各位大神好,我今年毕设题目和这个有关,需要用ezdsp5535在ccsv4.2环境下做。但是我按照说明书操作的时候出现了如图的问题。
我是做到第八步Target->Connect Target时候遇到这个问题的 我的ccs软件是导师给我的标准匹配板子的,所以不是板子的问题。求大神解答thank u!
1. Launch CCS v4 from the shortcut on the desktop. (This was created when CCS v4
was installed).
2. The CCS v4 window will appear. Click the “Target” menu, then select “New Target
Configuration File”.
3. The “New Target Configuration” window will appear. Enter a file name that describe
the emulator connection and/or Texas Instruments device being used and click
“Finish”. For example: “C5535_eZdsp”.
4. The “Basic” configuration setup window will open in the CCS v4. Select “Texas
Instruments XDS100v2 USB Emulator” from the “Connection” menu. Type “5535” in
the “Device” field and select “eZdsp5535”, from the list.
5. Click the “Save” button to save the configuration.
6. Click the “View” menu and select “Target Configurations” to expose the
configuration(s) that have been built or imported. A new tab labeled “Target
Configurations” will become available in the CCS window.
7. Expand the “User Defined” folder. Right-click on the new configuration that has been
created and click “Launch Selected Configuration”.
8. Click “View->Debug” then click “Target->Connect Target”. CCS will attempt to connect
to the C5535 eZdsp and run the GEL file. Once the connection is successful and the
GEL file has finished, the console window will print a message stating
“Target Connection Complete”.
