[原创] SINA31S第一次上电
白丁   2016-7-7 22:32 楼主
因为没有屏幕只好接上串口看看板子自带的是什么东西,波特率115200
  1. HELLO! BOOT0 is starting!
  2. boot0 version : 2.4.0
  3.                       reg_addr 0x01f00100 =0x00000000
  4. reg_addr 0x01f00104 =0x00000000
  5. reg_addr 0x01f00108 =0x00000000
  6. reg_addr 0x01f0010c =0x00000000
  7. reg_addr 0x01f00110 =0x00000000
  8. reg_addr 0x01f00114 =0x00000000
  9. [DRAM]ver 1.03 clk = 432
  10. cpu 1 pmu 1
  11. dram size =1024
  12. card boot number = 2
  13. card no is 2
  14. sdcard 2 line count 0
  15. [mmc]: cmd 8 timeout, err 0x00000100
  16. [mmc]: mmc cmd 8 err 0x00000100
  17. [mmc]: cmd 55 timeout, err 0x00000100
  18. [mmc]: mmc cmd 55 err 0x00000100
  19. [mmc]: cmd 6 timeout, err 0x00000040
  20. [mmc]: mmc cmd 6 err 0x00000040
  21. [mmc]: retry mmc switch(cmd6)
  22. [mmc]: SD/MMC Card: 4bit, capacity: 3776MB
  23. [mmc]: vendor: Man 0x00110100 Snr 0x105097aa
  24. [mmc]: product: 004G9
  25. [mmc]: revision: 3.0
  26. sdcard 2 init ok
  27. The size of Boot1 is 0x0004c000.
  28. Succeed in loading boot1 from sdmmc flash.
  29. Ready to disable icache.
  30. Succeed in loading Boot1.
  31. Jump to Boot1.
  32. [       0.276] boot1 version : 2.4.0
  33. [       0.280] script installed ok
  34. [       0.281] PMU: AXP221
  35. [       0.281] bat ratio = 100
  36. [       0.283] dcdc3 1260
  37. [       0.328] pll1 1008
  38. [       0.358] power finish
  39. [       0.358] key
  40. [       0.370] fel key max not found, try old mode
  41. [       0.370] no key found
  42. [       0.375] dcdc1 3000
  43. [       0.375] dcdc2 1200
  44. [       0.376] dcdc4 1240
  45. [       0.378] dcdc5 1500
  46. [       0.381] flash init start
  47. [       0.528] [mmc]: cmd 8 timeout, err 0x00000100
  48. [       0.528] [mmc]: mmc cmd 8 err 0x00000100
  49. [       0.531] [mmc]: mmc send if cond failed
  50. [       0.535] [mmc]: cmd 55 timeout, err 0x00000100
  51. [       0.540] [mmc]: mmc cmd 55 err 0x00000100
  52. [       0.544] [mmc]: send app cmd failed
  53. [       0.548] the first time to get sd card's operation condition
  54. [       0.873] [mmc]: cmd 6 timeout, err 0x00000040
  55. [       0.874] [mmc]: mmc cmd 6 err 0x00000040
  56. [       0.877] [mmc]: mmc switch failed
  57. [       0.881] [mmc]: retry mmc switch(cmd6)
  58. [       0.900] [mmc]: SD/MMC Card: 4bit, capacity: 3776MB
  59. [       0.901] [mmc]: vendor: Man 0x00110100 Snr 0x105097aa
  60. [       0.905] [mmc]: product: 004G9
  61. [       0.909] [mmc]: revision: 3.0
  62. [       0.912] [mmc]: boot0 capacity: 2000KB,boot1 capacity: 2000KB
  63. [       0.918] flash init finish
  64. [       0.942] fs init ok
  65. [       0.943] fattype FAT16
  66. [       0.943] fs mount ok
  67. [       0.947] dram_para_set start
  68. [       0.950] dram_para_set end
  69. [       0.950] type=2
  70. [       0.973] 0
  71. [       0.979] try card mode
  72. [       0.979] storage_type=2
  73. [       1.077] [mmc]: cmd 8 timeout, err 0x00000100
  74. [       1.077] [mmc]: mmc cmd 8 err 0x00000100
  75. [       1.080] [mmc]: mmc send if cond failed
  76. [       1.085] [mmc]: cmd 55 timeout, err 0x00000100
  77. [       1.089] [mmc]: mmc cmd 55 err 0x00000100
  78. [       1.093] [mmc]: send app cmd failed
  79. [       1.097] the first time to get sd card's operation condition
  80. [       1.201] [mmc]: cmd 1 timeout, err 0x00000100
  81. [       1.201] [mmc]: mmc cmd 1 err 0x00000100
  82. [       1.204] [mmc]: mmc send op cond failed
  83. [       1.209] [mmc]: Card did not respond to voltage select!
  84. [       1.214] [mmc]: mmc register failed
  85. [       1.218] [mmc]: SDMMC_PhyInit:Init SD/MMC card failed !
