利用keil的Manage Run-Time Environment可以快速进行开发,
但是首先要破解keil才能使用软件自带STemWin!
破解软件如下https://m.eeworld.com.cn/bbs/forum.php?mod=attachment&aid=MjE3MzU4fGQzYmJmZTNkZGNlYTUyZmEwMDhmOGE5YTU3ZjZiOGVkfDE3MzE2MzY1NDU%3D&request=yes&_f=.zip,支持最新的5.16a的破解
配置如下:
然后修改GUIConf.c
- * SEGGER Microcontroller GmbH & Co. KG *
- * Solutions for real time microcontroller applications *
- * (c) 1996 - 2015 SEGGER Microcontroller GmbH & Co. KG *
- * Internet: www.segger.com Support: support@segger.com *
- ** emWin V5.30 - Graphical user interface for embedded applications **
- All Intellectual Property rights in the Software belongs to SEGGER.
- emWin is protected by international copyright laws. Knowledge of the
- source code may not be used to write a similar product. This file may
- only be used in accordance with the following terms:
- The software has been licensed to ARM LIMITED whose registered office
- is situated at 110 Fulbourn Road, Cambridge CB1 9NJ, England solely
- for the purposes of creating libraries for ARM7, ARM9, Cortex-M
- series, and Cortex-R4 processor-based devices, sublicensed and
- distributed as part of the MDK-ARM Professional under the terms and
- conditions of the End User License supplied with the MDK-ARM
- Professional.
- Full source code is available at: www.segger.com
- We appreciate your understanding and fairness.
- Licensing information
- Licensor: SEGGER Software GmbH
- Licensed to: ARM Ltd
- Licensed SEGGER software: emWin
- License number: GUI-00181
- License model: LES-SLA-20007, Agreement, effective since October 1st 2011
- Licensed product: MDK-ARM Professional
- Licensed platform: ARM7/9, Cortex-M/R4
- Licensed number of seats: -
- File : GUIConf.c
- Purpose : Display controller initialization
- ---------------------------END-OF-HEADER------------------------------
- #include "GUI.h"
- * Defines
- // Define the available number of bytes available for the GUI
- #define GUI_NUMBYTES 0x200000
- * Public code
- * GUI_X_Config
- * Purpose:
- * Called during the initialization process in order to set up the
- * available memory for the GUI.
- void GUI_X_Config(void) {
- // 32 bit aligned memory area
- static U32 aMemory[GUI_NUMBYTES / 4] __attribute__((at(0xC0200000)));
- // Assign memory to emWin
- GUI_ALLOC_AssignMemory(aMemory, GUI_NUMBYTES);
- // Set default font
- GUI_SetDefaultFont(GUI_FONT_6X8);
- /*************************** End of file ****************************/
修改RTX_Conf_CM.C
- * CMSIS-RTOS - RTX
- * Name: RTX_Conf_CM.C
- * Purpose: Configuration of CMSIS RTX Kernel for Cortex-M
- * Rev.: V4.70.1
- * Copyright (c) 1999-2009 KEIL, 2009-2015 ARM Germany GmbH
- * All rights reserved.
- * Redistribution and use in source and binary forms, with or without
- * modification, are permitted provided that the following conditions are met:
- * - Redistributions of source code must retain the above copyright
- * notice, this list of conditions and the following disclaimer.
- * - Redistributions in binary form must reproduce the above copyright
- * notice, this list of conditions and the following disclaimer in the
- * documentation and/or other materials provided with the distribution.
- * - Neither the name of ARM nor the names of its contributors may be used
- * to endorse or promote products derived from this software without
- * specific prior written permission.
- * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
- * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
- * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
- * ARE DISCLAIMED. IN NO EVENT SHALL COPYRIGHT HOLDERS AND CONTRIBUTORS BE
- * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
- * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
- * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
- * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
- * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
- * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
- * POSSIBILITY OF SUCH DAMAGE.
- #include "cmsis_os.h"
- * RTX User configuration part BEGIN
- //-------- <<< Use Configuration Wizard in Context Menu >>> -----------------
- // <h>Thread Configuration
- // <o>Number of concurrent running user threads <1-250>
- // <i> Defines max. number of user threads that will run at the same time.
