[讨论] AD5933数据能够写入,但是无法读出,求解
areak   2014-12-30 18:35 楼主
STM32通过I2C读写AD5933数据, 用的是STM32的I2C1, 数据可以正常写入,测量AD5933可以产生激励信号,但是却读不回来数据,无论读哪个寄存器地址,读出来的都是0X1A。
不知道是不是STM32的I2C读函数写错了,手册上写的读字节时序,最后一个位是非应答,这里有点不确定是怎么操作。
回复评论 (8)
void I2C_Pointer_Write(unsigned char reg_addr) { while(I2C_GetFlagStatus(I2C1,I2C_FLAG_BUSY)); I2C_GenerateSTART(I2C1,ENABLE); while(!I2C_CheckEvent(I2C1,I2C_EVENT_MASTER_MODE_SELECT)); I2C_Send7bitAddress(I2C1,0X1A,I2C_Direction_Transmitter); while(!I2C_CheckEvent(I2C1,I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED)); I2C_SendData(I2C1,0XB0); while(!I2C_CheckEvent(I2C1,I2C_EVENT_MASTER_BYTE_TRANSMITTED)); I2C_SendData(I2C1,reg_addr); while(!I2C_CheckEvent(I2C1,I2C_EVENT_MASTER_BYTE_TRANSMITTED)); I2C_GenerateSTOP(I2C1,ENABLE); } char I2C_Byte_Read(unsigned char reg_addr) { char recieve_data; I2C_Pointer_Write(reg_addr); while(I2C_GetFlagStatus(I2C1, I2C_FLAG_BUSY)); /* Send START condition */ I2C_GenerateSTART(I2C1, ENABLE); while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_MODE_SELECT)); I2C_Send7bitAddress(I2C1, 0X1B, I2C_Direction_Transmitter); while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED)); /* Disable Acknowledgement */ I2C_AcknowledgeConfig(I2C1, DISABLE); recieve_data = I2C_ReceiveData(I2C1); I2C_GenerateSTOP(I2C1, ENABLE); /* Enable Acknowledgement to be ready for another reception */ I2C_AcknowledgeConfig(I2C1, ENABLE); return recieve_data; } 这是读AD5933的函数。 本帖最后由 areak 于 2014-12-30 18:42 编辑
点赞  2014-12-30 18:39
怎么都没人回复的?
点赞  2014-12-31 09:11
硬件的I2C,要不你先用模拟的试下啊。不然你改下你的读取函数,是最后一个字节读取时不要ack。不是所有读取操作都不要ACK char I2C_Byte_Read(unsigned char reg_addr,unsigned char ack) { char recieve_data; I2C_Pointer_Write(reg_addr); while(I2C_GetFlagStatus(I2C1, I2C_FLAG_BUSY)); /* Send START condition */ I2C_GenerateSTART(I2C1, ENABLE); while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_MODE_SELECT)); I2C_Send7bitAddress(I2C1, 0X1B, I2C_Direction_Transmitter); while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED)); /* Disable Acknowledgement */ if(ack) I2C_AcknowledgeConfig(I2C1, DISABLE); else I2C_AcknowledgeConfig(I2C1, ENABLE); recieve_data = I2C_ReceiveData(I2C1); I2C_GenerateSTOP(I2C1, ENABLE); /* Enable Acknowledgement to be ready for another reception */ I2C_AcknowledgeConfig(I2C1, ENABLE); return recieve_data; } 本帖最后由 weizhongc 于 2014-12-31 11:18 编辑
点赞  2014-12-31 11:04
已搞定,谢谢你
点赞  2014-12-31 15:20
        char recieve_data;
if(ack)
else
解决了,程序问题,谢谢
点赞  2014-12-31 15:22
什么问题啊
引用: areak 发表于 2014-12-31 15:22
解决了,程序问题,谢谢
点赞  2014-12-31 16:00
低级错误,这两句写错了。
I2C_Direction_Transmitter-->I2C_Direction_Reciever
I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED-->I2C_EVENT_MASTER_RECIRVER_MODE_SELECTED
weizhongc 发表于 2014-12-31 16:00
什么问题啊
点赞  2014-12-31 16:23
老哥还在么....虽然现在是2020年了,距离您发帖有6年,6年轻我还在参加中考哈哈哈,现在我在用AD5933,我怎么样都写不进去,因为我写入后读出来发现寄存器是空的,大佬如果能看到能给小弟发一下您的数据写入的函数吗,谢谢了我块搞了一个多月了,一直卡着没进展要哭了
点赞  2020-5-20 09:41
    写回复
