[系统相关] 【Arrow SoCKit】Linux系统初体验1
chenzhufly   2015-1-16 23:32 楼主
既然系统已经装上了,我们来看看系统中有些什么吧
1、看一下CPU信息,是双核的耶,看到没有
  1. root@arrow_sockit:~# cat /proc/cpuinfo
  2. processor       : 0
  3. model name      : ARMv7 Processor rev 0 (v7l)
  4. Features        : swp half thumb fastmult vfp edsp thumbee neon vfpv3 tls vfpd32
  5. CPU implementer : 0x41
  6. CPU architecture: 7
  7. CPU variant     : 0x3
  8. CPU part        : 0xc09
  9. CPU revision    : 0
  10. processor       : 1
  11. model name      : ARMv7 Processor rev 0 (v7l)
  12. Features        : swp half thumb fastmult vfp edsp thumbee neon vfpv3 tls vfpd32
  13. CPU implementer : 0x41
  14. CPU architecture: 7
  15. CPU variant     : 0x3
  16. CPU part        : 0xc09
  17. CPU revision    : 0
  18. Hardware        : Altera SOCFPGA
  19. Revision        : 0000
  20. Serial          : 0000000000000000
2、用top命令看一下当前系统运行情况,有意外惊喜,居然还有个webserver哦
  1. root@arrow_sockit:~# top
  2. Mem: 15528K used, 1016500K free, 0K shrd, 904K buff, 5236K cached
  3. CPU:   0% usr   4% sys   0% nic  95% idle   0% io   0% irq   0% sirq
  4. Load average: 0.04 0.03 0.02 1/47 191
  5.   PID  PPID USER     STAT   VSZ %VSZ %CPU COMMAND
  6.   173     1 root     S    10628   1%   0% /www/pages/cgi-bin/scroll_server
  7.   157     1 root     S     3592   0%   0% /usr/sbin/sshd
  8.   188     1 root     S     2496   0%   0% -sh
  9.   168     1 root     S     1960   0%   0% /usr/sbin/lighttpd -f /etc/lighttpd.co
  10.   134     1 root     S     1660   0%   0% udhcpc -R -n -p /var/run/udhcpc.eth0.p
  11.   161     1 root     S     1660   0%   0% /sbin/syslogd -n -O /var/log/messages
  12.   164     1 root     S     1660   0%   0% /sbin/klogd -n
  13.   191   188 root     R     1660   0%   0% top
  14.   189     1 root     S     1564   0%   0% /sbin/getty 38400 tty1
  15.   138     1 daemon   S     1460   0%   0% /sbin/portmap
  16.     1     0 root     S     1316   0%   0% init [5]
  17.     9     2 root     SW       0   0%   0% [migration/0]
  18.    22     2 root     SW       0   0%   0% [kworker/0:1]
  19.    46     2 root     SW       0   0%   0% [mmcqd/0]
  20.     3     2 root     SW       0   0%   0% [ksoftirqd/0]
  21.     6     2 root     SW       0   0%   0% [kworker/u4:0]
  22.     7     2 root     SW       0   0%   0% [rcu_sched]
  23.     4     2 root     SW       0   0%   0% [kworker/0:0]
  24.    27     2 root     SW       0   0%   0% [kworker/u4:1]
3、 那么查看一下IP吧
  1. root@arrow_sockit:~# ifconfig
  2. eth0      Link encap:Ethernet  HWaddr 02:37:49:34:7f:fe
  3.           inet addr:192.168.1.11  Bcast:0.0.0.0  Mask:255.255.255.0
  4.           UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
  5.           RX packets:7 errors:0 dropped:0 overruns:0 frame:0
  6.           TX packets:8 errors:0 dropped:0 overruns:0 carrier:0
  7.           collisions:0 txqueuelen:1000
  8.           RX bytes:1236 (1.2 KiB)  TX bytes:1648 (1.6 KiB)
  9.           Interrupt:152
  10. lo        Link encap:Local Loopback
  11.           inet addr:127.0.0.1  Mask:255.0.0.0
  12.           inet6 addr: ::1/128 Scope:Host
  13.           UP LOOPBACK RUNNING  MTU:65536  Metric:1
  14.           RX packets:0 errors:0 dropped:0 overruns:0 frame:0
  15.           TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
  16.           collisions:0 txqueuelen:0
  17.           RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
ping一下看看网络可通
  1. root@arrow_sockit:~# ping 192.168.1.1
  2. PING 192.168.1.1 (192.168.1.1) 56(84) bytes of data.
  3. 64 bytes from 192.168.1.1: icmp_req=1 ttl=64 time=2.10 ms
  4. 64 bytes from 192.168.1.1: icmp_req=2 ttl=64 time=0.958 ms
  5. 64 bytes from 192.168.1.1: icmp_req=3 ttl=64 time=1.02 ms
  6. 64 bytes from 192.168.1.1: icmp_req=4 ttl=64 time=0.948 ms
  7. 64 bytes from 192.168.1.1: icmp_req=5 ttl=64 time=0.941 ms
  8. 64 bytes from 192.168.1.1: icmp_req=6 ttl=64 time=0.874 ms
  9. 64 bytes from 192.168.1.1: icmp_req=7 ttl=64 time=0.945 ms
  10. --- 192.168.1.1 ping statistics ---
  11. 7 packets transmitted, 7 received, 0% packet loss, time 6003ms
  12. rtt min/avg/max/mdev = 0.874/1.114/2.109/0.409 ms
一切正常
4、登陆一下web看看是啥东西,哇,居然是个控制界面,这个地方可以控制LED的
5、看看home目录有啥
  1. root@arrow_sockit:~# ls
  2. README                clear_leds.sh~        led_blink_devices.sh
  3. altera                hello
  4. clear_leds.sh         led_blink
哇,又有新发现,还有两个可执行程序,看看是啥情况呗
  1. root@arrow_sockit:~# ./hello
  2. Hello SoC FPGA!
  1. root@arrow_sockit:~# ./led_blink
流水灯欢快的跑起来啦,你也可以试试哦,稍后继续。
生活就是油盐酱醋再加一点糖,快活就是一天到晚乐呵呵的忙 =================================== 做一个简单的人,踏实而务实,不沉溺幻想,不庸人自扰
回复评论 (4)
恩,这板子确实很强大!!
点赞  2015-1-17 09:06
确实很强大 而且太新了 一时半会也搞不定 所以只能慢慢来了
点赞  2015-1-17 10:47
顶起
点赞  2015-1-17 13:26
支持一下,我一直弄fpga,soc第一次接触soc,好多要请教大家呀呵呵
点赞  2015-1-18 10:49
    写回复