- // <i> Default: 6
- #ifndef OS_TASKCNT
- #define OS_TASKCNT 6
- #endif
- // <o>Default Thread stack size [bytes] <64-4096:8><#/4>
- // <i> Defines default stack size for threads with osThreadDef stacksz = 0
- // <i> Default: 200
- #ifndef OS_STKSIZE
- #define OS_STKSIZE 256 // this stack size value is in words
- #endif
- // <o>Main Thread stack size [bytes] <64-32768:8><#/4>
- // <i> Defines stack size for main thread.
- #ifndef OS_MAINSTKSIZE
- #define OS_MAINSTKSIZE 1024 // this stack size value is in words
- #endif
- // <o>Number of threads with user-provided stack size <0-250>
- // <i> Defines the number of threads with user-provided stack size.
- // <i> Default: 0
- #ifndef OS_PRIVCNT
- #define OS_PRIVCNT 0
- #endif
- // <o>Total stack size [bytes] for threads with user-provided stack size <0-1048576:8><#/4>
- // <i> Defines the combined stack size for threads with user-provided stack size.
- // <i> Default: 0
- #ifndef OS_PRIVSTKSIZE
- #define OS_PRIVSTKSIZE 0 // this stack size value is in words
- #endif
- // <q>Stack overflow checking
- // <i> Enable stack overflow checks at thread switch.
- // <i> Enabling this option increases slightly the execution time of a thread switch.
- #ifndef OS_STKCHECK
- #define OS_STKCHECK 1
- #endif
- // <q>Stack usage watermark
- // <i> Initialize thread stack with watermark pattern for analyzing stack usage (current/maximum) in System and Thread Viewer.
- // <i> Enabling this option increases significantly the execution time of osThreadCreate.
- #ifndef OS_STKINIT
- #define OS_STKINIT 0
- #endif
- // <o>Processor mode for thread execution
- // <0=> Unprivileged mode
- // <1=> Privileged mode
- // <i> Default: Privileged mode
- #ifndef OS_RUNPRIV
- #define OS_RUNPRIV 1
- #endif
- // </h>
- // <h>RTX Kernel Timer Tick Configuration
- // <q> Use Cortex-M SysTick timer as RTX Kernel Timer
- // <i> Cortex-M processors provide in most cases a SysTick timer that can be used as
- // <i> as time-base for RTX.
- #ifndef OS_SYSTICK
- #define OS_SYSTICK 1
- #endif
- // <o>RTOS Kernel Timer input clock frequency [Hz] <1-1000000000>
- // <i> Defines the input frequency of the RTOS Kernel Timer.
- // <i> When the Cortex-M SysTick timer is used, the input clock
- // <i> is on most systems identical with the core clock.
- #ifndef OS_CLOCK
- #define OS_CLOCK 200000000
- #endif
- // <o>RTX Timer tick interval value [us] <1-1000000>
- // <i> The RTX Timer tick interval value is used to calculate timeout values.
- // <i> When the Cortex-M SysTick timer is enabled, the value also configures the SysTick timer.
- // <i> Default: 1000 (1ms)
- #ifndef OS_TICK
- #define OS_TICK 1000
- #endif
- // </h>
- // <h>System Configuration
- // <e>Round-Robin Thread switching
- // <i> Enables Round-Robin Thread switching.
- #ifndef OS_ROBIN
- #define OS_ROBIN 1
- #endif
- // <o>Round-Robin Timeout [ticks] <1-1000>
- // <i> Defines how long a thread will execute before a thread switch.
- // <i> Default: 5
- #ifndef OS_ROBINTOUT
- #define OS_ROBINTOUT 5
- #endif
- // </e>
- // <e>User Timers
- // <i> Enables user Timers
- #ifndef OS_TIMERS
- #define OS_TIMERS 1
- #endif
- // <o>Timer Thread Priority
- // <1=> Low
- // <2=> Below Normal <3=> Normal <4=> Above Normal
- // <5=> High
- // <6=> Realtime (highest)
- // <i> Defines priority for Timer Thread
- // <i> Default: High
- #ifndef OS_TIMERPRIO
- #define OS_TIMERPRIO 5
- #endif
- // <o>Timer Thread stack size [bytes] <64-4096:8><#/4>
- // <i> Defines stack size for Timer thread.
