[求助] 为什么没有pwm产生
834707939   2015-3-28 13:13 楼主
#include "msp430.h"
typedef unsigned char uchar;
typedef unsigned int  uint;
uchar flag;
uchar table[]={0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,\
21,22,23,24,25,26,27,28,29,30,31,32,33,34,35,36,37,38,39,40,41,42,43,\
44,45,46,47,48,49,50,49,48,47,46,45,44,43,42,41,40,39,38,37,36,35,34,\
33,32,31,30,29,28,27,26,25,24,23,22,21,20,19,18,17,16,15,14,13,12,11,\
10,9,8,7,6,5,4,3,2,1,0};//呼吸的效果
void main(void)
  uchar i;
  WDTCTL = WDTPW + WDTHOLD;                 // Stop WDT
  BCSCTL1 &= ~XT2OFF;                       //打开xt2晶振
  do
   IFG1 &= ~OFIFG;
   for(i = 0xff; i > 0; i--);
  while((IFG1 & OFIFG));                    //等待起振,消除晶体失败标志
  BCSCTL2 |= SELM_2 + SELS;                 //mclk.smclk选择高频晶振
  TACTL |= TASSEL_2 + ID_3 + MC_1;          //计数时钟选测smclk,8分频,增计数模式 1mhz
//TBCTL |= TBSSEL_2 + ID_3+ MC_1 ;
  TBCTL|= TBSSEL_2 + TBCLGRP_0 + ID_3 + MC_1 ;
  P4SEL|=BIT2;
  P4DIR|=BIT2;
  TBCCR0 = 50;                             // 50us de 周期
  TBCCTL1 = OUTMOD_3+CLLD_0;
//  TBCCTL1 &= ~CAP;
  TACCR0 =5000;
  TACCTL0 = CCIE;                         // 开中断使能
  _EINT();                                 // Enter LPM0 w/ interrupt
//  LPM0;                                    //低功耗
while(1);                                 //应该不会进入此句
#pragma  vector  = TIMERA0_VECTOR
__interrupt void timeA()
static uchar  i = 0;
flag++;
  P2DIR = 0XFF;
  P2OUT = 0XFF;
if(flag == 4)                             //大概20 ms时 较为理想
   flag = 0;
   TBCCR1 = table[i++];
   if(i > 100)
   { i = 0;
     P2DIR = 0XFF;
     P2OUT = 0X00;
为什么没有pwm产生啊
回复评论 (4)
你都没说你用啥型号的,让人家怎么帮你,TI每个系列的430型号都有历程的呀
点赞  2015-3-28 22:10
我用的是msp430f149
#include "msp430.h"
unsigned int flag;
void main(void)
  uchar i;
  do
   IFG1 &= ~OFIFG;
  //TACTL |= TASSEL_2 + ID_3 + MC_1;          //计数时钟选测smclk,8分频,增计数模式 1mhz
  P2DIR |= BIT4 + BIT3;                      // P2.3 .4输出
  P2SEL |= BIT4 + BIT3 ;                      // P2.3 .4特殊功能ta1
  TBCCTL0 = CCIE;                           // 开中断使能
  TBCCTL2 = OUTMOD_3 ;                      // 输出方式3
  TBCCTL1 = OUTMOD_3;
  LPM0;                                    //低功耗
#pragma  vector  = TIMERB0_VECTOR
__interrupt void timeB()
static uchar  i = 0,j = 0;
flag++;
if(flag == 400)                             //大概20 ms时 较为理想
   flag = 0;
   TACCR2 = table[i++];
   TACCR1 = table[j++];
   if(i > 100)
     i = 0;
   if(j > 100)
     j = 0;
点赞  2015-3-31 21:00
引用: 834707939 发表于 2015-3-31 21:00 我用的是msp430f149 #include "msp430.h" typedef unsigned char uchar; typedef unsigned int uint; unsigned int flag; uchar table[]={0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,\ 21,22,23,24,25,26,27,28,29,30,31,32,33,34,35,36,37,38,39,40,41,42,43,\ 44,45,46,47,48,49,50,49,48,47,46,45,44,43,42,41,40,39,38,37,36,35,34,\ 33,32,31,30,29,28,27,26,25,24,23,22,21,20,19,18,17,16,15,14,13,12,11,\ 10,9,8,7,6,5,4,3,2,1,0};//呼吸的效果 void main(void) { uchar i; WDTCTL = WDTPW + WDTHOLD; // Stop WDT BCSCTL1 &= ~XT2OFF; //打开xt2晶振 do { IFG1 &= ~OFIFG; for(i = 0xff; i > 0; i--); } while((IFG1 & OFIFG)); //等待起振,消除晶体失败标志 BCSCTL2 |= SELM_2 + SELS; //mclk.smclk选择高频晶振 //TACTL |= TASSEL_2 + ID_3 + MC_1; //计数时钟选测smclk,8分频,增计数模式 1mhz TBCTL |= TBSSEL_2 + ID_3+ MC_1 ; P2DIR |= BIT4 + BIT3; // P2.3 .4输出 P2SEL |= BIT4 + BIT3 ; // P2.3 .4特殊功能ta1 TBCCR0 = 50; // 50us de 周期 TBCCTL0 = CCIE; // 开中断使能 TBCCTL2 = OUTMOD_3 ; // 输出方式3 TBCCTL1 = OUTMOD_3; _EINT(); // Enter LPM0 w/ interrupt LPM0; //低功耗 while(1); //应该不会进入此句 } #pragma vector = TIMERB0_VECTOR __interrupt void timeB() { static uchar i = 0,j = 0; flag++; if(flag == 400) //大概20 ms时 较为理想 { flag = 0; TACCR2 = table; TACCR1 = table[j++]; if(i > 100) i = 0; if(j > 100) j = 0; } }
你先不要开中断,单独测试PWM看看,感觉你的程序怪怪的,先把这两句去掉看看: _EINT(); // Enter LPM0 w/ interrupt LPM0; //低功耗 本帖最后由 强仔00001 于 2015-3-31 21:07 编辑
点赞  2015-3-31 21:05
好的  , 我试试
点赞  2015-3-31 21:06
    写回复
