至于DE1_SOC的板子简介我就不多说了,拿到板子首先按照培训资料(见附件)中的教程安装usb blaster ii的驱动,串口驱动等等,然后按照教程下载测试例程,看到的是一个流水灯和数码管的0~F轮回计数。过程中想说的两点是,
开始是NO hardware,要稍微过一会才会有DE-SOC[USB-1](感觉时间稍微有点长),另外一个教程中在programmer界面Auto Detect器件出现的是5CSEMA5然后是SOCVHPS
而我的是
SOCVHPS在左,5CSEMA5在右,开始选中了其中的5CSEMA5然后右键up,两者位置交换如下图
但是program出现错误,又Auto Detect一次program正常。至于两者的位置不同有什么区别还不知道,以后再探究吧。
按照教程烧SD镜像,启动系统。
- U-Boot SPL 2013.01.01 (Nov 04 2013 - 19:51:38)
- BOARD : Altera SOCFPGA Cyclone V Board
- SDRAM: Initializing MMR registers
- SDRAM: Calibrating PHY
- SEQ.C: Preparing to start memory calibration
- SEQ.C: CALIBRATION PASSED
- ALTERA DWMMC: 0
- U-Boot 2013.01.01 (Oct 24 2013 - 17:40:22)
- CPU : Altera SOCFPGA Platform
- DRAM: 1 GiB
- MMC: ALTERA DWMMC: 0
- In: serial
- Out: serial
- Err: serial
- Net: mii0
- Warning: failed to set MAC address
- Hit any key to stop autoboot: 5 4 3 2 1 0
- reading u-boot.scr
- ** Unable to read file u-boot.scr **
- Optional boot script not found. Continuing to boot normally
- reading zImage
- 3809104 bytes read in 1297 ms (2.8 MiB/s)
- reading socfpga.dtb
- 17119 bytes read in 14 ms (1.2 MiB/s)
- fpgaintf
- ffd08028: 00000000 ....
- fpga2sdram
- ffc25080: 00000000 ....
- axibridge
- ffd0501c: 00000000 ....
- ## Flattened Device Tree blob at 00000100
- Booting using the fdt blob at 0x00000100
- Loading Device Tree to 03ff8000, end 03fff2de ... OK
- Starting kernel ...
- Booting Linux on physical CPU 0x0
- Initializing cgroup subsys cpuset
- Linux version 3.12.0-00307-g507abb4-dirty (root@matthew) (gcc version 4.6.3 (Sourcery CodeBench Lite 2012.03-57) ) #2 SMP Mon Jan 6 19:54:56 CST 2014
- CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=10c5387d
- CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
- Machine: Altera SOCFPGA, model: Altera SOCFPGA Cyclone V
- Memory policy: ECC disabled, Data cache writealloc
- PERCPU: Embedded 8 pages/cpu @80fd1000 s11328 r8192 d13248 u32768
- Built 1 zonelists in Zone order, mobility grouping on. Total pages: 260096
- Kernel command line: console=ttyS0,115200 root=/dev/mmcblk0p2 rw rootwait
- PID hash table entries: 4096 (order: 2, 16384 bytes)
- Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
- Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
- Memory: 1031484K/1048576K available (5637K kernel code, 253K rwdata, 1424K rodata, 343K init, 256K bss, 17092K reserved)
- Virtual kernel memory layout:
- vector : 0xffff0000 - 0xffff1000 ( 4 kB)
- fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
- vmalloc : 0xc0800000 - 0xff000000 (1000 MB)
- lowmem : 0x80000000 - 0xc0000000 (1024 MB)
- modules : 0x7f000000 - 0x80000000 ( 16 MB)
- .text : 0x80008000 - 0x806ed828 (7063 kB)
- .init : 0x806ee000 - 0x80743c40 ( 344 kB)
- .data : 0x80744000 - 0x807834f0 ( 254 kB)
- .bss : 0x807834f0 - 0x807c355c ( 257 kB)
- SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
- Hierarchical RCU implementation.
- NR_IRQS:16 nr_irqs:16 16
- sched_clock: 32 bits at 100MHz, resolution 10ns, wraps every 42949ms
- Console: colour dummy device 80x30
- Calibrating delay loop... 1594.16 BogoMIPS (lpj=7970816)
- pid_max: default: 32768 minimum: 301
- Mount-cache hash table entries: 512
- CPU: Testing write buffer coherency: ok
- ftrace: allocating 17704 entries in 52 pages
- CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
- Setting up static identity map for 0x8051f018 - 0x8051f070
- CPU1: Booted secondary processor
- CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
- Brought up 2 CPUs
- SMP: Total of 2 processors activated.
