[讨论] C2000 Delfino LaunchPad,谁愿意拥有?
dontium   2015-7-17 18:22 楼主
描述
Special Note:  Due to the popularity of the LAUNCHXL-F28377S LaunchPad, all new orders will be subject to a four week lead time.
The C2000 Delfino LaunchPad is an inexpensive evaluation platform that provides designers with a low cost development kit for high performance digital control applications.  The LaunchPad is based on the Delfino TMS320F28377S MCU which provides 400MIPS of total system performance between a 200MHz C28x CPU and a 200MHz real-time control co-processor (CLA). This powerful microcontroller contains 1MB of on-board flash and includes highly differentiated peripherals such as 16-bit/12-bit ADCs, comparators, 12-bit DACs, delta-sigma sinc filters, HRPWMs, eCAPs, eQEPs, CANs, and more. The LaunchPad supports 12-bit ADC mode through the header pins and 16-bit mode can be driven with external differential signals.
The LaunchPad board includes features such as integrated isolated XDS100v2 JTAG emulator for easy programming and debugging and also is compatible with the various BoosterPacks in the ecosystem.  Designers interested in learning digital power control using an MCU can plug in the digital power buck converter BoosterPack (BOOSTXL-BUCKCONV).
Getting started with software is easy with the application examples in controlSUITE.
Designers also have access to a complimentary full license of the latest version of Code Composer Studio IDE.
特性
回复评论 (11)
要团购了?
点赞  2015-7-17 19:44
这个有点小贵啊。。。。要是能够便宜点就好了
https://bbs.eeworld.com.cn/thread-471646-1-1.html 欢迎加入我的团队
点赞  2015-7-17 19:53
这个芯片高级啊,200M,CPU+CLA,……
点赞  2015-7-17 20:29
还没用过DSP,不知道用起来感觉有什么不一样
点赞  2015-7-17 20:32
团购算我一个。
作为一个水军,就是尽量的多回帖,因为懂的技术少,所以回帖水分大,见谅! EEWORLD开发板置换群:309018200,——电工们免费装β的天堂,商家勿入!加群暗号:喵
点赞  2015-7-18 01:07
我惦记很久了 。。。
点赞  2015-7-18 09:13
还有双核的!377D
stm32f7系列和这个有竞争的!
点赞  2015-7-18 11:09
口水很久了。我们凑一波邮费怎么样。
点赞  2015-7-18 13:22
我想要!!!
点赞  2015-7-18 14:51
我想拥有
点赞  2015-7-23 08:08
要买记得叫我~
点赞  2015-8-14 20:59
    写回复
