使用TM4C129en MCU,在主循环(while())中 使用USRT0 发送数据,为什么只发送一次,而不是循环发送。每重启一次发送一次,发送的也是对的。
不知道我哪里设置错了。软件调试感觉是执行过了。就是没有数据接收到。
那位高手给指点指点!
// uart_polled.c - Example demonstrating UART polled I/O.
// Copyright (c) 2010-2015 Texas Instruments Incorporated. All rights reserved.
// Software License Agreement
// Redistribution and use in source and binary forms, with or without
// modification, are permitted provided that the following conditions
// are met:
// Redistributions of source code must retain the above copyright
// notice, this list of conditions and the following disclaimer.
// Redistributions in binary form must reproduce the above copyright
// notice, this list of conditions and the following disclaimer in the
// documentation and/or other materials provided with the
// distribution.
// Neither the name of Texas Instruments Incorporated nor the names of
// its contributors may be used to endorse or promote products derived
// from this software without specific prior written permission.
// THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
// "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
// LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
// A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
// OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
// SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
// LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
// DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
// THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
// (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
// OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
// This is part of revision 2.1.1.71 of the Tiva Firmware Development Package.
#include
#include
#include
#include "hw_memmap.h"
#include "hw_ints.h"
#include "hw_gpio.h"
#include "gpio.h"
#include "pin_map.h"
#include "sysctl.h"
#include "uart.h"
#include "ssi.h"
#include "interrupt.h"
#include "SSIControl.h"
#include "timer.h"
#include "sysctl.h"
//! \addtogroup uart_examples_list
//! UART Polled I/O (uart_polled)
//! This example shows how to set up the UART and use polled I/O methods
//! for transmitting and receiving UART data. The example receives characters
//! from UART0 and retransmits the same character using UART0. It can be
//! tested by using a serial terminal program on a host computer. This
//! example will echo every character that is type until the return/enter key
//! is pressed.
//! This example uses the following peripherals and I/O signals. You must
//! review these and change as needed for your own board:
//! - UART0 peripheral
//! - GPIO Port A peripheral (for UART0 pins)
//! - UART0RX - PA0
//! - UART0TX - PA1
#if defined(TARGET_IS_TM4C129_RA0) || \
defined(TARGET_IS_TM4C129_RA1) || \
defined(TARGET_IS_TM4C129_RA2)
uint32_t ui32SysClock;
#endif
//uint32_t ADC_Data[2];
//uint32_t test_Data[2];
//uint32_t DAC_Data[2];
//float voltage0[2];
//float voltage1[2];
const uint32_t ADarry_ch0_Len=12;
const uint32_t ADarry_ch1_Len=12;
uint32_t ADC_Data_ch0[4];
uint32_t ADC_Data_ch1[4];
uint32_t test_Data[4];
uint32_t DAC_Data;
float vol_get_ch0[1];
float vol_get_ch1[1];
uint32_t Fix_ADC_Data_ch0;
uint32_t Fix_ADC_Data_ch1;
uint32_t getad_chanel_0[ADarry_ch0_Len];
uint32_t getad_chanel_1[ADarry_ch1_Len];
uint32_t setad_st1[ADarry_ch1_Len];
uint32_t setad_st2[ADarry_ch1_Len];
uint32_t send_AD_val;
//uint32_t i;
uint32_t temp_AD_ch0;
uint32_t temp_AD_ch1;
float cmpflval[2];
uint8_t Dev_Adj_State;
uint32_t adj_count_st1;
uint32_t keepnum;
uint32_t loopnum;
uint32_t Ch1_overnum;
uint32_t Ch1_zerornum;
uint32_t outrange_num;
uint32_t rangeok;
uint32_t st_1_outrange;
uint32_t fill_num_st1;
uint32_t fill_num_sum;
uint32_t fouse_set_DA;
uint8_t usart_send_data_state[15];
//void Data_AD2DA(uint32_t *ADC_Data, uint32_t *DAC_Data);
//void inttofloat(float *valfloat, uint32_t *hexDataval);
// The UART interrupt handler.
void
UARTIntHandler(void)
uint32_t ui32Status;
// Get the interrrupt status.
ui32Status = UARTIntStatus(UART0_BASE, true);
// Clear the asserted interrupts.
UARTIntClear(UART0_BASE, ui32Status);
// Loop while there are characters in the receive FIFO.
while(UARTCharsAvail(UART0_BASE))
// Read the next character from the UART and write it back to the UART.
UARTCharPutNonBlocking(UART0_BASE,
UARTCharGetNonBlocking(UART0_BASE));
// Send a string to the UART.
void
UARTSend(const uint8_t *pui8Buffer, uint32_t ui32Count)
// Loop while there are more characters to send.
while(ui32Count--)
// Write the next character to the UART.
