[求助] msp43O 模拟串口
englei   2015-1-16 10:48 楼主
//  MSP-FET430P410 Demo - Timer_A, UART 2400 Ultra-low Power Echo, 32kHz ACLK
//  Description: Use Timer_A CCR0 hardware output modes and SCCI data latch to
//  implement UART function @ 2400 baud. Software does not directly read and
//  write to RX and TX pins, instead proper use of output modes and SCCI data
//  latch are demonstrated. Use of these hardware features eliminates ISR
//  latency effects as hardware insures that output and input bit latching and
//  timing are perfectly synchronized with Timer_A regardless of other
//  software activity. In the Mainloop the UART function readies the UART to
//  receive one character and waits in LPM3 with all activity interrupt driven.
//  After a character has been received, the UART receive function forces exit
//  from LPM3 in the Mainloop which echo's back the received character.
//  ACLK = LFXT1 = 32768Hz, MCLK = SMCLK = default DCO = 32 x ACLK = 1048576Hz
//  //* An external watch crystal between XIN & XOUT is required for ACLK *//
//                MSP430F413
//        /|\|              XIN|-
//         | |                 | 32kHz
//         --|RST          XOUT|-
//           |    P1.0/CCI0A/TX|---------->
//           |                 |  2400 8N1
//           |    P1.1/CCI0B/RX|<----------
//  M. Buccini
//  Texas Instruments Inc.
//  Feb 2005
//  Built with CCE Version: 3.2.0 and IAR Embedded Workbench Version: 3.21A
#include
#define RXD   0x02                          // RXD on P1.1
#define TXD   0x01                          // TXD on P1.0
//  Conditions for 2400 Baud SW UART, ACLK = 32768
#define Bitime_5  0x06                 // ~ 0.5 bit length + small adjustment
#define Bitime    0x0E                 // 427us bit length ~ 2341 baud
unsigned int RXTXData;
unsigned char BitCnt;
void TX_Byte(void);
void RX_Ready(void);
void main(void)
  WDTCTL = WDTPW + WDTHOLD;                 // Stop watchdog timer
  FLL_CTL0 |= XCAP14PF;                     // Configure load caps
  CCTL0 = OUT;                              // TXD Idle as Mark
  TACTL = TASSEL_1 + MC_2;                  // ACLK, continous mode
  P1SEL = TXD + RXD;                        // P1.0/1 TA0 for TXD/RXD function
  P1DIR = TXD;                              // TXD output on P1
  // Mainloop
  for (;;)
    RX_Ready();                             // UART ready to RX one Byte
    _BIS_SR(LPM3_bits + GIE);               // Enter LPM3 Until character RXed
    TX_Byte();                              // TX Back RXed Byte Received
// Function Transmits Character from RXTXData Buffer
void TX_Byte(void)
  BitCnt = 0xA;                             // Load Bit counter, 8data + ST/SP
  CCR0 = TAR;                               // Current state of TA counter
  CCR0 += Bitime;                           // Some time till first bit
  RXTXData |= 0x100;                        // Add mark stop bit to RXTXData
  RXTXData = RXTXData << 1;                 // Add space start bit
  CCTL0 = OUTMOD0 + CCIE;                   // TXD = mark = idle
  while ( CCTL0 & CCIE );                   // Wait for TX completion
// Function Readies UART to Receive Character into RXTXData Buffer
void RX_Ready(void)
  BitCnt = 0x8;                             // Load Bit counter
  CCTL0 = SCS + CCIS0 + OUTMOD0 + CM1 + CAP + CCIE;  // Sync, Neg Edge, Capture
// Timer A0 interrupt service routine
#pragma vector=TIMERA0_VECTOR
__interrupt void Timer_A(void)
  CCR0 += Bitime;                           // Add Offset to CCR0
  // RX
  if (CCTL0 & CCIS0)                        // RX on CCI0B?
    if( CCTL0 & CAP )                       // Capture mode = start bit edge
      CCTL0 &= ~ CAP;                       // Capture to compare mode
      CCR0 += Bitime_5;
    else
      RXTXData = RXTXData >> 1;
      if (CCTL0 & SCCI)                     // Get bit waiting in receive latch
        RXTXData |= 0x80;
      BitCnt --;                            // All bits RXed?
      if ( BitCnt == 0)
//>>>>>>>>>> Decode of Received Byte Here <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
        CCTL0 &= ~ CCIE;                    // All bits RXed, disable interrupt
        _BIC_SR_IRQ(LPM3_bits);             // Clear LPM3 bits from 0(SR)
  // TX
  else
    if ( BitCnt == 0)
      CCTL0 &= ~ CCIE;                      // All bits TXed, disable interrupt
    else
      CCTL0 |=  OUTMOD2;                    // TX Space
      if (RXTXData & 0x01)
        CCTL0 &= ~ OUTMOD2;                 // TX Mark
      BitCnt --;
发送数没有反应
回复评论
暂无评论,赶紧抢沙发吧
    写回复