- CPU: All CPU(s) started in SVC mode.
- devtmpfs: initialized
- VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
- NET: Registered protocol family 16
- fpga bridge driver
- DMA: preallocated 256 KiB pool for atomic coherent allocations
- L310 cache controller enabled
- l2x0: 8 ways, CACHE_ID 0x410030c9, AUX_CTRL 0x32460000, Cache size: 512 kB
- syscon fffef000.l2-cache: regmap [mem 0xfffef000-0xfffeffff] registered
- syscon ffd05000.rstmgr: regmap [mem 0xffd05000-0xffd05fff] registered
- syscon ffc25000.sdrctl: regmap [mem 0xffc25000-0xffc25fff] registered
- syscon ff800000.l3regs: regmap [mem 0xff800000-0xff800fff] registered
- syscon ffd08000.sysmgr: regmap [mem 0xffd08000-0xffd0bfff] registered
- hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
- hw-breakpoint: maximum watchpoint size is 4 bytes.
- altera_hps2fpga_bridge fpgabridge.2: fpga bridge [hps2fpga] registered as device hps2fpga
- altera_hps2fpga_bridge fpgabridge.2: init-val not specified
- altera_hps2fpga_bridge fpgabridge.3: fpga bridge [lshps2fpga] registered as device lwhps2fpga
- altera_hps2fpga_bridge fpgabridge.3: init-val not specified
- altera_hps2fpga_bridge fpgabridge.4: fpga bridge [fpga2hps] registered as device fpga2hps
- altera_hps2fpga_bridge fpgabridge.4: init-val not specified
- bio: create slab <bio-0> at 0
- FPGA Mangager framework driver
- SCSI subsystem initialized
- usbcore: registered new interface driver usbfs
- usbcore: registered new interface driver hub
- usbcore: registered new device driver usb
- pps_core: LinuxPPS API ver. 1 registered
- pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
- PTP clock support registered
- Switched to clocksource timer1
- NET: Registered protocol family 2
- TCP established hash table entries: 8192 (order: 4, 65536 bytes)
- TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
- TCP: Hash tables configured (established 8192 bind 8192)
- TCP: reno registered
- UDP hash table entries: 512 (order: 2, 16384 bytes)
- UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
- RPC: Registered named UNIX socket transport module.
- RPC: Registered udp transport module.
- RPC: Registered tcp transport module.
- RPC: Registered tcp NFSv4.1 backchannel transport module.
- hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counters available
- arm-pmu arm-pmu: PMU:CTI successfully enabled
- NFS: Registering the id_resolver key type
- Key type id_resolver registered
- Key type id_legacy registered
- NTFS driver 2.1.30 [Flags: R/W].
- jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
- msgmni has been set to 2014
- io scheduler noop registered (default)
- Serial: 8250/16550 driver, 2 ports, IRQ sharing disabled
- ffc02000.serial0: ttyS0 at MMIO 0xffc02000 (irq = 194, base_baud = 6250000) is a 16550A
- console [ttyS0] enabled
- altera_fpga_manager ff706000.fpgamgr: fpga manager [Altera FPGA Manager] registered as minor 0
- brd: module loaded
- cadence-qspi ff705000.spi: DMA NOT enabled
- cadence-qspi ff705000.spi: master is unqueued, this is deprecated
- m25p80 spi2.0: unrecognized JEDEC id ffffff
- cadence-qspi ff705000.spi: Cadence QSPI controller driver
- dw_spi_mmio fff01000.spi: master is unqueued, this is deprecated
- CAN device driver interface
- c_can_platform ffc00000.d_can: invalid resource
- c_can_platform ffc00000.d_can: control memory is not used for raminit
- c_can_platform ffc00000.d_can: c_can_platform device registered (regs=c08e4000, irq=163)
- stmmac - user ID: 0x10, Synopsys ID: 0x37
- Ring mode enabled
- DMA HW capability register supported
- Enhanced/Alternate descriptors
- Enabled extended descriptors
- RX Checksum Offload Engine supported (type 2)
- TX Checksum insertion supported
- Enable RX Mitigation via HW Watchdog Timer
- libphy: stmmac: probed
- eth0: PHY ID 00221611 at 1 IRQ 0 (stmmac-0:01) active
- usbcore: registered new interface driver usb-storage
- mousedev: PS/2 mouse device common for all mice
- i2c /dev entries driver
- Synopsys Designware Multimedia Card Interface Driver
- dwmmc_socfpga ff704000.dwmmc0: Using internal DMA controller.