UARTCharPutNonBlocking(UART0_BASE, *pui8Buffer++);
//UARTCharPut(UART0_BASE, *pui8Buffer++);
void
UARTSend_arry_data(const uint8_t pui8Buffer[], uint32_t ui32Count)
uint32_t loopnum_si;
for(loopnum_si=0;loopnum_si
// UARTCharPutNonBlocking(UART0_BASE, pui8Buffer[loopnum_si]);
UARTCharPut(UART0_BASE, pui8Buffer[loopnum_si]);
// The interrupt handler for the Timer0B interrupt.
void
Timer0BIntHandler(void)
// Clear the timer interrupt flag.
TimerIntClear(TIMER0_BASE, TIMER_TIMB_TIMEOUT);
// Update the periodic interrupt counter.
// g_ui32Counter++;
void Timer0Init(uint32_t Nms)
#endif
// The Timer0 peripheral must be enabled for use.
SysCtlPeripheralEnable(SYSCTL_PERIPH_TIMER0);
// Configure Timer0B as a 16-bit periodic timer.
TimerConfigure(TIMER0_BASE, TIMER_CFG_SPLIT_PAIR | TIMER_CFG_B_PERIODIC);
// Set the Timer0B load value to 1ms.
TimerLoadSet(TIMER0_BASE, TIMER_B, ui32SysClock / 1000);
#else
TimerLoadSet(TIMER0_BASE, TIMER_B, SysCtlClockGet() / 1000);
#endif
// Configure the Timer0B interrupt for timer timeout.
TimerIntEnable(TIMER0_BASE, TIMER_TIMB_TIMEOUT);
// Enable the Timer0B interrupt on the processor (NVIC).
IntEnable(INT_TIMER0B);
// Enable Timer0B.
TimerEnable(TIMER0_BASE, TIMER_B);
int
main(void)
usart_send_data_state[0]=0xEB;//frame head
usart_send_data_state[1]=0x01;//frame data type
usart_send_data_state[2]=0x00;//..device region
usart_send_data_state[3]=0x00;//..device code
usart_send_data_state[4]=0x01;//..data send reason
usart_send_data_state[5]=0x00;//..device state
usart_send_data_state[6]=0x00;//..DA0 height
usart_send_data_state[7]=0x00;//..DA0 low
usart_send_data_state[8]=0x00;//..DA1 height
usart_send_data_state[9]=0x00;//..DA1 low
usart_send_data_state[10]=0x00;//..AD0 height
usart_send_data_state[11]=0x00;//..DA0 low
usart_send_data_state[12]=0x00;//parite height
usart_send_data_state[13]=0x00;//parite low
usart_send_data_state[14]=0xAA;//frame end
#endif
// Set the clocking to run directly from the external crystal/oscillator.
// TODO: The SYSCTL_XTAL_ value must be changed to match the value of the
// crystal on your board.
defined(TARGET_IS_TM4C12ru9_RA1) || \
defined(TARGET_IS_TM4C129ru_RA2)
ui32SysClock = SysCtlClockFreqSet((SYSCTL_XTAL_25MHZ |
SYSCTL_OSC_MAIN |
SYSCTL_USE_OSC), 25000000);
#else
//SysCtlClockSet(SYSCTL_SYSDIV_1 | SYSCTL_USE_OSC | SYSCTL_OSC_MAIN |
// SYSCTL_XTAL_16MHZ);
SysCtlClockSet(SYSCTL_SYSDIV_2_5 | SYSCTL_OSC_MAIN | SYSCTL_USE_PLL |
SYSCTL_XTAL_25MHZ);
#endif
/////////////////uart init/////////////////////////////
#if 1
//ru
// Enruable the peripherals used by this example.
// The UruART itself needs to be enabled, as well as the GPIO port
// containirung the pins that will be used.
SysCtlPeripheralEnable(SYSCTL_PERIPH_UART0);
SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOA);
// Configure the GPIO pin muxing for the UART function.
//ru This is only necessary if your part supports GPIO pin function muxing.
// Struudy the data sheet to see which functions are allocated per pin.
// TODO:ru change this to select the port/pin you are using
GPIOPinConfigure(GPIO_PA0_U0RX);
GPIOPinConfigure(GPIO_PA1_U0TX);
// Since GPIO A0 and A1 are used for the UART function, they must be
//ru configured for use as a peripheral function (instead of GPIO).
// TOruDO: change this to match the port/pin you are using
GPIOPinTypeUART(GPIO_PORTA_BASE, GPIO_PIN_0 | GPIO_PIN_1);
// Configure the UART for 115,200, 8-N-1 operation.