- #ifndef OS_TIMERSTKSZ
- #define OS_TIMERSTKSZ 256 // this stack size value is in words
- #endif
- // <o>Timer Callback Queue size <1-32>
- // <i> Number of concurrent active timer callback functions.
- // <i> Default: 4
- #ifndef OS_TIMERCBQS
- #define OS_TIMERCBQS 4
- #endif
- // </e>
- // <o>ISR FIFO Queue size<4=> 4 entries <8=> 8 entries
- // <12=> 12 entries <16=> 16 entries
- // <24=> 24 entries <32=> 32 entries
- // <48=> 48 entries <64=> 64 entries
- // <96=> 96 entries
- // <i> ISR functions store requests to this buffer,
- // <i> when they are called from the interrupt handler.
- // <i> Default: 16 entries
- #ifndef OS_FIFOSZ
- #define OS_FIFOSZ 16
- #endif
- // </h>
- //------------- <<< end of configuration section >>> -----------------------
- // Standard library system mutexes
- // Define max. number system mutexes that are used to protect
- // the arm standard runtime library. For microlib they are not used.
- #ifndef OS_MUTEXCNT
- #define OS_MUTEXCNT 8
- #endif
- * RTX User configuration part END
- #define OS_TRV ((uint32_t)(((double)OS_CLOCK*(double)OS_TICK)/1E6)-1)
- * Global Functions
- /*--------------------------- os_idle_demon ---------------------------------*/
- /// \brief The idle demon is running when no other thread is ready to run
- void os_idle_demon (void) {
- for (;;) {
- /* HERE: include optional user code to be executed when no thread runs.*/
- #if (OS_SYSTICK == 0) // Functions for alternative timer as RTX kernel timer
- /*--------------------------- os_tick_init ----------------------------------*/
- /// \brief Initializes an alternative hardware timer as RTX kernel timer
- /// \return IRQ number of the alternative hardware timer
- int os_tick_init (void) {
- return (-1); /* Return IRQ number of timer (0..239) */
- /*--------------------------- os_tick_val -----------------------------------*/
- /// \brief Get alternative hardware timer's current value (0 .. OS_TRV)
- /// \return Current value of the alternative hardware timer
- uint32_t os_tick_val (void) {
- return (0);
- /*--------------------------- os_tick_ovf -----------------------------------*/
- /// \brief Get alternative hardware timer's overflow flag
- /// \return Overflow flag\n
- /// - 1 : overflow
- /// - 0 : no overflow
- uint32_t os_tick_ovf (void) {
- return (0);
- /*--------------------------- os_tick_irqack --------------------------------*/
- /// \brief Acknowledge alternative hardware timer interrupt
- void os_tick_irqack (void) {
- #endif // (OS_SYSTICK == 0)
- /*--------------------------- os_error --------------------------------------*/
- /* OS Error Codes */
- #define OS_ERROR_STACK_OVF 1
- #define OS_ERROR_FIFO_OVF 2
- #define OS_ERROR_MBX_OVF 3
- #define OS_ERROR_TIMER_OVF 4
- extern osThreadId svcThreadGetId (void);
- /// \brief Called when a runtime error is detected
- /// \param[in] error_code actual error code that has been detected
- void os_error (uint32_t error_code) {
- /* HERE: include optional code to be executed on runtime error. */
- switch (error_code) {
- case OS_ERROR_STACK_OVF:
- /* Stack overflow detected for the currently running task. */
- /* Thread can be identified by calling svcThreadGetId(). */
- break;
- case OS_ERROR_FIFO_OVF:
- /* ISR FIFO Queue buffer overflow detected. */
- break;
- case OS_ERROR_MBX_OVF:
- /* Mailbox overflow detected. */
- break;
- case OS_ERROR_TIMER_OVF:
- /* User Timer Callback Queue overflow detected. */
- break;
- for (;;);
- * RTX Configuration Functions
- #include "RTX_CM_lib.h"
- * end of file
