[求助] MSP430 SPI 主机从机通信问题
luooove   2015-3-14 10:12 楼主
现在,用两块430单片机进行SPI的通信,希望是从机发送数据,主机接收数据并返回。编写程序后发现主机没有主动产生时钟,现在用的是3线的SPI,是否需要4线的才能实现?
  1. //******************************************************************************
  2. //作为主机,接收SPI数据,并转换后发送回去,然后上传串口
  3. #include <msp430.h>
  4. unsigned char MST_Data,SLV_Data;
  5. void Serial_init()
  6. {
  7.         P10SEL = 0x30;                             // P3.4,5 = USCI_A0 TXD/RXD
  8.         UCA3CTL1 |= UCSWRST;                      // **Put state machine in reset**
  9.         UCA3CTL1 |= UCSSEL_2;                     // SMCLK
  10.         UCA3BR0 = 6;                              // 1MHz 9600 (see User's Guide)
  11.         UCA3BR1 = 0;                              // 1MHz 9600
  12.         UCA3MCTL = UCBRS_0 + UCBRF_13 + UCOS16;   // Modln UCBRSx=0, UCBRFx=0,
  13.        // over sampling
  14.         UCA3CTL1 &= ~UCSWRST;                     // **Initialize USCI state machine**
  15.         //UCA3IE |= UCRXIE;                         // Enable USCI_A0 RX interrupt
  16. }
  17. int main(void)
  18. {
  19.   WDTCTL = WDTPW+WDTHOLD;                   // Stop watchdog timer
  20.   Serial_init();
  21.   //P1OUT |= 0x02;                            // Set P1.0 for LED
  22.                                             // Set P1.1 for slave reset
  23. // P1DIR |= 0x03;                            // Set P1.0-2 to output direction
  24.   P9SEL |= 0x0E;                            // P3.5,4,0 option select
  25.   UCB2CTL1 |= UCSWRST;                      // **Put state machine in reset**
  26.   UCB2CTL0 |= UCMST+UCSYNC+UCCKPL+UCMSB;    // 3-pin, 8-bit SPI master
  27.                                             // Clock polarity high, MSB
  28.   UCB2CTL1 |= UCSSEL_2;                     // SMCLK
  29.   UCB2BR0 = 0x02;                           // /2
  30.   UCB2BR1 = 0;                              //
  31. // UCA0MCTL = 0;                             // No modulation
  32.   UCB2CTL1 &= ~UCSWRST;                     // **Initialize USCI state machine**
  33.   UCB2IE |= UCRXIE;                         // Enable USCI_A0 RX interrupt
  34.   //P1OUT &= ~0x02;                           // Now with SPI signals initialized,
  35. // P1OUT |= 0x02;                            // reset slave
  36.   __delay_cycles(100);                      // Wait for slave to initialize
  37.   __bis_SR_register(GIE);       // Enter LPM4, enable interrupts
  38.   while(1);
  39. }
  40. #if defined(__TI_COMPILER_VERSION__) || defined(__IAR_SYSTEMS_ICC__)
  41. #pragma vector=USCI_B2_VECTOR
  42. __interrupt void USCI_B2_ISR(void)
  43. #elif defined(__GNUC__)
  44. void __attribute__ ((interrupt(USCI_B2_VECTOR))) USCI_B2_ISR (void)
  45. #else
  46. #error Compiler not supported!
  47. #endif
  48. {
  49.   switch(__even_in_range(UCB2IV,4))
  50.   {
  51.   case 0:break;                             // Vector 0 - no interrupt
  52.   case 2:                                   // Vector 2 - RXIFG
  53.     while (!(UCA3IFG&UCTXIFG));             // USCI_A0 TX buffer ready?
  54.     UCA3TXBUF = 0xff-UCB2RXBUF;                  // TX -> RXed character
  55.     while (!(UCB2IFG&UCTXIFG));             // USCI_A0 TX buffer ready?
  56.     UCB2TXBUF = 0xff-UCB2RXBUF;                  // TX -> RXed character
  57.     break;
  58.   case 4:break;                             // Vector 4 - TXIFG
  59.   default: break;
  60.   }
  61. }
回复评论 (13)
如果双向通讯,使用四条线最快。
三线的也会有时钟输出的---主机侧。
点赞  2015-3-14 10:40
要返回数据当然要4线的,3线的是单向,而且基本是MCU做主机
点赞  2015-3-15 22:29
不对吧,3线也可以双向通信。
点赞  2015-3-17 17:06
3线也可以双向的,SPI是数据环。双机通讯要注意设置主机和从机模式。当然你这个说的主机没有产生时钟,应该是主机设置的问题。参考一下例程
点赞  2015-3-17 17:10
正常情况下从机是不能发起一次通信的,通信都由主机发起。
点赞  2015-3-17 17:30
看来我要回去补补课了
点赞  2015-3-17 20:08
好像确实是这样,我测试的时候主机这一端需要发一个数据给从机,然后才开始传输数据。但是我先的问题的是出现重复的数据,即从机发送一次数据主机会收到很多次的数据。请教下下是什么原因。而且如果从机暂停运行,主机还是会不断收到同一个数据。
点赞  2015-3-17 21:11
我看你的中断服务里没有清除标志位,是不是一次中断之后就一直在进中断服务程序呀?
你是在中断服务里面一直向串口丢数据包的…
点赞  2015-3-18 02:22
引用: 强仔00001 发表于 2015-3-17 20:08
看来我要回去补补课了
3线制SPI和4线制SPI区别应该是片选线。如果双机通信,应该可以省去片选线(一直处于通信状态)。
点赞  2015-3-18 03:19
现在是不太确定是因为串口的设置的问题,还是SPI的问题。从机在调试的时候暂停,主机也能不断地收到数据。感觉是因为从机一直在收数据。
点赞  2015-3-19 21:05
不看我的回复吗?
中断服务里没有清除标志位,所以一直在中断服务里。
一直在向串口发数据。
  1. switch(__even_in_range(UCB2IV,4))
  2.   {
  3.   case 0:break;                             // Vector 0 - no interrupt
  4.   case 2:                                   // Vector 2 - RXIFG
  5.     while (!(UCA3IFG&UCTXIFG));             // USCI_A0 TX buffer ready?
  6.     UCA3TXBUF = 0xff-UCB2RXBUF;                  // TX -> RXed character
  7.     while (!(UCB2IFG&UCTXIFG));             // USCI_A0 TX buffer ready?
  8.     UCB2TXBUF = 0xff-UCB2RXBUF;                  // TX -> RXed character
  9.     break;
  10.   case 4:break;                             // Vector 4 - TXIFG
  11.   default: break;
  12.   }
就是上面的代码出问题了。还有,中断服务里不应该使用while();语句的。
点赞  2015-3-19 23:26
引用: qiushenghua 发表于 2015-3-19 23:26
不看我的回复吗?
一直在向串口发数据。
看了,但是水平比较差,没看懂。是对发送中断标志位清零吗?UCB2IFG &= ~UCTXIFG;UCA3IFG &= ~UCTXIFG;?    while是参考官方例程的。不知道哥们有什么好的建议。
点赞  2015-3-20 20:46
好像确实是这样,我测试的时候主机这一端需要发一个数据给从机,然后才开始传输数据。但是我先的问题的是 ...
你测试SPI的时候是怎么测试的,能用串口助手调试吗?你用的单片机是430吗?
点赞  2016-8-4 15:11
    写回复
