[求助] 使用28035并行驱动lcd12864显示的问题
1169047256   2015-9-24 18:19 楼主
将51单片机lcd显示改写成下面28035的,请大家看看有什么问题,屏幕没有任何显示。
#include "DSP28x_Project.h"
#define uint16 unsigned char
#define uint32 unsigned int
#define RS        GpioDataRegs.GPADAT.bit.GPIO8
#define RW        GpioDataRegs.GPADAT.bit.GPIO9
#define E        GpioDataRegs.GPADAT.bit.GPIO10
#define PSB        GpioDataRegs.GPADAT.bit.GPIO11
#define BF        GpioDataRegs.GPADAT.bit.GPIO7
void init_gpio(void);
void init_12864(void);                                        //12864初始化
void write_order12864(uint16 order);                   //向12864中写入命令
void write_data12864(uint16 shuju);                //向12864中写入数据
uint16 Busy_12864(void);                                        //12864忙信号检测
void write_address(uint16 y,uint16 x);        //数据显示位置
void static1(void);
uint16 const a[]={"你好!"};
void main(void)
        InitSysCtrl();
        DINT;
        InitPieCtrl();
        IFR=0x0000;
        IER=0x0000;
        InitPieVectTable();
        init_gpio();
        init_12864();
        while(1)
                static1();
        EALLOW;
        GpioCtrlRegs.GPAMUX1.all=0x00000000;
        GpioCtrlRegs.GPAMUX2.all=0x00000000;
        GpioCtrlRegs.GPAPUD.all=0xffffffff;
        GpioCtrlRegs.GPADIR.all=0x0000ffff;
        EDIS;
        GpioDataRegs.GPADAT.all=0x00000000;
        DELAY_US(2000);        //26us
        PSB=1;
        write_order12864(0x30);                   //8位数据,基本指令操作
        DELAY_US(8);
        DELAY_US(2);
        write_order12864(0x0c);                //数据整体显示,游标不显示
        DELAY_US(8);
        write_order12864(0x06);                //游标移动方向
        DELAY_US(8);
        write_order12864(0x01);                //清屏
        DELAY_US(80);
void write_order12864(uint16 order)                //写命令
        while(Busy_12864()==1);
        RS=0;
        RW=0;
        E=0;
        DELAY_US(2);
        E=1;
        DELAY_US(8);
        GpioDataRegs.GPADAT.all=(order&0x00ff)|GpioDataRegs.GPADAT.all;
        DELAY_US(2);
        E=0;
        DELAY_US(2);
void write_data12864(uint16 shuju)                //写数据
        RS=1;
        RW=0;
        E=0;
        DELAY_US(2);
        E=1;
        DELAY_US(8);
        GpioDataRegs.GPADAT.all=(shuju&0x00ff)|GpioDataRegs.GPADAT.all;
        DELAY_US(2);
        E=0;
        DELAY_US(2);
uint16 Busy_12864(void)                //忙信号检测
        EALLOW;
        GpioCtrlRegs.GPADIR.bit.GPIO7=0;
        EDIS;
        uint16 jiance=0;
        RS=0;
        RW=1;
        E=1;
        DELAY_US(2);
        jiance+=BF;
        DELAY_US(2);
        E=0;
        DELAY_US(2);
        EALLOW;
        GpioCtrlRegs.GPADIR.bit.GPIO7=1;
        EDIS;
        return jiance;
void write_address(uint16 y,uint16 x)                //数据显示位置
        switch(y)
                case 1:        write_order12864(0x0080|x);
                break;
                case 2:        write_order12864(0x0090|x);
                break;
                case 3:        write_order12864(0x0088|x);
                break;
                case 4:        write_order12864(0x0098|x);
                break;
void static1(void)
        DELAY_US(8);
        uint16 i=0;
        write_address(2,1);
        DELAY_US(8);
        while(a!='\0')
                write_data12864(a);
                i++;
                DELAY_US(20);
回复评论 (5)
楼主在51应用时也是这样写的(或相当)?
这句话的作用是什么?
点赞  2015-9-24 20:23
GpioDataRegs.GPADAT.all=(shuju&0x00ff)|GpioDataRegs.GPADAT ...
将16位数据中的8位有效数据取出
点赞  2015-9-25 20:10
引用: 1169047256 发表于 2015-9-25 20:10
将16位数据中的8位有效数据取出
后面的再和端口寄存器相或的作用呢?
点赞  2015-9-25 20:56
将16位数据中的8位有效数据取出
楼主,这样是不行滴。昨天刚出现这种情况。不能直接拿GpioDataRegs.GPADAT.all参加运算,你应该先给个变量x将GpioDataRegs.GPADAT.all赋值给x,再运算x,最后把x赋值给GpioDataRegs.GPADAT.all。
点赞  2015-9-30 13:52
急求啊,这东西怎么改都不行啊,延时是我根据手册一个一个写的,delay函数延时使用示波器测的。。。
void write_order12864(uint32 order);                   //向12864中写入命令
void write_data12864(uint32 shuju);                //向12864中写入数据
void Busy_12864(void);                                        //12864忙信号检测
void write_address(uint32 y,uint32 x);        //数据显示位置
void static1(void);
void delayus(uint32 t);
uint16 const a[]={"HELLO"};
void main(void)
        InitSysCtrl();
        DINT;
        InitPieCtrl();
        IFR=0x0000;
        IER=0x0000;
        InitPieVectTable();
        init_gpio();
        init_12864();
        while(1)
                static1();
        EALLOW;
        EDIS;
        delayus(2000);        //26us
        PSB=1;
        delayus(8);
        delayus(8);
        delayus(8);
        delayus(8);
        delayus(200);
void write_order12864(uint32 order)                //写命令
        Busy_12864();
        uint32 temp=0;
        //delayus(200);
        RS=0;
        RW=0;
        E=0;
        delayus(2);
        E=1;
        delayus(2);
        temp=GpioDataRegs.GPADAT.all;
        temp=temp & 0xff00;
        temp=temp|(order & 0x00ff);
        GpioDataRegs.GPADAT.all=temp;
        delayus(4);
        E=0;
        delayus(50);
void write_data12864(uint32 shuju)                //写数据
        Busy_12864();
        uint32 temp=0;
        //delayus(200);
        RS=1;
        RW=0;
        E=0;
        delayus(2);
        E=1;
        delayus(2);
        temp=temp & 0xff00;
        temp=temp|(shuju & 0x00ff);
        delayus(4);
        E=0;
        delayus(50);
void Busy_12864(void)                //忙信号检测
        EALLOW;
        EDIS;
        uint32 jiance=1;
        RS=0;
        RW=1;
        delayus(1);
        E=1;
        delayus(2);
        while(jiance==1)
                jiance=BF;
                delayus(8);
        E=0;
        delayus(50);
        EALLOW;
        EDIS;
void write_address(uint32 y,uint32 x)                //数据显示位置
        switch(y)
                case 1:        write_order12864(0x00000080|x);
                break;
                case 2:        write_order12864(0x00000090|x);
                break;
                case 3:        write_order12864(0x00000088|x);
                break;
                case 4:        write_order12864(0x00000098|x);
                break;
void static1(void)
        delayus(200);
        uint32 i=0;
        write_address(2,1);
        delayus(8);
        while(a[i]!='\0')
                write_data12864(a[i]);
                i++;
                delayus(100);
void delayus(uint32 t)                //25us
        uint32 i=150*t;
        for(;i>0;i--);
点赞  2015-10-3 11:30
    写回复
