* @brief I2CM bus master example using polling mode
* @note
* Copyright(C) NXP Semiconductors, 2014
* All rights reserved.
* @par
* Software that is described herein is for illustrative purposes only
* which provides customers with programming information regarding the
* LPC products. This software is supplied "AS IS" without any warranties of
* any kind, and NXP Semiconductors and its licensor disclaim any and
* all warranties, express or implied, including all implied warranties of
* merchantability, fitness for a particular purpose and non-infringement of
* intellectual property rights. NXP Semiconductors assumes no responsibility
* or liability for the use of the software, conveys no license or rights under any
* patent, copyright, mask work right, or any other intellectual property rights in
* or to any products. NXP Semiconductors reserves the right to make changes
* in the software without notification. NXP Semiconductors also makes no
* representation or warranty that such application will be suitable for the
* specified use without further testing or modification.
* @par
* Permission to use, copy, modify, and distribute this software and its
* documentation is hereby granted, under NXP Semiconductors' and its
* licensor's relevant copyrights in the software, without fee, provided that it
* is used in conjunction with NXP Semiconductors microcontrollers. This
* copyright, permission, and disclaimer notice must appear in all copies of
* this code.
#include "board.h"
#include
/** @defgroup I2CM_POLLING_5410X I2C master (blocking/polling mode) ROM API example
* @ingroup EXAMPLES_ROM_5410X
* @include "rom\i2cm_polling\readme.txt"
* Private types/enumerations/variables
/* 400KHz I2C bit-rate */
#define I2C_BITRATE (400000)
/** I2C interface setup */
#define I2C_ADDR_7BIT (0xd0)//
#define LPC_I2C_PORT LPC_I2C2///LPC_I2C0
#define LPC_I2CM_CLOCK SYSCON_CLOCK_I2C2///SYSCON_CLOCK_I2C0
#define LPC_I2CM_RESET RESET_I2C2///RESET_I2C0
/* ROM driver handle for I2C master */
static ROM_I2CM_HANDLE_T i2cmHandle;
/* I2C driver context area */
static uint32_t drvData[16];
* Public types/enumerations/variables
/* Made global so data can be seen in the debuuger */
uint8_t rx[10], tx[4];
uint32_t actualRate;
ROM_I2CM_XFER_T mXfer;
* Private functions
/* Initializes pin muxing for I2C interface - note that SystemInit() may
already setup your pin muxing at system startup */
static void Init_I2C_PinMux(void)
{Chip_IOCON_PinMuxSet(LPC_IOCON, 0, 27, (IOCON_FUNC1 | IOCON_DIGITAL_EN));//23 /* I2C0 */
Chip_IOCON_PinMuxSet(LPC_IOCON, 0, 28, (IOCON_FUNC1 | IOCON_DIGITAL_EN));///
#if defined(BOARD_NXP_LPCXPRESSO_54102)
/* Connect the I2C_SDA and I2C_SCL signals to port pins */
Chip_IOCON_PinMuxSet(LPC_IOCON, 0, 28, (IOCON_FUNC1 | IOCON_DIGITAL_EN));///24 /* I2C0 */
#else
/* Configure your own I2C pin muxing here if needed */
#warning "No I2C pin muxing defined"
#endif
/* Display error string and spin */
static void errorOut(char *errStr)
DEBUGOUT(errStr);
while (1) {}
* Public functions
* @brief Main routine for I2C example
* @return Function should not exit
int main(void)
uint32_t memSize, *devMem;
ROM_I2CM_INIT_T i2cmInit;
/* Generic Initialization */
SystemCoreClockUpdate();
Board_Init();
/* Setup I2C pin muxing, enable I2C clock and reset I2C peripheral */
Init_I2C_PinMux();
Chip_Clock_EnablePeriphClock(LPC_I2CM_CLOCK);
Chip_SYSCON_PeriphReset(LPC_I2CM_RESET);
/* Get needed size for driver context memory */
memSize = ROM_I2CM_GetMemSize();
if (memSize > sizeof(drvData)) {
errorOut("Can't allocate memory for I2C driver context\r\n");
devMem = drvData; /* Or just use malloc(memSize) */
/* Initialize driver */
i2cmInit.pUserData = NULL;
i2cmInit.base = (uint32_t) LPC_I2C_PORT;
i2cmHandle = ROM_I2CM_Init(devMem, &i2cmInit);
if (i2cmHandle == NULL) {
/* Error initializing I2C */
errorOut("Error initializing ROM\r\n");
/* Set I2C clock rate */
actualRate = ROM_I2CM_SetClockRate(i2cmHandle,
Chip_Clock_GetAsyncSyscon_ClockRate(), I2C_BITRATE);
///DEBUGOUT("Actual I2C master rate = %dHz\r\n", actualRate);
/* Read data as fast as possible in loop */
while (1) {
/* Write address, write 1 btye, read 8 bytes back */
mXfer.slaveAddr = I2C_ADDR_7BIT;
tx[0] = 0x6b;
tx[1] = 0x00;
mXfer.txBuff = tx;
mXfer.rxBuff = rx;
mXfer.txSz = 2;
mXfer.rxSz = 1;
/* I2C master driver will block if blocking flag is used */
mXfer.flags = ROM_I2CM_FLAG_BLOCKING;
/* Start transfer and wait for completion */
ROM_I2CM_Transfer(i2cmHandle, &mXfer);
/* Check status of the transfer */
DEBUGOUT("I2C transfer completed: status = %x\r\n", mXfer.status);
if (mXfer.status != LPC_OK) {
errorOut("Error during I2CM transfer\r\n");
/* Code never reaches here. Only used to satisfy standard main() */
return 0;
在官方的例程修改!原来使用i2c0,修改为i2c2,问题不能正常访问这个端口啊!
主要点
tx[0] = 0x6b;
tx[1] = 0x00;
mXfer.txBuff = tx;
mXfer.rxBuff = rx;
mXfer.txSz = 2;
mXfer.rxSz = 0;
程序报错if (mXfer.status != LPC_OK) {
建议楼主把出现的问题描述放到帖子开头,看前面以为水帖哩
找到问题了!地址设定错误原以为是0xd0 (模拟i2c接口)
#define I2C_ADDR_7BIT (0x68)//硬件接口
确实,i2c超级好用,之前玩st的时候就没成功弄出来,nxp的太方便了。。。
