也可以关掉电源后开机,按K4即可显示先前保存的数据
*(crazybc.com)
#include "stm32f10x_lib.h"
/* Private typedef -----------------------------------------------------------*/
typedef enum {FAILED = 0, PASSED = !FAILED} TestStatus;
/* Private define ------------------------------------------------------------*/
#define FLASH_PAGE_SIZE    ((u16)0x400)   //USE_STM3210B
#define StartAddr          ((u32)0x08008000)
#define EndAddr            ((u32)0x0800C000)
/******************************** 变量定义 ------------------------------------*/
u32 EraseCounter = 0x00, Address = 0x00;
u32 Data;
vu32 NbrOfPage = 0x00;
volatile FLASH_Status FLASHStatus;
volatile TestStatus MemoryProgramStatus;
ErrorStatus HSEStartUpStatus;
bool EraseFlag  = FALSE , ProgramFlag = FALSE;
unsigned int jj = 0;
unsigned int  LedNumVal = 0 ,LedNumVal1 = 0;           //变量定义
//此表为 LED 的字模, 共阴数码管 0-9  -
unsigned char Disp_Tab[] = {0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x40};  //段码控制
//此表为8个数码管位选控制, 共阴数码管 1-8个  -
unsigned char dispbit[8]={0xfe,0xfd,0xfb,0xf7,0xef,0xdF,0xbF,0x7F};    //位选控制   查表的方法控制
unsigned int LedOut[10];                   //变量定义
/*********************************声明函数 -----------------------------------------------*/
void NVIC_Configuration(void);
void RCC_Configuration(void);
void GPIO_Configuration(void);
void Delay(vu32 nCount);
/* Private functions ---------------------------------------------------------*/
* Function Name  : main
* Description    : Main program
* Input          : None
* Output         : None
* Return         : None
int main(void)
#ifdef DEBUG
  debug();
#endif
  FLASHStatus = FLASH_COMPLETE;
  MemoryProgramStatus = PASSED;
  Data = 0x15041979;
  RCC_Configuration();  //配置系统时钟
  NVIC_Configuration();         //配置NVIC中断
  FLASH_Unlock(); //解锁FLASH 编程擦除控制器
  GPIO_Configuration();          //配置GPIO
  /* Define the number of page to be erased */
  NbrOfPage = (EndAddr - StartAddr) / FLASH_PAGE_SIZE;
    //清除所有标志标志
  FLASH_ClearFlag(FLASH_FLAG_BSY | FLASH_FLAG_EOP | FLASH_FLAG_PGERR | FLASH_FLAG_WRPRTERR);
  /*  FLASH Word program of data 0x15041979 at addresses defined by StartAddr and EndAddr*/
  while (1)
    unsigned int i ;
    if (++jj >= 0x00ff && GPIO_ReadInputDataBit(GPIOA,GPIO_Pin_0) == 0)
     { LedNumVal1++ ;
       jj = 0;
       EraseFlag = FALSE;
   //GPIO_Pin_6 擦出FLASH按钮
   if(GPIO_ReadInputDataBit(GPIOA,GPIO_Pin_1) == 0 && !EraseFlag)
     /* 清除FLASH待处理的标志位 */
     FLASHStatus = FLASH_ErasePage(StartAddr);
     EraseFlag = TRUE; //做了个擦出标志,FLASH可擦除的寿命有限,以免当按钮按住不放时反复擦除FLASH.
    }//if
   //GPIO_Pin_5 保存数据到FLASH按钮
   if(GPIO_ReadInputDataBit(GPIOA,GPIO_Pin_2) == 0 && !ProgramFlag )
   {    Address = StartAddr;
            FLASHStatus = FLASH_ProgramWord(Address, LedNumVal1);
                ProgramFlag = TRUE;
   }//if
    //GPIO_Pin_4 从FLASH中读出数据按钮
   if(GPIO_ReadInputDataBit(GPIOA,GPIO_Pin_3) == 0)
      LedNumVal =  (*(vu32*) Address);
    }//if
     LedOut[0]=Disp_Tab[LedNumVal%10000/1000];
     LedOut[1]=Disp_Tab[LedNumVal%1000/100];
     LedOut[2]=Disp_Tab[LedNumVal%100/10];
     LedOut[3]=Disp_Tab[LedNumVal%10];
         LedOut[4]=Disp_Tab[LedNumVal1%100000/1000];
     LedOut[5]=Disp_Tab[LedNumVal1%1000/100];
     LedOut[6]=Disp_Tab[LedNumVal1%100/10];  //十位
     LedOut[7]=Disp_Tab[LedNumVal1%10];     //个位
         for( i=0; i<8; i++)
            GPIOB->BSRR = LedOut[i]<<8 & 0xFF00;
        GPIOB->BRR = (~(LedOut[i]<<8)) & 0xFF00;
         //使用查表法进行位选
            GPIOB->BSRR = dispbit[i] & 0x00FF;
        GPIOB->BRR = (~dispbit[i]) & 0x00FF;
        Delay(0x000ff);                 //扫描间隔时间
  for(; nCount != 0; nCount--);
* Function Name  : GPIO_Configuration
* Description    : Configures the different GPIO ports.
