[讨论] msp430f4152 芯片中的flash问题
dingli   2015-3-31 17:19 楼主
msp430f4152中有256字节的信息存储器,地址从0x1000到0x10ff,分为四段A、B、C、D,0x1000~0x103F;0x1040~0x107F;0x1080~0x10BF;0x10C0~0x10FF。
void write_SegC(char value)
char *Flash_ptr; // Flash pointer
unsigned int i;
FCTL2 = FWKEY + FSSEL0 + FN1;
Flash_ptr = (char *)0x1080;                 // Initialize Flash pointer
FCTL3 = FWKEY;                                // Clear Lock bit
FCTL1 = FWKEY + ERASE;             // Set Erase bit
*Flash_ptr = 0;                                 // Dummy write to erase Flash seg
FCTL1 = FWKEY + WRT;            // Set WRT bit for write operation
for (i = 0; i < 16; i++)
*Flash_ptr++ =0x88;                   // Write value to flash
FCTL1 = FWKEY; // Clear WRT bit
FCTL3 = FWKEY + LOCK; // Set LOCK bit
程序如上,前三个信息段改变一下指针的地址,数据都能写进去,但是第四个段0x10C0~0x10FF,数据一直写不进去,一直显示0XFF,求高手帮忙解决一下
回复评论 (1)
什么情况!不是太懂! 本帖最后由 cnchouse 于 2015-3-31 17:28 编辑
点赞  2015-3-31 17:26
    写回复
