单次采样试过了 没问题 可是改成多路以后中断都进不去了! 哪个大神帮着看看哪的毛病!谢谢了
程序有电多 我只拷贝了我更改的部分!
1.先是初始化 A12 A13 A14 A15
ADC12_B_configureMemoryParam configureMemoryParam = {0};
configureMemoryParam.memoryBufferControlIndex = ADC12_B_MEMORY_0;
configureMemoryParam.inputSourceSelect = ADC12_B_INPUT_A12;
configureMemoryParam.refVoltageSourceSelect =
ADC12_B_VREFPOS_AVCC_VREFNEG_VSS;
configureMemoryParam.endOfSequence = ADC12_B_NOTENDOFSEQUENCE;
configureMemoryParam.windowComparatorSelect =
ADC12_B_WINDOW_COMPARATOR_DISABLE;
configureMemoryParam.differentialModeSelect =
ADC12_B_DIFFERENTIAL_MODE_DISABLE;
ADC12_B_configureMemory(ADC12_B_BASE, &configureMemoryParam);
//ADC12_B_configureMemoryParam configureMemoryParam = {0};
configureMemoryParam.memoryBufferControlIndex = ADC12_B_MEMORY_1;
configureMemoryParam.inputSourceSelect = ADC12_B_INPUT_A13;
configureMemoryParam.memoryBufferControlIndex = ADC12_B_MEMORY_2;
configureMemoryParam.inputSourceSelect = ADC12_B_INPUT_A14;
configureMemoryParam.memoryBufferControlIndex = ADC12_B_MEMORY_3;
configureMemoryParam.inputSourceSelect = ADC12_B_INPUT_A15;
configureMemoryParam.endOfSequence = ADC12_B_ENDOFSEQUENCE;
ADC12_B_clearInterrupt(ADC12_B_BASE,
0,
ADC12_B_IFG3
//Enable memory buffer 0 interrupt
ADC12_B_enableInterrupt(ADC12_B_BASE,
ADC12_B_IE3,
0,
0);
2.定时器里转换
#if defined(__TI_COMPILER_VERSION__) || defined(__IAR_SYSTEMS_ICC__)
#pragma vector=TIMERB0_VECTOR
__interrupt
#elif defined(__GNUC__)
__attribute__((interrupt(TIMERB0_VECTOR)))
#endif
void TIMERB0_ISR(void)
//Enable/Start sampling and conversion
* Base address of ADC12B Module
* Start the conversion into memory buffer 0
* Use the single-channel, single-conversion mode
ADC12_B_startConversion(ADC12_B_BASE,
ADC12_B_MEMORY_0,
ADC12_B_SEQOFCHANNELS);
// __bis_SR_register(LPM3_bits | GIE); // Wait for conversion to complete
// __bic_SR_register(GIE);
3.AD中断
#pragma vector=ADC12_VECTOR
__interrupt
__attribute__((interrupt(ADC12_VECTOR)))
#endif
void ADC12_ISR(void)
switch(__even_in_range(ADC12IV,12))
case 0: break; // Vector 0: No interrupt
case 2: break; // Vector 2: ADC12BMEMx Overflow
case 4: break; // Vector 4: Conversion time overflow
case 6: break; // Vector 6: ADC12BHI
case 8: break; // Vector 8: ADC12BLO
case 10: break; // Vector 10: ADC12BIN
case 12:
// Vector 12: ADC12BMEM0 Interrupt
ADC12IFGR0 &= ~ADC12IFG0; // Clear interrupt flag
__bic_SR_register_on_exit(LPM3_bits); // Exit active CPU
break; // Clear CPUOFF bit from 0(SR)
case 14:
ADC12IFGR0 &= ~ADC12IFG1; // Clear interrupt flag
break; // Vector 14: ADC12BMEM1
case 16:
ADC12IFGR0 &= ~ADC12IFG2; // Clear interrupt flag
break; // Vector 16: ADC12BMEM2
case 18:
qInput[samp_count] = ADC12_B_getResults(ADC12_B_BASE, ADC12_B_MEMORY_0);
samp_count++;
if(samp_count >=256)
samp_count =0;
mode = 1;
// Disable ADC12 and Timer_A0
ADC12_B_disable(ADC12_B_BASE);
Timer_B_stop(TIMER_B0_BASE);
__bic_SR_register_on_exit(LPM0_bits); // Exit active CPU //退出LPM0
break; // Vector 18: ADC12BMEM3
case 20: break; // Vector 20: ADC12BMEM4
case 22: break; // Vector 22: ADC12BMEM5
case 24: break; // Vector 24: ADC12BMEM6
case 26: break; // Vector 26: ADC12BMEM7
case 28: break; // Vector 28: ADC12BMEM8
case 30: break; // Vector 30: ADC12BMEM9
case 32: break; // Vector 32: ADC12BMEM10
case 34: break; // Vector 34: ADC12BMEM11
case 36: break; // Vector 36: ADC12BMEM12
case 38: break; // Vector 38: ADC12BMEM13
case 40: break; // Vector 40: ADC12BMEM14
case 42: break; // Vector 42: ADC12BMEM15
case 44: break; // Vector 44: ADC12BMEM16
case 46: break; // Vector 46: ADC12BMEM17
case 48: break; // Vector 48: ADC12BMEM18
case 50: break; // Vector 50: ADC12BMEM19
case 52: break; // Vector 52: ADC12BMEM20
case 54: break; // Vector 54: ADC12BMEM21
case 56: break; // Vector 56: ADC12BMEM22
case 58: break; // Vector 58: ADC12BMEM23
case 60: break; // Vector 60: ADC12BMEM24
case 62: break; // Vector 62: ADC12BMEM25
case 64: break; // Vector 64: ADC12BMEM26
case 66: break; // Vector 66: ADC12BMEM27
case 68: break; // Vector 68: ADC12BMEM28
case 70: break; // Vector 70: ADC12BMEM29
case 72: break; // Vector 72: ADC12BMEM30
case 74: break; // Vector 74: ADC12BMEM31
case 76: break; // Vector 76: ADC12BRDY
default: break;
大家帮看看哪有毛病 谢谢了
这个手册上还要有写,主要是寄存器的值的配置,这个还是自己看看吧,对自己也是一种提高,老实说,在论坛上贴程序的,很多是解决不了问题的,就像我一样,即使这个芯片我用过,我也不会再回去翻芯片手册一点点的对照程序检查