- dwmmc_socfpga ff704000.dwmmc0: Version ID is 240a
- dwmmc_socfpga ff704000.dwmmc0: DW MMC controller at irq 171, 32 bit host data width, 1024 deep fifo
- mmc_host mmc0: Bus speed (slot 0) = 12500000Hz (slot req 400000Hz, actual 390625HZ div = 16)
- dwmmc_socfpga ff704000.dwmmc0: 1 slots initialized
- usbcore: registered new interface driver usbhid
- usbhid: USB HID core driver
- mmc_host mmc0: Bus speed (slot 0) = 12500000Hz (slot req 12500000Hz, actual 12500000HZ div = 0)
- mmc0: new high speed SDHC card at address 1234
- mmcblk0: mmc0:1234 SA16G 14.6 GiB
- mmcblk0: p1 p2 p3
- dwc2 ffb40000.usb: DWC OTG Controller
- dwc2 ffb40000.usb: new USB bus registered, assigned bus number 1
- dwc2 ffb40000.usb: irq 160, io mem 0x00000000
- usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
- usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
- usb usb1: Product: DWC OTG Controller
- usb usb1: Manufacturer: Linux 3.12.0-00307-g507abb4-dirty dwc2_hsotg
- usb usb1: SerialNumber: ffb40000.usb
- hub 1-0:1.0: USB hub found
- hub 1-0:1.0: 1 port detected
- oprofile: using arm/armv7-ca9
- TCP: cubic registered
- NET: Registered protocol family 10
- sit: IPv6 over IPv4 tunneling driver
- NET: Registered protocol family 17
- NET: Registered protocol family 15
- can: controller area network core (rev 20120528 abi 9)
- NET: Registered protocol family 29
- can: raw protocol (rev 20120528)
- can: broadcast manager protocol (rev 20120528 t)
- can: netlink gateway (rev 20130117) max_hops=1
- 8021q: 802.1Q VLAN Support v1.8
- Key type dns_resolver registered
- ThumbEE CPU extension supported.
- Registering SWP/SWPB emulation handler
- kjournald starting. Commit interval 5 seconds
- EXT3-fs (mmcblk0p2): using internal journal
- EXT3-fs (mmcblk0p2): mounted filesystem with ordered data mode
- VFS: Mounted root (ext3 filesystem) on device 179:2.
- devtmpfs: mounted
- Freeing unused kernel memory: 340K (806ee000 - 80743000)
- usb 1-1: new high-speed USB device number 2 using dwc2
- INIT: version 2.88 booting
- usb 1-1: New USB device found, idVendor=0424, idProduct=2512
- usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
- hub 1-1:1.0: USB hub found
- hub 1-1:1.0: 2 ports detected
- Starting Bootlog daemon: bootlogd.
- Configuring network interfaces... eth0: device MAC address 6a:a9:48:f6:c3:f3
- udhcpc (v1.20.2) started
- Sending discover...
- No lease, failing
- Starting portmap daemon...
- Sat Sep 28 04:38:00 UTC 2013
- INIT: Entering runlevel: 5
- Starting OpenBSD Secure Shell server: sshd
- done.
- Starting syslogd/klogd: done
- Starting Lighttpd Web Server: lighttpd.
- Starting blinking LED server
- Stopping Bootlog daemon: bootlogd.
- Poky 8.0 (Yocto Project 1.3 Reference Distro) 1.3
- ttyS0
- socfpga login: root
- root@socfpga:~# p who i am am i
- BusyBox v1.20.2 (2013-09-27 23:27:54 CDT) multi-call binary.
- Usage: who [-a]
- root@socfpga:~# poweroffer
- Broadcast message from root@socfpga (ttyS0) (Sat Sep 28 04:39:11 2013):
- The system is going down for system halt NOW!
- INIT:
- INIT: Sending processes the TERM signal
- root@socfpga:~#
- INIT: Sending processes the KILL signal
- Stopping OpenBSD Secure Shell server: sshdstopped /usr/sbin/sshd (pid 148)
- Stopping syslogd/klogd: stopped syslogd (pid 152)
- stopped klogd (pid 155)
- done
- Deconfiguring network interfaces... ifdown: interface eth0 not configured
- done.
- Stopping Lighttpd Web Server: stopped /usr/sbin/lighttpd (pid 159)
- lighttpd.
- /etc/rc0.d/K90gsrd_init.sh: line 23: kill: (204) - No such process
- Sending all processes the TERM signal...
- Sending all processes the KILL signal...
- Unmounting remote filesystems...
- Stopping portmap daemon...
- Deactivating swap...
- Unmounting local filesystems...
- reboot: System halted
启动过程中可以看到许多系统信息。
登陆系统:
- root@socfpga:~# who i am
关机:
