[经验] STM32F0 TX,RX反了,STM32 TX/RX SWAP功能又救了我一次
damiaa   2016-9-21 10:49 楼主
今天又犯了一次低级错误,STM32F0 TX,RX反了,STM32 TXRXSWAP功能又救了我一次 今天板子回来,串口没反应,知道坏了,估计是TX,RX反了。 但还是记得以前把TX,RX用软件调换过。今天在QQ和人聊,然后也看了库。 QQ图片20160921143124.png stm32f0xx_usart.c中找到下面函数: /** * @brief Enables or disables the swap Tx/Rx pins. * @param USARTx: where x can be 1 or 2 to select the USART peripheral. * @param NewState: new state of the USARTx TX/RX pins pinout. * This parameter can be: * @arg ENABLE: The TX and RX pins functions are swapped. * @arg DISABLE: TX/RX pins are used as defined in standard pinout * @note This function has to be called before calling USART_Cmd() function. * @retval None */ void USART_SWAPPinCmd(USART_TypeDef* USARTx, FunctionalState NewState) { /* Check the parameters */ assert_param(IS_USART_ALL_PERIPH(USARTx)); assert_param(IS_FUNCTIONAL_STATE(NewState)); if (NewState != DISABLE) { /* Enable the SWAP feature by setting the SWAP bit in the CR2 register */ USARTx->CR2 |= USART_CR2_SWAP; } else { /* Disable the SWAP feature by clearing the SWAP bit in the CR2 register */ USARTx->CR2 &= (uint32_t)~((uint32_t)USART_CR2_SWAP); } } 于是在串口初始化后调用 USART_SWAPPinCmd(COM_USART[COM1], ENABLE); NVIC_InitTypeDef NVIC_InitStructure; USART_InitTypeDef USART_InitStructure; USART_InitStructure.USART_BaudRate = 115200; USART_InitStructure.USART_WordLength = USART_WordLength_8b; USART_InitStructure.USART_StopBits = USART_StopBits_1; USART_InitStructure.USART_Parity = USART_Parity_No; USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None; USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; STM_COMInit(COM1, &USART_InitStructure); USART_SWAPPinCmd(COM_USART[COM1], ENABLE); 串口正常了。 喜欢犯错的朋友们不用犯愁了。哈哈。 附:F1好像没这个功能哦。 看控制寄存器 2(USART_CR2)就知道了。 QQ图片20160921143430.png 本帖最后由 damiaa 于 2016-9-21 14:35 编辑
回复评论 (10)
这个功能的确很实用啊,F0全系列都支持吗
点赞  2016-9-21 10:57
好像是,留意一下库就知道了。F4,F7也许都可以。
点赞  2016-9-21 11:06
点赞  2016-9-21 13:57
算你有种,我还是第一次遇到居然有人这么用
http://shop34182318.taobao.com/ https://shop436095304.taobao.com/?spm=a230r.7195193.1997079397.37.69fe60dfT705yr
点赞  2016-9-21 14:07
斑竹,被逼的啊。
点赞  2016-9-21 14:23
F10x不行么,没听说过这个神奇的功能
亚里士缺德
点赞  2016-9-21 14:27
引用: 汤权 发表于 2016-9-21 14:27
F10x不行么,没听说过这个神奇的功能
是没有,F0 F3 F4,F7估计都有,看看 控制寄存器 2(USART_CR2)确定一下。
点赞  2016-9-21 14:36
thankyou
亚里士缺德
点赞  2016-9-21 15:26
你这个USART_SWAPPinCmd函数,看起来好像只有在f0中有,f4是没有你说的这个函数的。哈哈哈,所以幸亏你用的是f0。
点赞  2016-9-21 23:52
F3可以,F7可以   F4真没看到。
点赞  2016-9-22 11:14
    写回复