  86. [       1.224] MSG:L336(BootMain.c):card is not exist
  87. [       1.229] ret1=0,ret2=0
  88. [       1.231] all gpio get ok
  89. [       1.234] 0x43600010
  90. [       1.237] all jtag gpio get ok
  91. [       1.240] 0x436000c0
  92. [       1.414] WRN:L229(Common/ui/display_interface/display_interface.c):fetch script data boot_disp.output_type fail
  93. [       1.419] WRN:L265(Common/ui/display_interface/display_interface.c):fetch script data boot_disp.output_mode fail
  94. [       1.429] WRN:L285(Common/ui/display_interface/display_interface.c):fetch script data boot_disp.auto_hpd fail
  95. [       1.439] lcd0_para.lcd_used=1
  96. [       1.442] lcd open
  97. [       1.446] lcd 0 timeout=0
  98. [       1.491] lcd 1 timeout=10
  99. [       1.491] lcd open,ret=0
  100. [       1.491] power status = 3
  101. [       1.494] power start cause = 0
  102. [       1.497] axp buffer 0x00000000
  103. [      [       1.501] lcd 2 timeout=50
  104. 1.500] power trigger
  105. [       1.506] startup status = 1
  106. [       1.509] no battery exist
  107. [       1.554] lcd 3 timeout=0
  108. [       1.554] lcd 4 timeout=0
  109. [       1.564] key 0
  110. [       1.565] recovery key high 32, low 28
  111. [       1.565] cant find fstbt value
  112. [       1.569] try to boot
  113. [       1.571] load kernel start
  114. [       1.592] load kernel successed
  115. [       1.593] start address = 0x4a000000
  116. [       1.594] jump to
  117. [       1.596] 0x4a000000
  118. U-Boot 2011.09-rc1-00000-gf2ffe6c-dirty (Jul 26 2014 - 10:21:09) Allwinner Technology
  119. CPU:   SUNXI Family
  120. Board: SUN6I
  121. DRAM:  1 GiB
  122. MMC:   SUNXI SD/MMC: 2
  123. retry mmc switch(cmd6)
  124. In:    serial
  125. Out:   serial
  126. Err:   serial
  127. --------fastboot partitions--------
  128. -total partitions:10-
  129. -name-        -start-       -size-
  130. bootloader  : 1000000       1000000
  131. env         : 2000000       1000000
  132. boot        : 3000000       1000000
  133. system      : 4000000       30000000
  134. data        : 34000000      40000000
  135. misc        : 74000000      1000000
  136. recovery    : 75000000      2000000
  137. cache       : 77000000      20000000
  138. databk      : 97000000      8000000
  139. UDISK       : 9f000000      4bc00000
  140. -----------------------------------
  141. bootcmd set setargs_mmc
  142. Hit any key to stop autoboot:  0
  143. read boot or recovery all
  144. sunxi flash read :offset 3000000, 10239546 bytes OK
  145. [       3.812]
  146. Starting kernel ...
  147. [    1.159317] sun6i_vibrator_init motor is not used in config
  148. [    1.388211] otg_wakelock_init: No OTG transceiver found
  149. [    2.384144] init: width = 1024
  150. [    2.387564] init: height = 600
  151. [    2.390975] init: s.st_size = 3145728
  152. [    2.395087] init: logo match failed!fbsize = 2457600
  153. [    2.402696] init: dont need format /dev/block/by-name/UDISK
  154. [    3.771845] sw_keyboard: module is already loaded
  155. [    3.885406] init: cannot find '/system/etc/install-recovery.sh', disabling 'flash_recovery'
  156. shell@android:/ $ [    6.138315] init: untracked pid 1693 exited
  157. [    8.912794] aw5306_ts 1-0038: AW5306_ts_probe: CHIP ID NOT CORRECT
training
回复评论 (19)
神奇的CHIP ID NOT CORRECT,居然连shell都输入不了
training
点赞  2016-7-7 22:35
一堆的timeout和fail啊
training
点赞  2016-7-7 22:39
好像没关系吧 aw5306是个触摸屏芯片
你现在接屏了没
生活就是油盐酱醋再加一点糖,快活就是一天到晚乐呵呵的忙 =================================== 做一个简单的人,踏实而务实,不沉溺幻想,不庸人自扰
点赞  2016-7-8 00:26
你现在接屏了没
没有啊,没有屏幕也不应该这样啊,mmc一直timeout
training
点赞  2016-7-8 08:21
没接 当然是这样的
点赞  2016-7-8 13:03
是不是把控制台console重定向到 lcd上了
点赞  2016-7-8 16:17
有什么办法重定向回来呢?目前手头没有匹配的液晶屏
training
点赞  2016-7-8 19:39
在 device tree里面, 一般都是在节点 chose指明的
比如 zynq-zed.dts就是这么写的:
chosen {
                bootargs = "console=ttyPS0,115200 root=/dev/ram rw earlyprintk";
                linux,stdout-path = "/amba/serial@e0001000";
点赞  2016-7-8 20:00
training
点赞  2016-7-8 20:44
因为没有液晶屏,所以专门买了一根HDMI转VGA的线,用上之后能够正常运行,鼠标接到usb口上也能够使用,想到之前shell没有响应大概是因为安卓待机了,没有触摸(这里是鼠标)开机后很快就进入了代码息屏状态,大概不是因为重定向到了lcd
training
点赞  2016-7-8 20:48
给大家看看十块零三毛包邮的HDMI转VGA线
training
点赞  2016-7-8 20:53
我也是醉了
点赞  2016-7-11 07:38
老白  给个HDMI转VGA你买的线的地址呢
点赞  2016-10-21 17:02
看了下已经下架了,改卖别的东西了,你直接搜索HDMI转vga,选择包邮,再按照价格排下序就能找到便宜的
training
点赞  2016-10-21 19:33
这货分有源和无源么 网上看的这个不知道能不能用  10,8
点赞  2016-12-6 23:14
当时没注意,应该是可以用的,我买的就是最便宜的,
training
点赞  2016-12-7 08:40
那应该是不带电源和音频的
点赞  2016-12-7 09:14
引用: 常见泽1 发表于 2016-12-7 09:14
那应该是不带电源和音频的
没有电源和音频,这两根线都没有
training
点赞  2016-12-7 09:37
引用: 白丁 发表于 2016-12-7 09:37
没有电源和音频,这两根线都没有
多谢老白 已GO入
点赞  2016-12-7 09:43
    写回复