//ru This function uses SysCtlClockGet() or ui32SysClock to get the system clock
// frruequency. This could be also be a variable or hard coded value
// insteruad of a function call.
UARTConfigSetExpClk(UART0_BASE, ui32SysClock, 115200,
(UART_CONFIG_WLEN_8 | UART_CONFIG_STOP_ONE |
UART_CONFIG_PAR_NONE));
#else
UARTConfigSetExpClk(UART0_BASE, SysCtlClockGet(), 115200,
#endif
//IntEnable(INT_UART0);
//ruUARTIntEnable(UART0_BASE, UART_INT_RX | UART_INT_RT);
#endif
/////////////////uart init end/////////////////////////////
UARTFlowControlSet(UART0_BASE,UART_FLOWCONTROL_NONE);
UARTFIFODisable();
UARTEnable(UART0_BASE);
IntEnable(INT_UART0); //??UART1??
// UARTIntEnable(UART0_BASE, UART_INT_RX );
// UARTIntEnable(UART0_BASE, UART_INT_TX);
// UARTSend((uint8_t *)"ssi test...\r\n", 16);
//////ru/////////////////////////////////////////////////////
//spi inirut
////////////ru//////////////////////////////////////////////
SSIConfigure(SSI2,1000000, SSI_FRF_MOTO_MODE_0, SSI2_DATA_WIDTH);
SSIConfigure(SSI3, 1000000, SSI_FRF_MOTO_MODE_1, SSI3_DATA_WIDTH);
//GPIO init
//ru////////////////////////////////////////////////////////
//GPIruO config (use TS12A4515 control)
*(uint32_t *)(GPIO_PORTA_BASE + GPIO_O_LOCK) = 0x4C4F434B;
*(uint32_t *)(GPIO_PORTA_BASE + GPIO_O_CR) = 0xFF;
//set PA dir
GPIOPinTypeGPIOOutput(GPIO_PORTA_BASE, GPIO_PIN_2 | GPIO_PIN_3);
//GPIO[PQ] config (use DAC8551 cs)
SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOQ);
*(uint32_t *)(GPIO_PORTQ_BASE + GPIO_O_LOCK) = 0x4C4F434B;
*(uint32_t *)(GPIO_PORTQ_BASE + GPIO_O_CR) = 0xFF;
//set PQ dir
GPIOPinTypeGPIOOutput(GPIO_PORTQ_BASE, GPIO_PIN_1);
//Timer0Init(1);
IntMasterEnable();
// Prompt for text to be entered.
//UARTSend((uint8_t *)"\033[2JEnter text: ", 16);
SSIRev_ADS_7950(ADC_Data_ch0, 0);
SysCtlDelay(1000000);
SSIRev_ADS_7950(ADC_Data_ch1, 1);
//DAC SSI cs
GPIOPinWrite(GPIO_PORTQ_BASE, GPIO_PIN_1, 1);
// LOW ON; HIGH OFF
GPIOPinWrite(GPIO_PORTA_BASE, GPIO_PIN_2 | GPIO_PIN_3, 0);
SysCtlPeripheralEnable(SYSCTL_PERIPH_GPION);
GPIOPinTypeGPIOOutput(GPIO_PORTN_BASE, GPIO_PIN_1);
Dev_Adj_State=0;
while(1)
led_state_on();
//ROM_UARTIntEnable(UART2_BASE, UART_INT_RX | UART_INT_RT);
//ROM_UARTIntEnable(UART2_BASE, UART_INT_TX);
//ROM_UARTIntDisable(UART2_BASE, UART_INT_RX | UART_INT_RT);
//ROM_UARTIntDisable(UART2_BASE, UART_INT_TX);
// UARTIntEnable(UART0_BASE, UART_INT_RX | UART_INT_RT);
// UARTIntDisable(UART0_BASE, UART_INT_RX | UART_INT_RT);
// UARTIntDisable(UART0_BASE, UART_INT_RX|UART_INT_TX);
// UARTDisable(UART0_BASE);
// SysCtlDelay(10000);
// UARTEnable(UART0_BASE);
// while(!UARTCharsAvail(UART0_BASE))
// while(UARTCharGetNonBlocking(UART0_BASE))
//UARTEnable(UART0_BASE);
UARTSend_arry_data(usart_send_data_state, 15);
//UARTSend((uint8_t *)"usart0 test...\r\n", 16);
// UARTIntEnable(UART0_BASE, UART_INT_RX);
// UARTIntDisable(UART0_BASE, UART_INT_TX);
led_state_off();
能看到电路板上的指示灯在闪烁。
就是没报文发出来。
看看具体的设置情况,串口初始化中,有没有使能发送中断。最好不要使能。看看程序卡在了什么地方。