* Input          : None
* Output         : None
* Return         : None
    GPIO_InitTypeDef GPIO_InitStructure;
    GPIO_PinRemapConfig(GPIO_Remap_SWJ_Disable, ENABLE);
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_All ;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; //引脚频率50M
    GPIO_Init(GPIOA, &GPIO_InitStructure);
    GPIO_Init(GPIOB, &GPIO_InitStructure);
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_2 | GPIO_Pin_3 | GPIO_Pin_4 | GPIO_Pin_5 | GPIO_Pin_6 | GPIO_Pin_7;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
* Function Name  : NVIC_Configuration
* Description    : Configures Vector Table base location.
* Input          : None
* Output         : None
* Return         : None
#ifdef  VECT_TAB_RAM
  /* Set the Vector Table base location at 0x20000000 */
  NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0);
#else  /* VECT_TAB_FLASH  */
  /* Set the Vector Table base location at 0x08000000 */
  NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0);
#endif
* Function Name  : RCC_Configuration
* Description    : Configures the different system clocks.
* Input          : None
* Output         : None
* Return         : None
//复位RCC外部设备寄存器到默认值
  RCC_DeInit();
  //打开外部高速晶振
  RCC_HSEConfig(RCC_HSE_ON);
//等待外部高速时钟准备好
  HSEStartUpStatus = RCC_WaitForHSEStartUp();
  //外部高速时钟已经准别好
  if(HSEStartUpStatus == SUCCESS)
    FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
    FLASH_SetLatency(FLASH_Latency_2);
   //配置AHB(HCLK)时钟=SYSCLK
    RCC_HCLKConfig(RCC_SYSCLK_Div1);
    //配置APB2(PCLK2)钟=AHB时钟
    RCC_PCLK2Config(RCC_HCLK_Div1);
    //配置APB1(PCLK1)钟=AHB 1/2时钟
    RCC_PCLK1Config(RCC_HCLK_Div2);
    //配置ADC时钟=PCLK2 1/4
    RCC_ADCCLKConfig(RCC_PCLK2_Div4);
    //配置PLL时钟 == 外部高速晶体时钟*9
    RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);
        //配置ADC时钟= PCLK2/4
   //使能PLL时钟
    RCC_PLLCmd(ENABLE);
   //等待PLL时钟就绪
    while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET)
    //配置系统时钟 = PLL时钟
    RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
   //检查PLL时钟是否作为系统时钟
    while(RCC_GetSYSCLKSource() != 0x08)
   //启动GPIO
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB ,ENABLE);
    //启动AFIO
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO, ENABLE);
#ifdef  DEBUG
* Function Name  : assert_failed
* Description    : Reports the name of the source file and the source line number
*                  where the assert_param error has occurred.
* Input          : - file: pointer to the source file name
*                  - line: assert_param error line source number
* Output         : None
* Return         : None
void assert_failed(u8* file, u32 line)
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  while (1)
#endif
/******************* (C) COPYRIGHT 2008 STMicroelectronics *****END OF FILE****/
回复评论 (2)
仿真环境下通过加断点还有单步调试看吧,就这样我估计没人能看出来问题在哪儿。
把这个完整的操作分成几个步骤,在每一个步骤开始和结束查看输入和输出是否跟预想的一致。这样就能找出问题在哪儿了
点赞  2014-11-10 09:51
是个人都不知道你出了啥问题,问题都没列出来
点赞  2014-11-10 16:18
    写回复
